11-27-2011, 02:52 PM | #1 |
1 thing at a time is progress.
2004 Tahoe 5.3 weird idle
I'll do my best to explain this.
Runs great at all RPM's except at idle. At idle it has an erratic skip. Sometimes it is barely noticeable and at other times it drops low enough to make the lights dim. I notice it more when it is warm. When cold it runs smooth. There are no check engine lights on. It has about 145K on the clock. It also happens with AC on or off. If I two foot it and bring the idle up about 100-200 rpm it is still noticeable. Any suggestions will be greatly appreciated.
Alan
Philippians 2:14-16 |
11-27-2011, 08:27 PM | #2 |
Re: 2004 Tahoe 5.3 weird idle
Clean the throttle body bore with some carb cleaner.
11-27-2011, 08:33 PM | #3 |
my 03 z71 5.3 did the same thing.... its "somewhat" normal i guess. does it to my dads too... but his is a 6.0. put it on a snap on live diagnostics and it is a mix with ethonal gas. only happened if i ran 87. I cleaned throttle body, votec plenum, etc. and it still did it. i ran 89 or 93 mix with 87 and lucas upper cylinder lubricant and it went away. but comes back when i ran with plain old gas.....now that i have a new truck 2010 with the 6.2 i notice it does the same just not as bad. i run a mix of 93 and 87 and no problem so far..with the lucas too of course...
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 |
11-27-2011, 08:34 PM | #4 |
may want to replace plugs and wires...that helps too....
11-27-2011, 08:44 PM | #5 |
Thanks guys I'm sure it needs the throttle body cleaned. I just put some Lucas injector cleaner in yesterday. I don't know what's been done as far as maintenance. I just bought it about two months ago. I should go ahead and change the plugs etc. I'll post the outcome.
Alan
11-28-2011, 02:20 AM | #6 |
check fuel pressure regulator as well.
12-02-2011, 11:11 PM | #7 |
Hadn't got to do much yet. I did buy some E3 plugs. Then I pulled one out for a comparision. i don't think they need changed, what do y'all think? I only pulled one. The idle is getting noticeably worse. The throttle body is next, I hope to get it cleaned tomorrow.
Alan
12-03-2011, 12:31 AM | #8 |
I run Delco or NGK plugs. I dont recommend running any type of "gimmick" spark plug.
If it idles worse when its cold......Intake gaskets are known to cause this symtom. If it they have never been replaced.....I would replace them as a maintainence item at 148K. |
12-03-2011, 03:17 PM | #9 |
I have to agree. Put delcos back in it. If you do some looking you will see there have been instances where the gimmick plugs are the issue.
12-03-2011, 05:26 PM | #10 |
Has more rust than truck...
X3 Get a good set of normal plugs. Platinum or Iridium are fine, just no multiple electrode/power enhancing gimmick junk like Clinebarger and bighaas said.
12-03-2011, 09:21 PM | #11 | |
If you do the intake gaskets, I would recommend getting the better Fel-pro gaskets that are molded rubber over steel frame instead of the stock plastic holder with a seal.....do it once and be done with it
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627 Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948 |
12-05-2011, 10:54 AM | #12 |
Thanks for all the input. I finally cleaned the TB today. Very cruddy inside. I thought for sure that would fix it. I would say it helped. The idle doesnt fall off as much as before. It does still have a noticeable drop in RPM at idle. It feels like a little shake in the seat. Until I can go get some AC plugs, should I unhook the battery to reset the computer? Does the ECM have a memory of the way it was running. I'll post pics tonight of the TB.
Alan
12-05-2011, 11:38 AM | #13 |
those e-3s will cause the coil to burn up if not carefull best plug for that truck is the ac delco 41-110 Iridium plugs runn 9-11 dollars each but they will run 100k miles with no changing, the e-3's are a resister plug which will not let all the energy from the coil though
12-05-2011, 12:16 PM | #14 | |
Does it idle any better after it's fully warmed up? That would be another indication of an intake gasket issue.....they usually idle worst when they're cold, and get better as they warm up when everything expands from the heat....
12-05-2011, 12:26 PM | #15 | ||
Alan
12-06-2011, 12:47 AM | #16 |
I can't post pics tonight, because I can't find my DL cable for the camera. Home improvements suck. Anyways.........
I read some where to clean the MAF. I started thinking about it and one thing I didn't mention is there is a K&N air filter installed. Maybe the oil from the filter has put a film of oil on the MAF and dust has accumilated on the sensor. Thoughts?? I picked up the AC plugs today as well and didn't have time to install them. After driving home the idle doesn't seem much better. I'm just trying to do the simple things first. I'd like to do a smoke test, but don't have access to a tester. I can check around and see if someone I know has one. Is there a specific ohm range on the plug wires? Or should they just be changed? I really don't want to replace parts if not needed. I really don't know if they are original or not. If they are original I would say it is time to replace them like someone mentioned before.
Alan
12-06-2011, 02:16 PM | #17 |
Update: the AC plugs seemed to have fixed the problem as of right now. I let it idle up to temp without any drop off. I'm confident that it is fixed. Before I would have noticed it once it warmed up. Thanks for all the help guys. Y'all rock.
Alan
12-06-2011, 09:52 PM | #18 |
another sotry off crapy e-3"s glad the plugs fixed it
12-07-2011, 12:56 AM | #19 |
Pics as promised. I did put antiseize on the plugs. I almost forgot.
Alan
02-18-2012, 10:30 PM | #20 |
laying low
So Alan is it still idling ok for ya?
02-18-2012, 10:39 PM | #21 |
Yes Sir, no complaints.
Alan
