Old 04-29-2018, 07:15 PM   #1
mehoff400
cable pedal
what are you guys doing to switch to gas cable pedal? i am looking for something that is minimal fab work as i dont weld. i do have buddy that can do some welding for me.
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 04-29-2018, 07:56 PM   #2
PGSigns
PGSigns's Avatar
Re: cable pedal
I used a pedal from 67 to 72 and got it here off the parts board. easy swap.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-29-2018, 08:12 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: cable pedal
A few people have done this with success: http://persh.org/Pickup/CableThrottle.htm In fact thats what I am now doing.
'71-'72 or '73-'87 pedals should work.
Although I havnt seen it done I even think the Lokar Xbag will work (see post #8 below) - https://www.ebay.com/itm/Lokar-XBAG-...mtr&rmvSB=true
Lokar Pedal - http://67-72chevytrucks.com/vboard/s...51&postcount=4
They also have an 'Eliminator' floor mounted pedal.
Old 04-29-2018, 10:34 PM   #4
Hollow65
Hollow65's Avatar
Re: cable pedal
I believe it’s a lokar assembly. I used a chunk of billet to offset the pedal. So much easier to pedal now.
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 04-29-2018, 11:18 PM   #5
steven03
Re: cable pedal
I dont have a pic but i used a s10/blazer gas pedal i got off ebay for 15 bucks. fits almost perfect just drilled a couple holes and bolted it right up.
steven03 is offline   Reply With Quote
Old 04-30-2018, 11:34 AM   #6
jcramsey
jcramsey's Avatar
Re: cable pedal
I used a mid 90's suburban pedal in my 62. Super simple and dirt cheap from the junkyard. Just trimmed the right side down a little, drilled three holes and bent the rod to where I needed it to be.
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 05-01-2018, 10:22 PM   #7
64shortbox
64shortbox's Avatar
Re: cable pedal
I used the gas pedal assy from a mid 70's Pontiac. The plastic gas pedal came off a mid 70's Nova. I did have to tweek (bend) the Pontiac gas pedal assy a little to get everything to work correctly. Nothing a vise couldn't handle. I also added the Power brake pedal from a 73 C-10 and next on the list is the stainless trim kit for a Chevelle to finish off the look.
Another item I plan to add is an emergency brake pedal assy from a 72 Caddy so when I drop the truck into gear - Drive or Reverse the parking brake will release automatically. Yep, I'm lazy and forgetful.
64shortbox is offline   Reply With Quote
Old 05-04-2018, 12:44 PM   #8
DLW
Re: cable pedal
I just went with a Lokar pedal for the 67-70 C10, put it where I wanted and drilled 3 holes.
DLW is offline   Reply With Quote
Old 05-04-2018, 09:55 PM   #9
rvrfoot
Re: cable pedal
Where did you get your fire wall cover?
rvrfoot is offline   Reply With Quote
Old 05-05-2018, 12:27 AM   #10
DLW
Re: cable pedal
Hi rvrfoot, I'm not sure who you were asking, but if it's me, I don't have a firewall cover. I used duplicolor bed liner on the entire floor and firewall then dynamatted it.
Old 05-07-2018, 10:17 PM   #11
rvrfoot
Re: cable pedal
What is the rubber cover over the dynamat?
Old 05-07-2018, 11:31 PM   #12
DLW
Re: cable pedal
There is no rubber cover over the dynamat. That is duplicolor bed liner, then I have dynamat over the bed liner, except for the firewall at the moment.
