05-17-2011, 07:37 PM | #1 |
T56 trans is getting stuck in 4th gear HELP
Prior to getting stuck there was no weird noises or grinding. Coming to a stop light I tried taking it out of gear and it would not come out. As I turned into a neighborhood I was able to work it free. I kept driving for a few minutes and everything checks out ok.
The car only has 15k on it. Do I need to rebuild? Posted via Mobile Device |
05-18-2011, 09:39 AM | #2 |
On a budget like Fred Sanford
Re: T56 trans is getting stuck in 4th gear HELP
Most likely a damaged 3-4 shift fork and/or broken fork pads, pretty common problem. The transmission will need torn down and inspected. Make sure you upgrade to the stronger steel 3-4 fork when you put it back together.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
