Old 11-30-2020, 11:31 PM   #1
Kootenay64
Kootenay64's Avatar
Original bed wood??
Disassembled the bed wood for a full freshen up of paint to the wood and metal strips to restore to like original color, appears to be original bed wood in fair condition.
Looks to be painted on the bottom side of the bed wood, anyone know if this underside paint would be original build?
Anyone had experience refurbishing this original wood? Any tips?
I know there are plenty of new wood kits out there, my goal is to refinish the boards and paint semi gloss black for ‘factory’ look.
Thanks for advice.
The doctor said I wouldn’t get so many nose bleeds if I kept my finger outta there,” - Ralph Wiggum
Kootenay64 is offline   Reply With Quote
Old 12-01-2020, 02:17 AM   #2
oem4me
Re: Original bed wood??
Yes, that does appear like it may be original. It would have been black, all sides. Perhaps the wood was stripped or sanded clean for a clear finish at some point, same time the red was added to the strips?
Old 12-01-2020, 02:22 PM   #3
jayoldschool
Moderator
Don't think those strips are original, they didn't have square holes.
jayoldschool is offline   Reply With Quote
Old 12-01-2020, 03:36 PM   #4
nsb29
nsb29's Avatar
I’m not saying you’re wrong but I think you’re mistaken
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 12-01-2020, 04:41 PM   #5
Mack B
Mack B's Avatar
If referencing jayoldschool he is correct. See pic.
I’m no expert, but looking at the two rear corner pieces in the first pic, did those pieces have the groove that’s on the edge that goes under the bedside from the factory as these appear? Also one bolt hole appears to not be in a factory place on one of them. Looks like it had a bolt through to the rear cross sill?Again this stuff is just fresh on my mind I’m no expert.
Mack B is offline   Reply With Quote
Old 12-01-2020, 08:21 PM   #6
nsb29
nsb29's Avatar
My 65 had the oem strips the square holes are so the bolts won’t turn I fought every single one because the square holes were partially rusted as well as the bolt letting them turn
Old 12-01-2020, 08:42 PM   #7
jayoldschool
Moderator
It's well documented on this forum: the original strips have round holes and use ribbed shank carriage head bolts. Not square holes. Square holes: aftermarket strips.
Old 12-02-2020, 12:01 AM   #8
oem4me
Good eye! It pays to look closely.
Old 12-02-2020, 04:14 PM   #9
Kootenay64
Kootenay64's Avatar
Ya I know the strips are not original, they're in WAY too good of shape. Planning to have them sandblasted and painted same color black as the original bed would have been.
Pretty happy that the wood is in decent shape and reusable for being fifty five plus years old. Will plane off a thin bit of material off the top, sand and refinish, at least that's the plan optimistically.
If anyone has any insights I'm all ears!
Thanks for all your input and any tips.
Old 12-02-2020, 07:53 PM   #10
cwcarpenter98
cwcarpenter98's Avatar
If it's original wood, you might be able to find a date stamp on one of the planks on the top side. After all this time, it might have been sanded off though
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 12-02-2020, 08:25 PM   #11
nsb29
nsb29's Avatar
Well I guess I learned something new all of mine spun and with the Rust I assumed they were square originally like the new ones
Old 12-02-2020, 09:22 PM   #12
jayoldschool
Moderator
Yep, I uninstalled my originals with a sawzall and a grinder. No wrenches!
Old 12-03-2020, 12:39 AM   #13
Killer Bee
Killer Bee's Avatar
earned every one of them - kept a small piece of souvenir factory wood
Old 12-03-2020, 10:37 AM   #14
LT1 Burb
LT1 Burb's Avatar
That almost looks like OAK to me, bed wood was yellow pine, if it is original the 3rd or 4th piece, near the cab, will have a date stamp on it.
LT1 Burb is offline   Reply With Quote
Old 12-04-2020, 04:59 PM   #15
Afirehawk1
So southern yellow pine is correct on the bed?
Kind of paint or stain was applied?
Afirehawk1 is offline   Reply With Quote
Old 12-05-2020, 09:16 AM   #16
factorystock
factorystock's Avatar
What Chevy said it was.
factorystock is offline   Reply With Quote
Old 12-05-2020, 09:42 AM   #17
The Rocknrod
Moderator
The Rocknrod's Avatar
More adds and info: http://67-72chevytrucks.com/vboard/s...d.php?t=484080
Old 12-05-2020, 12:10 PM   #18
Killer Bee
Killer Bee's Avatar
Originally Posted by The Rocknrod View Post
I had not seen that until now, thank you for posting!
got three wood beds, one down, two to go..
pine kit and same finish materials on hand for red '71 longhorn WFL - work order status code for waiting for labor
Dad's '65 C20 planning to go OE all the way
Old 12-05-2020, 12:35 PM   #19
Afirehawk1
Cool thanks
