11-26-2021, 12:36 PM | #1 |
Power steering upgrade
Good morning all, I am going to install power steering on my 1965 C10. I'll retain the stock suspension and ride height, has a regular small block 350. it will be a daily driver. I am looking for a company that sells a complete power steering kit with everything I need for the conversion. Also I see there are 2 different steering boxes, standard ratio 16-1 and a quick ratio 14-1. Anyone with experience on this? Thanks for any help, hope everyone had a great Thanksgiving.
Hairball |
11-26-2021, 01:06 PM | #2 |
Re: Power steering upgrade
I'm not into kits. If you do a little research on this forum you can find a list of parts to gather up. Everyone uses parts from square body era trucks and adapters from Captain Fab.
11-26-2021, 02:09 PM | #3 |
Like Big Moe, not sure on kits, Capt Fab does fantastic adapter, enough information on this site to see you through the process
Ratio…I use the 14:1 with power steering, but thats my choice…. |
11-26-2021, 02:17 PM | #4 |
Moderator
Performance Online might, I know CPP does.
11-30-2021, 12:45 AM | #5 |
I believe many kits are out there ,POL Ecklers, and CPP sell them.
You can piece together what you need from your local parts house for less money. I used all 1972 C10 parts, pump, hose, steering coupler and gear. As mentioned Capt. Fab sells a top notch adapter to mount the gearbox to your frame, and may even be able to supply you a parts list of what you will need . Whatever route you decide to take you will only regret not adding it sooner. Good luck and keep us posted
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
11-30-2021, 07:25 AM | #6 | |
Moderator
12-08-2021, 03:50 PM | #7 |
I upgraded last year with a kit from POL. Works great. I went with quick ratio and I think I should have gone with the standard. The quick ratio is a little twitchy. You will end up with old timey 1 finger steering that doesn’t lend itself to a quick ratio.
12-08-2021, 06:25 PM | #8 |
Thanks Pitpig, I have been looking at the CPP power steering conversion kit for my 65 C10 and was thinking about the quicker 14-1 ratio. I may have to reconsider now and think about the 16-1 standard ratio. My truck has the original front suspension and stock ride height. Maybe I can get some more input on the two choices from other members.
12-08-2021, 06:52 PM | #9 |
needs more caster in the front end with power steering. Have a good friend not far from you in Dolores.
1961 chevy K10 my build is------------61K10 build |
12-08-2021, 07:32 PM | #10 |
I went with the quicker box and I like it. My truck also has stock springs (re-pops) and I added a squarebody sway bar with poly bushings. I do a lot of all around driving and I also enjoy some twisty mountain roads and I think it works fine.
