07-12-2017, 03:33 PM | #1 |
69 C10 front disc brake conversion
Would the front cross member with all the suspension and front disc brakes off a 77 to 78 corvette fit on a 69 Chevy C10. Would it be a direct bolt on? or It would not work. Any thoughts anybody?
Thanks, Ramiro |
07-12-2017, 04:16 PM | #2 |
Re: 69 C10 front disc brake conversion
I'm gonna stick my neck out and say this will not work, but anything can work with enough welding rod.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
07-12-2017, 04:34 PM | #3 |
71-87 Chevy 1/2 ton trucks are your best bet. Direct bolt on with least amount of work. Get the brake booster, M/C, prop valve that goes with the donor truck and you have better brakes also.
07-12-2017, 04:41 PM | #4 |
Def not direct bolt on
07-13-2017, 01:19 AM | #5 |
Thanks for all the responses. Definitely won't be going that route then.
07-13-2017, 12:57 PM | #6 |
63-82 Corvettes do not have a bolt on front crossmember. No, this is nowhere near bolt-on.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
07-13-2017, 03:31 PM | #7 |
My son just told me its a Camaro front end not a Corvette. Will the Camaro one work?
Ramiro |
07-13-2017, 03:34 PM | #8 |
Camarillo won't work either find a square body and use everything from one of those
70 SWB STEPSIDE 70 BLAZER 09 challenger |
07-13-2017, 03:43 PM | #9 |
