02-28-2013, 08:40 PM | #1 |
Project Whitey II - the "I wish I'd never sold it" build
The picture in my avatar is an '87 I had a few years back. I bought it from the original owner with 62K original miles and it was like new. I did a 4.5/5.5 static drop and drove it. One day I made the mistake of selling it. Ever since I've wished I had it back.
Fast forward to about a year ago. I was looking on craigslist and she jumped right out at me. The story was the guy I talked to bought the truck new in Texas and drove it for several years. His dad liked the truck. He sold it to his dad here in North Carolina back in the mid 90's. His dad had recently passed and he was helping him mom settle his estate. They decided not to keep the truck. Lucky me! After a few minutes of haggling she was on the road headed to my house!
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
02-28-2013, 08:41 PM | #2 |
Re: Project Whitey II - the "I wish I'd never sold it" build
Meant to put this under projects and builds. Moderator, please move this. Thanks!
02-28-2013, 08:43 PM | #3 |
I didn't waste any time buying her new shoes. They are Boss 338 with Nitto 555's.
02-28-2013, 08:45 PM | #4 |
Next was the chore of getting her attitude right. First picture is of rear flip done. Second is with the new spindles and springs done in the front, along with the suspension rebuilt. New steering components also.
02-28-2013, 08:53 PM | #5 |
67-72 parts collector,…
Looks great!
02-28-2013, 08:57 PM | #6 |
Next on the docket was new power. I decided on a late modle LS series engine with 4l60e trans. Found an all aluminum L33 and trans on Ebay. The seller had a lot of good feedback. I put the purchase and it was on it's way. Got here, started pulling it apart for clean up and something told me I needed to try to spin it over. Hooked up a hot battery and remote start switch........ BANG 1/4 of a turn and locked up tight as a drum. Started pulling plugs out. You'll see below what I found - RUST and water! They came and picked up the engine and provided a full refund. I was BUMMED!
02-28-2013, 08:59 PM | #7 |
Nice truck! What inch drop is that in front? Anything other than the flip done in the back?
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
02-28-2013, 09:03 PM | #8 |
So I decided to do something I was a little more comfortable with. So started the Stealth Ram injected 383. It started with a late model 4 bolt main block. Bought a nice balanced rotating assembly and LT4 hot cam. Next came a set of Bowtie vortec heads. Then I got a stealth ram and did quite a bit of porting to it, and a BBK throttle body. New 30lb injectors should work nicely.
02-28-2013, 09:05 PM | #9 |
Got the motor together and it was time to get it in the truck. I used a L98 camaro serpentine setup.
02-28-2013, 09:08 PM | #10 |
Next I had to supply fuel. I installed a blazer tank in the rear with internal pump.
02-28-2013, 09:11 PM | #11 |
Got it running, and then it was time to get ready for paint.
02-28-2013, 09:13 PM | #12 |
I debated long and hard about a color change. I just couldn't do it. Had to be white. Finally back from paint 3 months later! Had to see what she looked like with the wheels back on.
02-28-2013, 09:15 PM | #13 |
Got the grill, front markers, wheel molding, and cab molding back on. As she sits tonight.
02-28-2013, 09:19 PM | #14 |
Thanks. Yes just the flip in the back and 2.5 spindles with 2 inch springs in the front.
02-28-2013, 09:36 PM | #15 |
I know the pieces fit
Glad to see you're still building cool squares.
02-28-2013, 09:38 PM | #16 |
It followed me home?
Nice truck!! any pictures of what you did the the gas filler?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
02-28-2013, 09:43 PM | #17 |
You know me....I can't be without one for long. Found a '78 SWB with factory 454 and loaded out. Trying hard to talk myself in to buying it. If this one was done it would already be home!
02-28-2013, 09:45 PM | #18 |
what brand springs/spindles did you go with?
02-28-2013, 09:45 PM | #19 |
I'll get you a picture of it tomorrow.
02-28-2013, 10:16 PM | #20 |
I like the cut of yer' jib! This is my current DD. I used a picture of your old truck, lowered to photoshop some wheels.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
03-03-2013, 09:57 AM | #21 |
They are McGaughy's (spelling?).
03-03-2013, 10:02 AM | #22 |
I bought an aluminum fuel filler door from Jegs. I cut the hole and brought the lower ribs up to meet the high ones for a level surface. I had to trim one of the lower cross braces to clear the sending unit in the tank. Other than that it was all pretty easy. Here are a couple of pics.
03-03-2013, 10:05 AM | #23 |
Thanks. Your truck looks really clean! I like it!
03-03-2013, 11:05 AM | #24 |
Beautiful truck!
03-03-2013, 11:50 AM | #25 |
Cool looking project...keep the pictures coming!
