02-06-2012, 02:07 PM | #1 |
1962 chevy c10 update.
Just finished blasting and painting the rear frame. I used rustoleum rusty metal primer and semi gloss black. I think it came out good. I do recommend this product for cost cutting. The quarts cost $8.00 each and lay down smooth. The truck is coming together slowly. I also cut out the cab corners and finished putting the engine back together. I had three people stop when I was working on it out side. I also received a ticket for storing my bed in the driveway.
02-06-2012, 02:19 PM | #2 |
Re: 1962 chevy c10 update.
lookin good. whyd you get a ticket for having the bed in your driveway? thats bs!!!
Posted via Mobile Device |
02-06-2012, 07:18 PM | #3 |
I know, I live in a new sub division and there is construction everywhere so I didn't think it would matter. So I have to move it into the garage.
02-06-2012, 11:55 PM | #4 |
That's just stupid for the ticket. Nice job
02-07-2012, 02:00 AM | #5 |
60-66 Nut
Your truck is looking good
Are you leaving it mostly stock? I think that is BS getting a ticket for your bed being in the driveway. I am so glad I don't have to worry about things like that around here......not yet anyway.
02-07-2012, 07:36 AM | #6 |
Yes I am planning on stock with little modifications. I will change the wheels and put either a 2 or 3 carb setup on it. I want to do something different than what everybody else does. I wanted to put a v8 and auto but everybody in my area has that. I want to do a 60s theme with a hot strait six. I saw an eposode of gears and he did a strait six with three carbs and it looked kick ass. Thanks for the comments. I moved my bed inside last night so I won't get into trouble.
02-11-2012, 06:58 PM | #7 |
Replaced the right cab corner. The left one I messed up and need to get another. Does anybody know the best way to remove the front cab mount/ floor brace? Mine is rusted thru.
02-25-2012, 08:08 PM | #8 |
Just replaced the right front cab mount. It took longer than expected. It had a bunch of spot welds. Plus it was harder to do upside down. I finally removed and replace it.
02-26-2012, 04:23 PM | #9 |
Wow your resto work looks great!
The motor looks like it is totally back from the dead, and your p-side cab corner looks awesome! Are you doing all this solo, or do you have some help? I am also guessing this is not your first project piece.....
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
02-26-2012, 08:51 PM | #10 |
I am doing all myself. I did a 66 when I was in high school (1988) that I found in a farmer's field. I have been a Army Mechanic for 22 yrs and I have been watching all the how to shows like Gears, Trucks, Muscle ca and Overhaulin. I have been wanting a project for a long time and came across this truck. Thanks for the shout out!
02-26-2012, 09:56 PM | #11 |
Congrats on your 22 years of service!!
I just rolled over 20 years active last August. Keep us in pics on your build, this is the fun stuff !!
02-26-2012, 10:10 PM | #12 |
Same to you! August is when I hit 22.
02-29-2012, 12:51 PM | #13 |
rusty 66
Nice truck
1947 chevy fleetmaster http://www.cbforum.net/forum/ 1966 chevy c10 long bed http://67-72chevytrucks.com/vboard/s...d.php?t=439219 1970 chevy impala custom http://www.layitlow.com/forums/index...pic=349867&hl= |
02-29-2012, 05:50 PM | #14 |
Lookin good! Nice body work on the cab corner!
02-29-2012, 08:48 PM | #15 |
Thanks for the complements. I received the inner fender seals so I am going to replace the inner fenders. If I have time I am going to do the other cab corner. I do not want to get in a hurry because last time I did and I messed it up. I am looking for a good right front fender. I started sanding the front and noticed that it is rusty and dented bad in the front.
03-09-2012, 09:01 PM | #16 |
Did more work today. I replaced the left rocker panel. It wasn't as bad as I thought. The hardest part was stretching the panel to get a good fit. I still have to grinding and fill the seam to make it look better. I also fitted my front fenders. For some reason they are not lining up right.
03-10-2012, 10:58 AM | #17 |
Great work keep it up
03-14-2012, 03:05 PM | #18 |
Your truck build is coming along great! Keep up the great work. Your engine is looking killer now.
C@rnut001 (Owen) Alaskan Members Check In http://67-72chevytrucks.com/vboard/s...22#post5094422 http://67-72chevytrucks.com/vboard/s...18#post6778618 |
03-14-2012, 08:42 PM | #19 |
Did more metal work today. Didn't get to finish because the lower part of the right door is rusted thru. So I have to order a patch to finish it.
03-23-2012, 01:22 AM | #20 |
Subscribed. It's coming along nicely
03-26-2012, 01:01 PM | #21 |
looks great- I'm going to have to replace at least the bottom of my door skin eventually- I'm very nervous even thinking about it - your work looks awesome.
03-31-2012, 09:56 PM | #22 |
Replaced my left side door skin and lower door panel It came out ok but it's a bout 1/4 off. I still have to adjust it a little.
04-01-2012, 04:05 AM | #23 |
Senior Enthusiast
Very impressive progress, your truck is coming along nicely. In my youth I always wanted to build a 6 cylinder engine with a 4 barrel and headers, but it never worked out that way. Triple carbs have always provided a better wow factor though. I wish I had your sheet metal skills. Keep up the good work!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
04-01-2012, 10:56 AM | #24 |
Thanks,
One day I will having look as good as yours. I have been a mechanic in the Army for 22 yrs and just started to get into the body work. While I was in Germany I watched all the how to car shows and learned a little. I wish I were better.This was the first time I did a door skin. It came out ok but it is a 1/4 in off from the left door. How much does the door seal stick out from the sill plate on the bottom? The bottom door is knocked in a little because it was sticking way out. I need to do some more hammering and filling to get the door better. If I didn't have to replace the lower door I think it would have come out better. This is the hardest part of the build so far. Getting the doors right. Last edited by 62 Barnfind; 04-01-2012 at 11:08 AM. |
04-01-2012, 11:15 AM | #25 |
Looking real good keep it up it will pay off in the end
Thread Tools | |
Display Modes | |
