04-05-2020, 08:11 PM | #1 |
Aftermarket small cap HEI.
I have a 283 from a 64 c10. (Currently in 51 GMC)
I acquired an old edelbrock intake. A 1406 carb a pair of valve covers. Those came with 2 new ish. Aftermarket small cap distributors. Look identical. The part number is Jm6701r. Google tells me nothing. The cap uses different wires than my points dis. Is it worth installing? I do NOT want a mad box. I do Not think there is firewall room for an original large cap hei. What coil? My current coil is new 12v no ballast resistor required. The ug wires are different.. What thoughts or prayers would you suggest? Last edited by Marty68; 04-05-2020 at 08:24 PM. Reason: Adding pictures |
04-05-2020, 09:00 PM | #2 | ||
"I ain't nobody, dork."
Re: Aftermarket small cap HEI.
This is what the part number brought up when I typed it into Google.
https://www.amazon.com/Top-Street-Pe.../dp/B006CUBFOC Typical 70 dollar made in China distributor. Gary
04-06-2020, 10:38 AM | #3 |
Would either be better than stock points?
04-06-2020, 11:52 AM | #4 |
I don't know about the quality of that particular distributor, but HEI is a huge upgrade over points systems in general. I found several different vendors with that part number on Amazon, but all told there are only four reviews; three are 5-star and one is 1-star.
I would say try it, what do you have to lose, but since it requires different wires...
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
04-06-2020, 12:49 PM | #5 |
I dropped it in ran the plug wires went to put coil wire on.... different ends. I found an msd wire with adapter on amazon... $20 but wont be here until Apr 20... so tonight will be clear coating intake. tomorrow assembling intake with point dist and new points. I have a 1405 and 2406 600 cfm edyelbrock the 140t ids cleaner looking which should I use?
I hove no reason to believe this engine is not "stock 1964"" Last edited by Marty68; 04-06-2020 at 02:04 PM. |
04-06-2020, 03:51 PM | #6 |
Moderator
This guy can probably sell you a different cap that will work with what you have wire wise - https://swapmeetparts.com/contact/
Also Blueprint Engines sells them (caps for small HEI).
04-06-2020, 04:38 PM | #7 |
Thank you rocknrod
04-11-2020, 11:22 AM | #8 | |
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. |
04-12-2020, 10:40 AM | #9 |
I had old dist out. Set points to .017.
Adjusted timing. Played with throttle to give full range of motion. This thing runs AMAZING.. Likely not using aftermarket dist. Trading accuired 600cfr. Edelbrock for 500. I will install intake carb likely next weekend. At that time I wiss lset up another set of points to carry as a spare.. while looking for good used gm hei.... or not lol Thanks for helping a youn old guy figure things out. |
