Lowering my 73 gmc 3/4 ton
Dont want to swap it to 1/2 ton. What is the best kit to lower my truck?
Re: Lowering my 73 gmc 3/4 ton
Get ahold of the guys at Western Chassis. In fact I received a E-mail from them today and there having a New Year sale going on. Check them out.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
Depends on how far you wanna drop your truck.
You'll need 1 ton drop spindles, and calipers for the front. I would take the overloads off, and look at a flip kit. Or moving up the hangers. This all depends what you want in the end. Also while at it they have a semi floating 14 bolt that I am fond of. Which is slightly smaller allowing a bigger drop before cutting the bed. |
#4 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=753432
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-30-2017 at 06:10 PM. |
POL makes drop spindes. No need to change brakes. You can weld on a new set of perches.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Like I stated above, Western Chassis makes the correct spindles and springs to properly lower a 3/4 and 1 ton chassis.
I lowered my truck and didn't have to change any brake calipers, brake hoses. Ball joints,ect. It was a nut and bolt swap of parts. Stop making sound so hard to do, the parts are there. There not cheap by any means. I paid $1000.00 for the parts on my truck from Western Chassis. No issue's Lowering a bigger truck isn't done cheap. Ken
I used POLs control arms and cut a coil off the stock springs. For the rear I did a hanger and shackle but I may put some lowering springs from POL on mine. A buddy of mine did the same with Western Chassis stuff with the same results as well. The only thing I found was the 1 ton front hanger had to drill out a hole or two in the frame to work.
#8 | |
I would never use dropped pocket a-arms on a GM truck.
