Old 09-16-2020, 09:29 PM   #1
rustytruck50
rustytruck50's Avatar
2005 Sierra 2wd LH side lean correction & lowering
My Sierra has the much discussed LH lean that I want to correct. I also want to lower the truck. What would happen if I just put new drop coils in? Would this correct the lean or just lower the lean?
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 09-16-2020, 10:35 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 2005 Sierra 2wd LH side lean correction & lowering
The lean will still be there.
I either trim the “high side” or add a Belltech spring spacer under the “low side” front spring.
Keith
Convert to disc brakes.
Old 09-16-2020, 11:11 PM   #3
rustytruck50
Thanks Keith....I thought a bit about trimming the higher side. What would be a reasonable amount to cut off? Half coil at a time? Is the reason it would still lean because of the rear spring pulling it down?
-Doug
'05 RCSB Sierra 2WD
Old 09-17-2020, 12:47 AM   #4
lolife99
lolife99's Avatar
I’m not sure what causes the lean. Fuel tank on one side? I don’t known
Be conservative on your cutting and sneak up on it.
1/2 COIL = 1” of drop.
Keith
Old 09-17-2020, 07:20 AM   #5
Since I had a small floor jack, some chains and tools in my truck under the tonneau cover I made a little box to hold it on to the passenger side of the bed near tailgate and it leveled my truck out.
I have heard so many stories why there is lean like the gas tank & driver weight. I do know on my 02, the spacers they added from factory for quietness and the lean, deteriorated and made the lean worse.
A friend of mine swapped his leaf springs around when he lowered his and it seemed to help get rid of it. Personally, I think the leafs are more of the issue that the front coils, but the front coils are easier for most folks to tinker with..
Palf70Step is online now   Reply With Quote
Old 09-17-2020, 07:23 AM   #6
rustytruck50
Pretty sure its the tank. My thought was that maybe since the springs on that side have both sagged a bit that if something was done first, the softer rear spring was the cause of it still leaning. I agree with the conservative approach...made that mistake years ago on a '83 Cutlass...thought I knew what was what & could not have been more incorrect :eyeroll:...thank goodness for the internet!
-Doug
'05 RCSB Sierra 2WD
Old 09-17-2020, 09:42 PM   #7
rustytruck50
I watched a really good video on YouTube on a green '02 Sierra and he swapped the leaf packs & said it did the trick. Are the spacers you mentioned, on the lower arms? I guess I thought those were just insulators...might check & see if I can find a replacement. I'll hafta click a couple of pics of my goofy looking caster issues I'm hoping to iron out during this fix.Thanks for the info!
-Doug
'05 RCSB Sierra 2WD
Old 09-18-2020, 06:03 AM   #8
I think they (at least mine were) on the top of the spring. They may have both, but the drivers side top is what deteriorated on my 02.
Old 09-18-2020, 08:14 AM   #9
hatzie
Moderator
hatzie's Avatar
A good spring shop can re-arch leaf springs.
Swapping LH & RH springs is fairly easy as well.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 10-03-2020, 11:56 AM   #10
rustytruck50
I think I'll give the springs a swap and see what happens....I did get a new spring insulator off of ebay the other day...thanks for the insights & I'll make sure to keep you updated
-Doug
'05 RCSB Sierra 2WD
