Transmission cooler line setup
I’m not a technical guy in any way ( at least
building cars). But I recently got this passion for old American trucks, so I bought one from y and got it delivered to Stockholm. The first thing I noticed was that it was too tight between the steering and the seat. I almost couldn’t fit. What the heck did I buy!!!!! So I started doing some research one how to make it “modern “. The progress is doing well, and now I just finished setting the hydraulic cooler hoses. I need some positive feedbacks (negative also respected) Posted via Mobile Device |
Six in a row makes it go...
![]() Join Date: Mar 2009
Re: Transmission cooler line setup
It looks good to me, provided the inner line isn't too close to the exhaust. I just put headers on my old Buick and I'm debating between soft lines and bending up some copper-nickel.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
#3 | |
need a distance of 6” from the exhaust. Too be secure I mounted my headers to be sure, and I’m satisfied with it. Thanks for the input. Posted via Mobile Device |
#4 | |
Old member
Personally I would run hard lines from the radiator to the transmission use the rubber hose for both ends to connect it. Run the lines up in the frame rail and hide them out of sight. The hard lines will be much smaller also which will give you more room.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Looks good I like the custom separation brackets, also you may need to protect the hoses once the inner fender is in place. What was your solution for interior modern updates? Custom seat, and steering wheel changes?
#7 | ||
"I ain't nobody, dork."
Will the inner fender still fit?
Gary
Yes, new power steering, fuel tank in the frame, hydraulic brake, automatic transmission, new seats (Volvo, I need some Swedish parts)
![]() Join Date: Jul 2017
Definitely want to see the pics of Volvo seats in the truck.
JMC1965 1967 C20 LWB
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
That's what I was wondering...? Other than that, I kinda like it. But I would never run without those inner fenders...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
I would just put some DEI reflective sleeves on the lines where they are close to the exhaust. They make it with Velcro so you won’t have to disconnect the lines. I have used this stuff with success on turbo cars at much closer proximety.
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust) |
