01-13-2015, 10:38 PM | #1 |
E rated tires
I have e rated tires on NY K20.
Book recommends 65 psi, but I am running 45 psi right now. It doesn't seem t affect mileage. So that s it bad for the tires if I don't load the truck up? Going for a bit less jarring of a ride, and it seems to of worked. |
01-13-2015, 10:42 PM | #2 |
Re: E rated tires
Should be fine.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
01-14-2015, 01:15 AM | #3 |
20' Daredevil (Ret)
Re: E rated tires
You'll be fine. Increase the pressure if you're carrying heavier loads.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
01-14-2015, 01:41 AM | #4 |
Re: E rated tires
I think my sidewalls call for 80psi max, I run around 45 unloaded. Still doesn't ride smooth but it's less bad.
1973 C20, 350/350 |
01-14-2015, 01:55 PM | #5 |
Re: E rated tires
01-14-2015, 10:21 PM | #6 |
Re: E rated tires
I've had this conversation with others before. I had some LR E tires on my half ton, I would run them at 35 PSI when not loaded. I was told I couldn't do that, they aren't rated, etc... by so called, "experts."
So I showed them this. http://www.michelintruck.com/referen...tion-tables/#/ Anyhow, most LR E tires can be safely run at 35 PSI without any ill effects. Trust me, your back and kidneys will thank you. I don't know what kind of tire you have, but I'm sure the manufacturer has a similar inflation table. |
01-15-2015, 01:34 AM | #7 |
20' Daredevil (Ret)
Re: E rated tires
^ That's a great resource, whitedog -- thanks for posting the link. Saved.
01-15-2015, 03:03 AM | #8 |
Re: E rated tires
I run about 40 psi front and rear, unloaded in my 64 1/2 ton pickup. Bump the rears up to 60 or so when I'm putting 1500lbs of gravel in the bed.
Tires are 235/85r16. I like this size a lot because its similar to the old 7.50-16 size.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
