03-15-2018, 12:31 AM | #1 |
Wheel Adapters anyone using them?
I have an 86 GMC short bed and I am thinking I would like to go to a new style 6 lug wheel which would require the use of a wheel adapter. Any problem in using them? Would like to hear from those that might be using them or thoughts about them! Thanks
03-19-2018, 01:24 AM | #2 |
Diggin The SquareLife
Re: Wheel Adapters anyone using them?
do not use wheel adapters.....they can break and push the wheels out to far
03-19-2018, 10:16 AM | #3 |
I used some on a 8 lug square I had a while back. Used later model 8 lug aluminum wheels, never had an issue. Torque them down correctly and use loc-tite on the threads, and you're golden. On that note, I would never use them on anything bigger than a stock tire height, too much stress on that small of an area.
03-19-2018, 10:44 AM | #4 |
Thanks for replying! I was thinking going from a 15 to maybe an 18". Think that is to big a jump? Just doing some thinking right now, have not bought any adapters.
03-19-2018, 11:12 AM | #5 |
67-72 parts collector,…
If you are adapting a 5-lug truck to 6-lug I highly suggest you don't.
Those are some scarey adapters that bolt together. Use aftermarket 6-lug rotors and new rear axles. Just be warned that most 6-lug wheels are for the 99- up silverados that have a smaller hub bore than your truck. Most 6-lug wheels used on pre-99 trucks are custom built. (unless you are talking 4x4 wheels) Not enough info to know what you are doing,...
