04-18-2017, 09:06 AM | #1 |
Moderator
65 C10 6cyl battery cable length?
Ordered a new set of cables from my parts guy last week. Went to install them on the weekend, negative is too short, positive is way too long. What length are they supposed to be? Yes, I've measured, I already have crappy parts store ones on there.
04-18-2017, 06:28 PM | #2 |
Moderator
Re: 65 C10 6cyl battery cable length?
Ok, I went through the supplier's website to find what I need.
I had: - 15" negative (too short) - 65" positive (way too long) Looked at their other cables, and ordered: - 20" negative - 48" positive I'll update when I get them. |
04-18-2017, 06:54 PM | #3 |
Moderator
You could take an old piece of copper wire and run it along the route you want and use that as a measurement to purchase the correct length. So you dont have to buy things twice.
Or not.
04-18-2017, 07:45 PM | #4 |
Moderator
I actually measured before calling the parts place the first time. They sent the wrong stuff.
04-19-2017, 11:10 AM | #5 |
It's Better With Nitro
Knowing how expensive these cables are, and in case you haven't placed the re-order yet, I would shorten the positive cable and just order the negative cable.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
04-19-2017, 07:06 PM | #6 |
Moderator
I have a good parts place. I get parts delivered an hour after I call, and I don't pay up front. No problem with the wrong ones, driver picks them up on the next run.
04-19-2017, 07:41 PM | #7 |
...just another truck junkie..
That certainly makes things easier for you. Great to have a place that works with a person like that.
Mike "Bear" Shea |
