10-26-2020, 07:08 PM | #1 |
What is this "connector" actually called?
Anyone know what this is called and where to buy one? Thanks.
10-26-2020, 09:17 PM | #2 |
Re: What is this "connector" actually called?
GM 12191376 Battery Positive Cable Junction Block. Looks pretty nifty. For recent model years. You can google for it and find a bunch of different sources to buy from. https://www.google.com/search?q=GM+1...junction+block
I don't know about a source for the weird L-shaped terminal that crimps onto the cable. Last edited by dmjlambert; 10-26-2020 at 09:19 PM. Reason: clarify |
10-26-2020, 11:27 PM | #3 |
https://www.amazon.com/Genuine-GM-12.../dp/B000QIQUE6
https://www.ebay.com/itm/25363518264...gaApXiEALw_wcB Doesn't come with the connector. looks to be some kind of "flag terminal" , Maybe it has a GM part number and could be sourced from the stealership? Standard flag terminal looks like it would probably work fine.
Insert clever text here: Last edited by Greasey Harley; 10-26-2020 at 11:33 PM. |
10-27-2020, 08:32 AM | #4 |
[QUOTE=dmjlambert;
I don't know about a source for the weird L-shaped terminal that crimps onto the cable.[/QUOTE] Thanks, but that L shaped terminal is the part I need, not the box. I am just looking to join the wire from the alternator to the positive battery cable for my LS swap. I will look into the flag terminal that Greasey Harley mentioned. Thanks. |
10-27-2020, 09:36 AM | #5 |
Old member
Why not use this. It looks pretty close to the same thing just run them straigt out.
https://www.summitracing.com/parts/c...kaAlFjEALw_wcB https://www.summitracing.com/parts/s...gaAlkrEALw_wcB
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-28-2020, 01:15 AM | #6 | |
If you can’t find the flag terminal, I have an extra cable with the fitting you need that needs a new end crimped on... you can have it if you’d like it.
1965 c/10 swb 1969 c/10 lwb |
10-28-2020, 08:44 AM | #7 | |
Thanks for your reply! |
10-28-2020, 12:41 PM | #8 | |
11-26-2020, 07:29 PM | #9 |
BMW & ASE Master Certified
https://ceautoelectricsupply.com/ind...style-eyelets/
unfortunately shows out of stock... but maybe more searching using some of those key words will help you find it
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
