Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 07-11-2014, 07:07 AM   #1
notsolo
notsolo's Avatar
Sum Old Parts -72- 2wd conversion
Mostly original 72 Blazer
notsolo is offline   Reply With Quote
Old 07-11-2014, 07:16 AM   #2
notsolo
notsolo's Avatar
Re: Sum Old Parts -72- 2wd conversion
Started tear down about 3 years ago. The Blazer was solid and complete,
Old 07-11-2014, 07:21 AM   #3
notsolo
notsolo's Avatar
Stripped Everything off the frame. Lots of rivets drilled and punched out. Removed all 4X4 springs, cross members. Sand blasted frame and started reconstruction.
Old 07-11-2014, 07:31 AM   #4
notsolo
notsolo's Avatar
Seconds tick by...or seasons in this case.
Old 07-11-2014, 07:45 AM   #5
notsolo
notsolo's Avatar
Frame Spec's help to find out how the original was built, a lot of Cleaning and sand blasting and repainting, some things got done more than once.
Old 07-11-2014, 01:16 PM   #6
notsolo
notsolo's Avatar
Not a lot of photo's of pieces going back together, tried to use as many original 2wd truck parts as possible. Couple teaser pic's of the color.
Old 07-11-2014, 05:42 PM   #7
smbrouss70
smbrouss70's Avatar
Looks good so far! Are those corvette ram horn manifolds or 4x4 ones?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 07-11-2014, 07:55 PM   #8
notsolo
notsolo's Avatar
Silver Manifolds in the photo were original 4x4 dump strait down. had to replace with Dorman 45 degree swept back.
Old 07-11-2014, 08:08 PM   #9
notsolo
notsolo's Avatar
Cleaned undercoating off everything, wheel wells, under hood radiator support and body. Used Mastercoat silver on bare metal and shot U-Pol Raptor bed liner tinted blue over it.
Old 07-11-2014, 08:15 PM   #10
notsolo
notsolo's Avatar
Top came off after body was bolted back on the frame, removed windshield and painted dash and cowl area.
Old 07-11-2014, 08:24 PM   #11
denny5625
denny5625's Avatar
Looking good!
66 el Camino
70 1/2 RS Z-28
71 C10 2wd
72 2 wd Blazer
(2) 72 4 x 4 Blazers
88 24' Mirage 70 mph+
08 Harley Night Train
08 Silverado 4d 4 x 4
denny5625 is offline   Reply With Quote
Old 07-12-2014, 08:41 PM   #12
notsolo
notsolo's Avatar
Some Engine and drive train shots, after getting the whole thing together 327 didn't have good compression. (Bummer ) pulled that out in January and dropped in a crate 350. Drive shaft may have some history to it beefy 45" came from a motorsport engine builder outside Charlotte.
Old 07-12-2014, 08:51 PM   #13
notsolo
notsolo's Avatar
Parking brake cable was fabbed up out of a piece of frame rail. other bits copied from (Bruce's just a pickup)
Old 07-12-2014, 09:05 PM   #14
notsolo
notsolo's Avatar
I have been dreading the painting of the doors it took almost 2 weeks to get them prepped once started. After 2k primer, All pieces were painted bright silver,2 coats then topped with 3 coats of green.
Old 07-12-2014, 09:11 PM   #15
notsolo
notsolo's Avatar
Some orange peel but over all I am very pleased with the way it came out
Old 07-15-2014, 02:07 AM   #16
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Looking good! I'm going to follow along.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 07-15-2014, 06:30 AM   #17
notsolo
notsolo's Avatar
After 5 Coats of clear
Old 07-15-2014, 06:49 AM   #18
notsolo
notsolo's Avatar
Painted original grille a few years ago, had a few holes and cuts in it. 67-72chevytrucks.com/vboard/showthread.php?p=5082961&posted=1#post5082961
Old 07-15-2014, 11:51 AM   #19
jhama78
jhama78's Avatar
Good looking truck man, I see that you are local. Im down just south of the md/va line in temperanceville va. Hope to see you around.
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 07-19-2014, 06:43 AM   #20
notsolo
notsolo's Avatar
Thanks jhama78, slowly getting a few things done, seats in.
Old 09-03-2014, 10:17 AM   #21
notsolo
notsolo's Avatar
Side Panels made from 3/8 Aztek acrlic
Old 09-03-2014, 05:26 PM   #22
SOON2BLAZE
SOON2BLAZE's Avatar
Did using the garage door pully help as a multiplier for your rear brakes? Thanks
SOON2BLAZE is offline   Reply With Quote
Old 09-04-2014, 10:18 AM   #23
notsolo
notsolo's Avatar
No real mechanical advantage over the original hook and eye.
Old 09-04-2014, 10:38 AM   #24
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Wow! Excellent work! Any chance you have the any leftover parts to sell like some of the small stuff on the motor?
Old 09-04-2014, 07:31 PM   #25
jaros44sr
jaros44sr's Avatar
X2 very nice work.....
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
