04-01-2017, 01:17 PM | #1 |
New super-bright LED 194 dash bulbs
Found these on Amazon, ordered a set. I installed one bulb and I literally thought I'd done something wrong, because all the others "went out"... actually the one was just so bright that it made the others look off by comparison!
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 I'd have to pull my cluster to swap them all, so I can't speak to what it would look like. But the color temp seems OK, or at least appropriate for my dash. I've got a number of clear, blue, and green LEDs in 194 format and didn't care for any of them, and am running stock bulbs. These might change that though! They are intense. Wish I could find a candle power rating (our stock lamps a 2cd).
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
04-01-2017, 06:06 PM | #2 |
70+ ( Old Skool Club )
Re: New super-bright LED 194 dash bulbs
I bought these for my trucks dash but haven't installed them yet. Post up some pics when you get yours installed.
https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-01-2017, 09:06 PM | #3 |
But are you able to adjust the brightness?
04-01-2017, 09:49 PM | #4 |
I didn't try, sorry! There are a couple of references in the discussion at Amazon to dimming them, so it sounds like it, but I can't say I tried.
06-04-2017, 11:26 PM | #5 | |
06-05-2017, 11:26 AM | #6 |
Picture of them on?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
06-05-2017, 11:34 AM | #7 |
I have a set of LED's in the dash as well, though i'm unable to dim them at all so far. Haven't looked into it, just installed and verified they worked.
06-05-2017, 01:18 PM | #8 |
I'll have to wait until dark tomorrow night.
06-07-2017, 12:49 AM | #9 |
For anyone who is curious, I used the same lights and was able to swap them all without pulling the gauge cluster. I just reached up behind the dash and pulled out all the bulb holders, and put them back in by feel. Really easy, took maybe 5 minutes to do.
06-07-2017, 01:37 AM | #10 |
I did mine the same way buy can't find one. In the picture, and this is the back of my dash, I can't find the one on the left side of the gray speedo box.
06-07-2017, 03:41 AM | #11 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Pics please,
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
06-07-2017, 08:12 AM | #12 | |
The Older Generation
That hole would be where your fiber optic socket is located. There is still a bulb in it but it has a black fiber optic cable attached to the socket that goes to your shift indicator on the upper column.... You remove it the same way as the others. LockDoc
06-13-2017, 03:02 PM | #13 |
I'll have to try again to find that last bulb holder. I noticed my gear selector is not lit up either. . Here are the pics of my dash and you can see the dark spot is where that fibre optic thing must be. LED's are bright enough so my old eyes see the gauges clearly but not blinding bright.
06-13-2017, 04:01 PM | #14 | |
Hahahaha I breathe near mine and the cable falls out of the socket! Its white and on my cluster, it is between the speedo and tach. It is difficult to turn to remove once the socket is locked in. However though years of patience and understanding I can put the fiber optic cable back in by feel...
06-13-2017, 04:33 PM | #15 | |
06-13-2017, 06:31 PM | #16 |
Ordered a set of these last week and installed them Sunday . They are great . To whomever found them kudos to you and thanks
06-13-2017, 06:56 PM | #17 |
That was me as I'm asuming you meant the Yorkims. I'm glad they worked good for you. How about some pics of your dash at night?
06-13-2017, 07:11 PM | #18 |
I have leds in mine also, undimmable. The led in the fiber optic socket is not bright though. A regular bulb is brighter there. Ive just grown used to it being dimmer than the rest of the leds. I also put leds in the ac controller panel too. Its much brighter now.
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
06-13-2017, 07:19 PM | #19 | |
06-13-2017, 07:38 PM | #20 | |
06-13-2017, 08:29 PM | #21 | ||
06-13-2017, 09:32 PM | #22 | |||
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
06-13-2017, 11:59 PM | #23 |
Keith if you go to Post #10 in this thread the back of my dash is pictured and its the socket just to the left of the grey speedo bob on the right sid eof the dash.
Post # 13 has pics of my LED"s at night from last night actually and yes they dim. P01 is the RPO Code for the deluxe hubcaps/wheel covers that were offered on the trucks and they are oftened referred to by that code. Pic attached.
06-14-2017, 10:04 AM | #24 |
Nothing a tilt column wouldn't solve ;-)[/QUOTE]
If you're buying, i accept cash, money order, or cashiers check.
06-14-2017, 10:50 AM | #25 | |
Yes, the bulb holder is a different configuration but it locks in the same as the rest. You can replace it with a regular bulb holder if you want. LockDoc
