Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-19-2011, 10:56 AM   #1
Raider Rudy
Raider Rudy's Avatar
66 4x4 my sons new project
Picked it up on Thursday!
1969 Chevy Long Fleet Custom C/10 (2nd owner)
1971 Chevy Short Fleet Custom C/10 (2nd owner)
2001 Chevy Silverado Ext Cab
Raider Rudy is offline   Reply With Quote
Old 03-19-2011, 12:37 PM   #2
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
Re: 66 4x4 my sons new project
Very cool!! What are the plans keep it stock or custom?
66Gilbert is offline   Reply With Quote
Old 03-19-2011, 12:42 PM   #3
66Gilbert
66Gilbert's Avatar
Glad to see that this old 4x4 did not make it to a salvage yard.
Old 03-19-2011, 05:29 PM   #4
Raider Rudy
He wants to keep it original, but when we crawled under it we found out the transfer case was missing! It had an old Rockwell. The rear end is blown out too, so we have our work cut out for us!
Old 03-19-2011, 10:53 PM   #5
argonaut
argonaut's Avatar
Its got a fair bit of rust in the cab and some pretty wavy body panels. So I'll be keeping my eyes open for a donor long bed with some good steel, preferably 60-62.
The previous owner drilled about fifty thousand holes in the dash, mounted switches and gauges and an auxillary fuse panel... so I spent part of today ripping all that out and restoring the wiring to factory.
For now we'll focus on getting the powertrain and drivetrain sorted out. And hopefully in the next two weeks there will be a big block in here.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 03-26-2011, 09:58 PM   #6
wilkinst
Beautiful truck! Looks about like what I started with. Keep us posted with your plans and more pictures!
wilkinst is offline   Reply With Quote
Old 03-27-2011, 12:37 AM   #7
scottsdaleowner75
Cool build. Good to see another 4x4'er near me. (San Bernardino)
scottsdaleowner75 is offline   Reply With Quote
Old 03-27-2011, 02:11 AM   #8
argonaut
argonaut's Avatar
UPDATE
Today I scored a deal on some parts froma guy parting out a 73 1/2 ton Blazer.
Picked up front Dana44 axle complete hub to hub, along with the linkage, power steering gearbox and sway bar. I'll need to do some research on the best way to mount the steering gearbox as well as the sway bar. On the 73 the sway bar mounted to the front crossmember, which is quite different than the 66's front crossmember.
Grabbed the power brake booster, master cylinder, proportioning valve and mounting brackets. So this should set us up well with the disk brake Dana44 up front and help stop this big truck.
Finally loaded up the complete rear axle and both front and rear driveshafts. As I discovered a week ago the rear differential in the 66 had grenaded at some point in the past so I'll just swap out the whole rear axle. I'll need to check the pinion angle with respect to the leaf perches and compare to stock.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 03-27-2011, 11:49 AM   #9
Raider Rudy
Before I let my son have the truck I was going to cut it down to a short bed.
I wonder if he is going to keep it a long bed
Old 03-27-2011, 07:05 PM   #10
argonaut
argonaut's Avatar
..but there is so much room in that loooong bed
One thing I noticed today is that the driver's side shock mounts behind the axle on the 73 12 bolt, as opposed to both shocks on the 66 which mount forward. I'm thinking of relocating the upper shock mount bracket in the frame to the rear of the axle on the driver's side.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 03-27-2011, 07:58 PM   #11
scottsdaleowner75
Yes you will have to drill a hole and instal the shock bolt and stud. No big deal. I vote shortbed all the way!!
Old 03-27-2011, 09:19 PM   #12
Raider Rudy
Short Bed Yesssss!
Old 03-27-2011, 09:49 PM   #13
west9378
west9378's Avatar
I like the idea of a long bed for now later you may decide to shorten the bed.
west9378 is offline   Reply With Quote
Old 03-27-2011, 10:45 PM   #14
onebadbowtie
onebadbowtie's Avatar
long bed 4x4's look tougher!!!
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 03-28-2011, 12:36 PM   #15
argonaut
argonaut's Avatar
It looks like there is a standoff bracket that is riveted inside the frame C-channel. I'll have to remove it and relocate it further back on the frame.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 03-28-2011, 04:29 PM   #16
scottsdaleowner75
Or you could just inboard the shocks with a new mount like the 1 ton K30's and CUCV's.
Old 03-28-2011, 05:33 PM   #17
argonaut
argonaut's Avatar
Photos?
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 03-28-2011, 06:20 PM   #18
Altec
Getcha Pull
Altec's Avatar
If it is going to be used as a truck, then keep it long.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 03-28-2011, 06:39 PM   #19
msgross
msgross's Avatar
Captain Fab (on the board) makes a bracket for the newer steering box to mount to the flat frames. Use a piece of C Channel for the front crossmember extension, to mount the sway bar.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-28-2011, 06:47 PM   #20
argonaut
argonaut's Avatar
I was looking at Catain Fab's post on the steering gearbox adapter. Do the 2wd and 4wd gearboxes mount in the same way/loctation/pattern? I have a CPP kit that I will be putting onto my 64 C10 in the next few weeks... but I'm not the biggest fan of CPP at the moment.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 03-28-2011, 09:22 PM   #21
msgross
msgross's Avatar
yes, they mount the same but the arm moves in different directions...
The Garage:
Old 03-28-2011, 09:31 PM   #22
LeftCoast32
Custom Builder
LeftCoast32's Avatar
Very nice start to a build for your son! Keep us posted on the progress. Keep it a Long Bed, it will look great with a set of 33"-35" tires on it. Here is mine on stock suspension and 35" tires. I will have these wheels and a bunch of parts left over from my build. I am down in Carlsbad about 1.5 hours drive from you.
LeftCoast32 is offline   Reply With Quote
Old 03-28-2011, 09:40 PM   #23
Raider Rudy
Nice long bed! I noticed it the other day. I had big plans for the truck but my son said it was the truck of his dreams
Old 03-29-2011, 01:58 PM   #24
argonaut
argonaut's Avatar
I believe my dad has secured the '72 donor truck with the 402 big block that is destined for transplant into the '66. That means we have all the major parts necessary to turn Big Ugly into a runner!
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 03-29-2011, 01:59 PM   #25
argonaut
argonaut's Avatar
Lefty, Let us know when you start pulling parts off of yours, there may be some we're interested in!
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
