01-11-2017, 02:23 PM | #1 |
Pictures of both AMP gauge fuse locations?
I shorted my amp gauge when working on my cluster and the fuse by the junction block broke when I pulled the holder apart. I replaced it but the gauge still isn't working. I have heard of a 2nd fuse but on externally regulated vehicles. I have a 70 with internally regulated alternator. Does anyone have a picture of where this 2nd fuse holder is on my model??
Thanks!
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
01-11-2017, 02:26 PM | #2 | |
The Older Generation
Re: Pictures of both AMP gauge fuse locations?
LockDoc
01-11-2017, 02:56 PM | #3 | |
Now to figure out how to install a 1-wire alternator AND keep the gauge working.
01-12-2017, 12:10 PM | #4 |
Found the one on the driver side. It was blown as well. Replaced it and the gauge works again! Stoked!
01-12-2017, 03:41 PM | #5 | |
You could convert the ammeter to a voltmeter, I think someone on the board even sells a kit. It'd be more informative, accurate, and best of all it'd work!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
01-12-2017, 03:52 PM | #6 | |
1978 SWB cheyenne A/C, power steering/brakes, 305, Tach, Gauges 1972 SWB Custom 10, gauges, cammed LQ9, M22 |
01-12-2017, 04:37 PM | #7 |
I was using the LS3 eRod wiring harness, so it gets tied to the battery, and the main lead from the alternator goes to the junction block. It has the sense wires if you can use them, so I just went ahead and used them. That means that NONE of the original wiring was retained or modified, and the old regulator is still sitting on the firewall. So my case likely doesn't help you much, sorry.
There are a ton of threads on the basic external regulator to internal conversion. It's cut two wires and loop two others together, pretty easy, if that's what you're after.
01-12-2017, 05:38 PM | #8 |
Changing the alt. wireing will have no effect on the ammeter.
01-12-2017, 09:51 PM | #9 |
I agree. The ammeter measures the current flowing one direction or the other along the red wire that goes from the battery junction block to the front driver-side fender area. As long as your alternator connects to the red wire at the driver-side fender area, and you continue to use that same 12 gauge red wire, the ammeter will work fine and show battery draw or charging.
01-12-2017, 10:02 PM | #10 |
Old member
Mad electric is all you need.
Read this and see why 3 wires is better than one. http://www.madelectrical.com/electri...hreewire.shtml
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
