01-02-2014, 01:05 AM | #1 |
72 c30 swap questions
Brake rotors for this c30 I have seem impossible to find and would guess pricey. Since it is a project, could I swap the suspension for say, 73 and up suspension/brakes as bolt on? Its a dually, and the rotors are the ginormous ridiculous mountain versions.
01-02-2014, 01:44 AM | #2 |
Re: 72 c30 swap questions
I pulled a whole front suspension out of a 73+ truck for my 71 for which rotors are NLA. For a 71 you can replace the spindle-out or the whole front end.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
01-02-2014, 01:46 AM | #3 |
73 1 ton over to your 71 1 ton? Any mods?
01-02-2014, 01:55 AM | #4 |
I have not done it yet, but I did research here on the forum. To swap the crossmember-out you have to drill several more holes in the frame. To replace the spindles out you just swap the spindles, rotors, calipers. I dont think I remember anything about changing ball joints. Several forum members have done it. I am going to rebuild and paint the whole assy and also swap in a 14 bolt to get rid of the 4.56s. 73+ came with a sway bar as well.
01-02-2014, 01:59 AM | #5 |
Just going to ask you about the rear differential swap as well. I'm leaning at this point to either go with the 1 ton swap or cut the frame and swap over to 1/2. I have an retired California Conservation utility vehicle. I will post pictures tomorrow.
01-02-2014, 09:34 AM | #6 |
Sure you have to swap spindles? I have a 72 C2500 that I did some research on a while back, and I thought that all the bearings were the same. I also thought the rotors were the same 3/4 and 1 ton srw from 72 up. Will have to revisit this. Just checked Rockauto and they describe that the srw rotors fit from 72 to 89. I would believe that the drw rotors would swap too
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
01-02-2014, 11:13 AM | #7 | |
The Older Generation
I'm headed out to the shop so I don't have time to look anything up for you but if you type the words "C-30 brake upgrade" into the GOOGLE search box at the top of this page, click on the circle in front of "67-72chevytrucks.com and click on the GOOGLE button you will find lots of threads on the subject. Here is one of the most comprehensive ones: http://67-72chevytrucks.com/vboard/s...d.php?t=367260 It is not C-30 specific but there is a lot of good info in it. It is on the '60-'66 board but would also cover the later trucks as the frame is basically the same... LockDoc
01-02-2014, 04:46 PM | #8 |
Here are the pictures I mentioned that I would post. This is a 72 c30 4 speed granny low, with a non stock 327 circa 67. It is a retired California Conservation Corp utility truck turned work truck. The original red paint it came with is still in the interior and in places, exterior.
01-02-2014, 04:49 PM | #9 | |
01-02-2014, 08:29 PM | #10 |
NAPA shows the same p/n s for wheel brgs, calipers, ball joints, lower control arms 72-78 C30.
Upper control arms show different p/n s. Rotors 73+ are 1 piece hub and rotor 1.54" thick. My 71s are 1 piece hub and rotor around 1.5 without pulling a wheel. My Chevy parts book shows the same spindles C20&30 71-72 but the front brake page is missing. I dont know why this has to be so difficult and why the parts houses show NLA. I guess I will throw a 78 rotor on my 71 and see if everything lines up. Unkle Matt never did say how his setup worked, or what he used. I do know that forum members have put late 70s spindles-out on drum brake trucks.
01-03-2014, 12:59 PM | #11 |
Is this common for c30 front suspension with the extra leaf spring supporting the lower a arms?
01-03-2014, 01:11 PM | #12 |
I thought it sat a lot higher in the front than my low rider.
First I have seen one of those.
01-03-2014, 01:49 PM | #13 |
01-03-2014, 02:22 PM | #14 |
I lightened the picture up a little and rotated it so it is easier to see... That is some heavy duty springs for sure. Any chance you could post a picture of the sticker from the inside of the glove box door? Does it list any heavy duty springs as an option? LockDoc
01-03-2014, 05:17 PM | #15 | |
Originally a dual battery, dual alternator vehicle. Note the massive wiring sent to the utility bed in back of the brake booster, from firewall. |
