10-02-2018, 01:38 AM | #1 |
67 door screws
I have just purchased a 1967 Chevy C10 and need to remove the steel door panels. Some of the screws are stuck and some of them just spin as if the nut on the door shell is no longer attached. Any suggestions on removal and repair/replacement.
10-02-2018, 07:36 AM | #2 |
Re: 67 door screws
Unfortunately you have to drill the ones that spin. The nuts on the inside of the door are lightly welded in place. Spray them and work them back and forth slow. Find these cage nuts local or order online and use antiseize on the new ones.
10-02-2018, 09:41 AM | #3 |
Re: 67 door screws
X2 on what 68panelman said. I just had to do EXACTLY that to some of my own 67 GMC door screws. I used PB blaster on it, then I used a small vise grip to clamp the largest screw piece on the inside of the door, turned it counter clockwise, and removed it that way. There was not enough of the drilled screw on the outside to get any good grip.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
10-02-2018, 10:13 PM | #4 |
The Older Generation
Re: 67 door screws
Classic parts has the correct screws for the panels and upper trim. https://www.classicparts.com/1967-71...ctinfo/19-429/ If you have an ACE hardware close to you they may have what you need..... LockDoc
10-04-2018, 09:56 AM | #5 |
Re: 67 door screws
Thank you all for the information.
10-05-2018, 12:30 PM | #6 | |
Re: 67 door screws
