04-12-2014, 09:54 PM | #1 |
Turn signal cable
I am in need of a new turn signal cable mine is bent and rusted. I found one at classic industries and ordered it and when it came in it's to short. It says it is for a impala and a 62 truck. Did anyone else have this problem? Does anybody know where to find the right cable?
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
04-13-2014, 08:26 AM | #2 |
Re: Turn signal cable
Lost me on this one. What is a turn signal cable? All mine are wires.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-13-2014, 10:05 AM | #3 |
The cable runs from the turn signal assembly to the switch. I ordered a new one and it's to short. Did anybody on this site ever replace it and where did you buy the correct one? I can use the short one but I will have to remove the colum and re drill the switch mounting holes.
04-13-2014, 11:25 AM | #4 |
Only cable I have seen used on a Chevy is for an Impala.
There are some on Ebay |
04-13-2014, 12:16 PM | #5 |
Enjoy your truck
I have never seen such a thing.
Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
04-13-2014, 12:37 PM | #6 |
Where is the switch mounted that you need a cable to operate it? AND, why don't you relocate it?
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
04-13-2014, 12:41 PM | #7 |
I have never seen this either. As far as I can see, my 62' doesn't have this either. Could someone have put an Impala set-up in your truck?
04-13-2014, 01:04 PM | #8 |
some if not all of the 60/61 and 62s used the cable with the switch down on the column http://img.inkfrog.com/click_enlarge...&aid=306971192 and http://www.ebay.com/itm/60-61-62-Che...1fb8b1&vxp=mtr
04-13-2014, 01:06 PM | #9 |
WOW! I guess I wasn't to old to learn something new. lol
04-13-2014, 04:17 PM | #10 |
I have the new Impala cable but it's to short. The truck cable is about 1in longer so the mounting screws are off from the new one. I can relocate but I didn't want to drop the column just for this switch. I can't get my right angle drill to get into the right location. I guess I need to drop it because I am also having a problem with the horn also. There was a member on here that rebuilds columns. Does anybody remember?
04-13-2014, 06:32 PM | #11 |
I don't know about the differences, but someone has drilled new holes in my column in the past from the cable being too short. It was probably from it breaking and instead of replacing they just bent the end and made new holes. I believe that's called ingenuity. haha!
04-13-2014, 06:47 PM | #12 |
Senior Enthusiast
Wow I've learned something new as well. I replaced my original 1960 column 20 years ago, but I don't remember it having anything like that.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
04-13-2014, 08:28 PM | #13 |
I was a new one on me too. I have had a 63, a 64, and now a 65 and a 66 but no 60 or 61's.
Jimmy
04-13-2014, 09:15 PM | #14 |
Just one of the many reasons these 60-62's are so zany! Look at us over here with our hydraulic clutches, torsion bar suspension, nutty cable operated turn signal and bonus x-member frame rails. We're out of control!
04-13-2014, 10:01 PM | #15 |
One foot in front of the other
04-13-2014, 10:58 PM | #16 |
Never seen this
and would upgrade to 63-72 turn switch with wires if this is not a high end factory correct restore truck |
04-13-2014, 11:13 PM | #17 |
I have one I am pretty sure, it is on a column in my shed. I have about 6 auto columns in there and I remember that unusual set up on a couple of my columns... I will look first chance I get and get back with ya
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
04-14-2014, 06:10 AM | #18 |
Thanks for checking. Softpatch I was wondering if I could switch it to a 63 or newer set up? It would be easier to deal with than this setup.
04-14-2014, 07:57 AM | #19 |
As far as switching them over..... I know the plug ins are different, I did put an older column in a 65 once. I cut the plug ins off and rewired it, so it can be done.
04-14-2014, 12:31 PM | #20 |
my 61 had that set-up. I know i saved it, but where is it? will look for it. post up some measurements.
1961 chevy K10 my build is------------61K10 build |
04-19-2014, 09:28 PM | #21 |
Ok I finally got the turn signal to work. I lowered the column and repositioned and mounted the switch. I cut the cable sleeve and installed the turn signal cable. Now if I can get the horn to work I can get it on the road. Here are some pics.
11-16-2017, 07:53 PM | #22 |
My turn signal cable pulled loose, how does the cable connect to the switch? I see the switch portion that moves but can not see how to connect the cable.
11-16-2017, 09:54 PM | #23 |
Small pin on the switch that the cable end slides over and is held by a clip.
11-20-2017, 09:05 PM | #24 |
I'm guessing my cable has been broken off on the end, it is just a plain straight cable, nothing to hook on to. Looks like I need a new cable if I understand.
11-21-2017, 11:24 AM | #25 |
The lower end doesn't have a loop or anything. It's a straight cable that is grabbed by the switch mechanism using a spring-loaded clip.
B |
