08-25-2022, 04:03 PM | #1 |
2 Temperature Sending units?
I've always been a little confused about how my small block 350 has 2 temperature sending units- one over the thermostat housing and one driver's side head. I'm currently reading off the Thermostat housing. Is there a best location (using standard factory gauge)? Is there any advantage to adding a second gauge that perhaps reads in degrees F?
Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! |
08-25-2022, 04:47 PM | #2 |
Re: 2 Temperature Sending units?
If you have a factory gauge (original to the truck) than the sending unit wired to it should be right
Vehicles with just a dash light for temp the sender is typically on intake manifold or sometimes T Stat housing. For a "gauge" it would be head, where temp is more accurate IMHO (generally will read 10 degrees hotter than one on manifold) |
08-25-2022, 06:28 PM | #3 |
The heads are the biggest issue if you start to overheat, so I'll never quite understand checking the temp in the thermostat housing or manifold.
08-25-2022, 06:59 PM | #4 |
Some people have a sending unit for the gauge in the cab, and another sending unit that turns electric fan at the radiator on and off as needed. That may be why you have 2 sending units. There is probably a threaded hole in each head, so both of the sending units can go in the heads if desired. I have a sending unit on the driver side head for the gauge, and a sending unit on the passenger side head that I have yet to wire up that will go to the TEMP warning light. They are different types of sending units, one gives a variable resistance to ground to work the gauge, and the one for the warning light switches on at 240 +/- 10 degrees.
08-25-2022, 07:01 PM | #5 |
Early 283 had the factory sensor on the intake near to the thermo housing.
1968 was the first year for sensor in head. Last edited by geezer#99; 08-25-2022 at 07:07 PM. |
08-25-2022, 07:57 PM | #6 |
I have two thermostat sending units and two gauges. Previous owner, rather than mess with the factory gauges and sending unit, added a second one for under the dash that is a little easier to read (ie it has numbers on it).
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
08-25-2022, 09:51 PM | #7 |
Who Changed This?
^ I did this because my in-dash temp gauge was going bug nuts. At some point that will be fixed. I priced a complete dash from Autometer. O.o
08-26-2022, 07:12 AM | #8 |
I may be wrong, but the temperature sending unit for gauge (or light) was always in the intake and then the head. There could be a ported vacuum switch in the T-stat housing, but I don't believe the gauge sender was ever there from the factory.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
03-01-2023, 12:32 PM | #9 |
I meant to follow up on this a while back. So if I want a second guage reading off the head, one with numbers on it, what temperature range should be on the guage and is there one that will work with the existing sender?
