Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-19-2016, 01:14 AM   #1
MIKE77z
MIKE77z's Avatar
1969 Blazer 4x4 project
Been fighting with my android that doesn't want to upload to the forum and mac that seems to hate me since i don't have a iphone but here goes nothing... again
1969 Blazer supposedly a Texas truck i will guess it was a at one time but it sure saw some salt from the body rust after blasting. Was a 350 350 205 now to be a Ramjet 350 700r4 205
On to the pictures
I'll add more tomorrow if this works , That was December 10 th if i recall.
Mike
MIKE77z is offline   Reply With Quote
Old 05-19-2016, 07:18 AM   #2
jaros44sr
jaros44sr's Avatar
Re: 1969 Blazer 4x4 project
Looks like you made it to the best forums around and welcome. Good start, and what I wouldn't give for a lift, but for now a creeper works with a 4" lift on the truck
Mike careful with that trouble light, I have read of them causing fires
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-19-2016, 12:06 PM   #3
MIKE77z
MIKE77z's Avatar
Yeah they are junk thanks for thr concern, burnt forearms to prove it. I use it when the batteries die on my snap on light. It at least has a led bulb in it now.
More progress pics tonight. It's actually coming back together fairly well.
Mike
Old 05-19-2016, 09:56 PM   #4
MIKE77z
MIKE77z's Avatar
A few more of the disassembly
Old 05-19-2016, 10:04 PM   #5
MIKE77z
MIKE77z's Avatar
Blasting time.... It had a wee bit of cancer
Old 05-19-2016, 10:11 PM   #6
MIKE77z
MIKE77z's Avatar
And a few more holes.... She's a wee bit rough
Old 05-19-2016, 10:27 PM   #7
MIKE77z
MIKE77z's Avatar
And the metal work begins . Inner outer rockers drivers rocker box and reinforcement Both floor pans rocker braces a pilars windshield frame ect ect
Old 05-19-2016, 10:36 PM   #8
MIKE77z
MIKE77z's Avatar
Easter sunday with the truck. Weather tunred nice figured it was time to get the rest of it blasted. Then a few coats of bedliner on the underside.
Old 05-19-2016, 10:49 PM   #9
MIKE77z
MIKE77z's Avatar
Thanks to some ideas from 29od1's guide on the 08 up SUV seats I decided to take it a little farther 6 way power drivers seat using power tracks from a 2007 Grand Prix took some work but results were good. Interior all coated in Lizard skin sound and heat coatings.
Old 05-19-2016, 10:59 PM   #10
MIKE77z
MIKE77z's Avatar
The frame was next... What a nightmare... previous accident damage and BRUTAL repair welidng the steering box to the frame and about 20 lbs of random metal in the drivers rail to supposedly reinforce it. Found a donor 6cyl clip ( well actually came with the truck i wont take too much credit here ) Used some of it to repair both front rails and Diamond plated inside the rail to reinforce.
Old 06-06-2016, 12:46 PM   #11
MIKE77z
MIKE77z's Avatar
Little more progress
Powertrain and brake lines installed, Disk Brakes and front diff rebuilt
Old 06-06-2016, 12:58 PM   #12
MIKE77z
MIKE77z's Avatar
Removed the powertrain and reboxed it all. Off to the body shop.. Dropped it off last week. Now the search starts for headers,rad, ac parts interior on and on it goes.
Ill keep you guys updated as the reconstruction starts.
Mike
Old 06-06-2016, 02:43 PM   #13
1rippen6
I have a set of headers I pulled off a 72 blazer can send pictures if interested.
1rippen6 is offline   Reply With Quote
Old 06-06-2016, 03:54 PM   #14
MIKE77z
MIKE77z's Avatar
Sure i'd take a gander if you don't mind. I had a set laying around but they got into the front driveshaft which is another challenge with the 700r4 and not using the spacer.
Thanks Mike
Old 06-06-2016, 08:51 PM   #15
tjsblazer
tjsblazer's Avatar
Wow another great build. Welcome from another Canuck. I'm about 5 hours west of Ottawa in Waterloo region. You aren't wasting any time there. Great progress.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 06-07-2016, 07:22 AM   #16
1rippen6
Here's what I have the blazer had a 350-205 setup. I don't know if they will work with the 700r4 setup.
http://67-72chevytrucks.com/vboard/s...hlight=headers
Old 07-22-2016, 11:26 AM   #17
13jraven
13jraven's Avatar
Just need a spacer to bolt up the 700r4 in place of the TH350.
http://offroaddesign.com/catalog/700r4spacer.htm
13jraven is offline   Reply With Quote
Old 01-17-2017, 09:54 PM   #18
MIKE77z
MIKE77z's Avatar
She was at the body shop for a few months 😆 but it's back and reconstruction beings between snow shifts. I'm happy with the work lines are straight doors close like a new car . Back cherry blend made in house to not be too too blingy some more pics to follow.
Old 01-17-2017, 10:55 PM   #19
harrisoncole4
harrisoncole4's Avatar
Looks awesome! My blazer looks pretty similar to what yours looked like at the beginning.
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858
harrisoncole4 is offline   Reply With Quote
Old 01-20-2017, 10:58 PM   #20
MIKE77z
MIKE77z's Avatar
Did a little more on it in the shed , it's kinda warm and too lazy to drag it to the shop. Thanks it's coming along for sure
Vintage air installation has started ididit tilt column and shocks door handles emblems all on more pics when in the shop.
Old 02-03-2017, 12:54 AM   #21
MIKE77z
MIKE77z's Avatar
Just did some serious damage to the credit card today, should be rolling it in the shop on sunday/monday and install the power train then start on well everything else lol
Old 03-21-2017, 09:18 PM   #22
MIKE77z
MIKE77z's Avatar
Well not much to report till a few days ago , its been snowing and i haven't had much time to get much done. But all is well no snow coming (for the rest of the year i hope ) And its in the shop for a little burst this week/weekend
Old 03-22-2017, 07:43 AM   #23
grillzy
look'n good neighbor
grillzy is offline   Reply With Quote
Old 03-22-2017, 10:33 PM   #24
MIKE77z
MIKE77z's Avatar
Just a Little progress today, Things went well.
Installed motor, trans , T case , rad , cruise ect ect some pics
Old 03-22-2017, 11:31 PM   #25
MIKE77z
MIKE77z's Avatar
Thanks grillzy, it's a wee a bit of a project and getting closer and closer to a ride in it ☺
