Old 01-05-2010, 02:39 PM   #1
tjsblazer
tjsblazer's Avatar
Question factory oil pressure gauge 60lb ??
Was the standard oil pressure gauge for a 350 engine 60lbs on a 72 Blazer ??
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 01-05-2010, 03:28 PM   #2
turp mcspray
turp mcspray's Avatar
Re: factory oil pressure gauge 60lb ??
Yes. Small blocks are 60 and big blocks are 80.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 01-05-2010, 03:42 PM   #3
Firebirdjones
I wasn't aware of numbers on the 70-72 gauges, and didn't know bigblocks were part of the blazer line.
I can tell you my 72 blazer oil pressure gauge does coincide with a hand held mechanical gauge I had T'd into just for a comparison. And when the factory gauge was pegged it matched very close to the 60 lbs. mark on my handheld.
My 79 pickup with a factory 454 doesn't have an 80lbs. gauge either. Neither did the 77 bigblock I had before that. They were also all 60 lbs. gauges,,,with actual numbers on the gauge in those years.
Firebirdjones is offline   Reply With Quote
Old 01-05-2010, 04:07 PM   #4
71swb4x4
71swb4x4's Avatar
67-72 gauges do not have numbers on the face, but they do utlilize the two different gauges, 60 and 80 lb.
you are right, no BB in Blazers but lots of gauge panels swapped in and out so you may have an 80 where a 60 would have been stock.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-05-2010, 04:10 PM   #5
Firebirdjones
That's true with all the swapping on these things over the last 40 years.
With that said then the original posters best bet is to do what I did, and temporarily hook another mechanical gauge up just to see how it reads in comparison.
Old 01-05-2010, 09:56 PM   #6
turp mcspray
Sorry for the confusion. My post was a general, "across the board" statement in regards to the entire 67-72 body style. If you pull the gauge out of the panel you will see where it says 60 or 80lb. I believe they used a 60lb in all applications from 73 up.
Turp Mcspray
Old 01-06-2010, 01:42 PM   #7
Firebirdjones
Oooops, my bad. I gotcha now.
Old 01-06-2010, 07:54 PM   #8
tjsblazer
tjsblazer's Avatar
Thanks for the responses. I see now where when removed it is printed on the lower face. 80lb might be the way to go with fresh higher performance 383 always seems to peg the guage full over.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 01-06-2010, 08:43 PM   #9
too much stuff
Roadtrip!
too much stuff's Avatar
I think the 80 pound gauges were found in the C-40 and bigger trucks. I believe everything from C-10-C-30 was a 60 pound regardless of engine size.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-06-2010, 09:34 PM   #10
jaros44sr
jaros44sr's Avatar
I hope my oil gauge never goes bad, don't know if I can lift a 60lb. gauge up into my dash, let alone an 80 lb. one
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-06-2010, 09:38 PM   #11
Critter
Future TOTM Winner
Critter's Avatar
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 09-14-2018, 03:41 AM   #12
toolboxchev
Originally Posted by Critter View Post
Yea I am getting to old for that also! Hope the original goes another 50!
toolboxchev is offline   Reply With Quote
