07-01-2019, 03:04 PM | #1 |
Moderator
200R4 Trans Setup
Some interesting reading and pics if your planning on using a 200R4 - https://www.1952chevytruck.com/stree...cable.htm#dent
07-02-2019, 02:44 PM | #2 |
Re: 200R4 Trans Setup
Interesting read. I went thru this last year installing my 2004r in my stock 70 C20. I have a 350 with the stock quadrajet. After reading many articles about how to set up the TV cable, I took a stab at it. I did get a pressure gauge and used Bowtie overdrives recommendations. Worked just fine for me. I think the biggest thing is to make sure the connection is the correct distance from the pivot on the carb linkage. I also used the factory TV cable that was adjustable for the year the trans was built. Been a year now and a few thousand miles with no issues.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
07-02-2019, 03:11 PM | #3 |
Moderator
I wonder if the Lokar bracket for that carb is indeed correct then, as far as distance.
