Old 11-09-2017, 01:56 PM   #1
T2vigil
T2vigil's Avatar
Brake swap sequence
Is there a right way to make the swap from stock brakes on my 64. I am all set parts wise but would like opinions on where to start. I'm going to install power assisted disc both front and rear. Power booster, rear or front first. Thanks in advance. Terry
T2vigil is offline   Reply With Quote
Old 11-09-2017, 03:36 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Brake swap sequence
Have you checked post #2 in the FAQ section? http://67-72chevytrucks.com/vboard/s...15&postcount=2
Old 11-09-2017, 07:21 PM   #3
T2vigil
T2vigil's Avatar
Yes I did. My question was where to start? Start with the booster, or the rear brakes or the front brakes? Or does it matter where to start?
Old 11-10-2017, 12:24 AM   #4
Captainfab
60-66 Nut
I don't think it matters much as you won't be able to drive it until it is complete. You should not run a disc/disc master and prop valve with drums/drums.
Old 11-10-2017, 07:40 AM   #5
ImpalaJim
ImpalaJim's Avatar
Id like to go disc on mine but I like the no power brake thing. When peeps look at my truck I say that's a 1966 serpentine. I like that just what and nothing more then you need look.
ImpalaJim is offline   Reply With Quote
Old 11-10-2017, 10:36 AM   #6
T2vigil
T2vigil's Avatar
Thanks Captain. You have answered the question that I was unsure of.
