Old 08-09-2014, 07:14 PM   #1
tinydb84
tinydb84's Avatar
Used Parts Build
I have been meaning to start a build thread over here. I have one on the other forum so some might be familiar with it already. My goal is to build it with the most used and cheap parts as possible.
When I got her:
[/QUOTE]
David
Instagram: myfabguy
Old 08-09-2014, 07:15 PM   #2
tinydb84
tinydb84's Avatar
Re: Used Parts Build
First problem:
So I just started ripping it all apart:
Surprisingly when I ripped out all the old wires that were twisted together it fixed the problem....
David
Instagram: myfabguy
Old 08-09-2014, 07:25 PM   #3
tinydb84
tinydb84's Avatar
So my brother had this lying around:
It was free so
And done! The horn button doesnt fit with the o-ring they give you. I used a strip of tape instead of the ring and it fits great.
David
Instagram: myfabguy
Old 08-09-2014, 07:26 PM   #4
tinydb84
tinydb84's Avatar
I tore out my old exhaust
New Headers (with some room made)
And installed!
Knock off single chamber flows...
David
Instagram: myfabguy
Old 08-09-2014, 07:27 PM   #5
tinydb84
tinydb84's Avatar
I found on Jakes Transmissions that you could modify the valve body to firm up the shifts without a shift kit so I gave it a shot (I did post about this in a different subsection).
First was to remove the spring from here
Then enlarge these holes
Here we go
Then plug this hole
Tap and set screw for a dollar or two
Tapped
Plugged
David
Instagram: myfabguy
Old 08-09-2014, 07:27 PM   #6
tinydb84
tinydb84's Avatar
Was going through my phone and found a pic of a truck that was being sold on here that I passed up (still thinking I should have bought it)
David
Instagram: myfabguy
Old 08-09-2014, 07:28 PM   #7
tinydb84
tinydb84's Avatar
So I bought this:
Then changed my mind...
And I traded it for cash and this:
David
Instagram: myfabguy
Old 08-09-2014, 07:29 PM   #8
tinydb84
tinydb84's Avatar
Started working on the rear.
David
Instagram: myfabguy
Old 08-09-2014, 07:30 PM   #9
tinydb84
tinydb84's Avatar
Damn that is a lot of springs!!
Lets fix that
Tada!
The drivers side was easy
Damn gas tank...
And some Por15
David
Instagram: myfabguy
Old 08-09-2014, 07:31 PM   #10
tinydb84
tinydb84's Avatar
Got some more of the hard work done
Bushings in
Shackles
Hangers and notch
David
Instagram: myfabguy
Old 08-09-2014, 07:31 PM   #11
tinydb84
tinydb84's Avatar
The brown truck stopped by...
David
Instagram: myfabguy
Old 08-09-2014, 07:32 PM   #12
tinydb84
tinydb84's Avatar
Around this time I saw a truck on here that a guy was talking about selling....and I bought it:
David
Instagram: myfabguy
Old 08-09-2014, 07:33 PM   #13
tinydb84
tinydb84's Avatar
Finally back together!!
Sold the engine and trans for $500
David
Instagram: myfabguy
Old 08-09-2014, 07:34 PM   #14
tinydb84
tinydb84's Avatar
Parts!
Every lug was stripped...
Slow progress
David
Instagram: myfabguy
Old 08-09-2014, 07:35 PM   #15
tinydb84
tinydb84's Avatar
Then I decided to bag the truck...cant leave well enough alone...
Drilling holes is a *****
Mocking up
I know it looks too far forward but the bag sits forward in the arm (I put it all together to check first
David
Instagram: myfabguy
Old 08-09-2014, 07:36 PM   #16
tinydb84
tinydb84's Avatar
hours of cutting, grinding, and wire brushing, then lit myself on fire lol
Narrowed them 7/8'' of an inch and moved the ball joint to the front to increase caster
David
Instagram: myfabguy
Old 08-09-2014, 07:37 PM   #17
tinydb84
tinydb84's Avatar
Not C10 but used parts for my 350z! New rear end with 10% lower gears and test pipes.
David
Instagram: myfabguy
Old 08-09-2014, 07:37 PM   #18
tinydb84
tinydb84's Avatar
Holy **** it took forever to clean and paint everything...so long I am still doing it. Ugh. Here are some pics for now.
Got the crossmember out
Cleaning
Tacked in new studs
Painting some parts:
I only painted enough of the frame rails for the crossmember to bolt to for now.
David
Instagram: myfabguy
Old 08-09-2014, 07:39 PM   #19
tinydb84
tinydb84's Avatar
Starting to get some stuff together
David
Instagram: myfabguy
Old 08-09-2014, 07:40 PM   #20
tinydb84
tinydb84's Avatar
I decided to Z it. Annnnndddddddddddd....decided to d it myself. So I bought a new welder and got to practicing
New welder!
First beads in a few years
Vertical uphill
Cut apart and acid etch (only had ospho so the etch isnt that prominent)
David
Instagram: myfabguy
Old 08-09-2014, 07:41 PM   #21
tinydb84
tinydb84's Avatar
Found a pic of a bike I built years ago:
Anyway...I started sectioning a crossmember before I decided I was going to Z my truck. I worked on it a bit tonight. Figure I'll sell it and use the money towards the truck when I am done.
Laying out the lines:
One side:
And the other:
Apart!
Just resting together:
I still need to grind a bunch and work on the fitting. I figure I'd cut the lip off the front and weld it in together just for extra clearance. I am only going 1.25 on it so it shouldn't hit the steering.
David
Instagram: myfabguy
Old 08-09-2014, 07:41 PM   #22
tinydb84
tinydb84's Avatar
Didnt get a pic of final welds. Still need to cut out some filler plates for the sides
Finished the crossmember and did a quick coat of primer
David
Instagram: myfabguy
Old 08-09-2014, 07:42 PM   #23
tinydb84
tinydb84's Avatar
When I made the decision to Z it I figured why not do a SFBD...ugh. Need to stop this whole lowering thing...
Started working on my stock floor body drop.
Got a piece of steel on sale for cheap. 3x4x1/4 it was a bit too thick but half price:
Pulled my trans crossmember:
Split the tube in half:
Fit it in the frame:
David
Instagram: myfabguy
Old 08-09-2014, 07:43 PM   #24
tinydb84
tinydb84's Avatar
Found a good deal on a 4l80e so I went and picked it up:
And found a deal on some used rims and tires for my 350Z:
Then went out and replaced my shocks and put lowering springs on my Z:
Then washed her:
And did a little bit of drilling on the steel I am boxing my frame with:
David
Instagram: myfabguy
Old 08-09-2014, 07:44 PM   #25
tinydb84
tinydb84's Avatar
I finished cleaning the inside of my frame (forgot to take pics) and decided to firm up my motor mounts (just wanted to weld ****):
Inside view:
Done!
David
Instagram: myfabguy
