#1 | |
Real Projects never die
1986: np208. 700r4---->th350 swap, need advice
For my 86 k5, i wanna swap the 700r4 in favor of a th350. I dont really care about the overdrive or lower gear ratio, i plan to tow and play with this truck, so i want it to take some moderate abuse.
I know the 82-84 or some years in there used a th350 np208. What all is different between these tcase/adapters and the 700r4s? i thought i read somewhere the th350 and 700r4 can swap without any modificaions. edit: just found out they are different. Quote:
(the main reason i want to use the th350 opposed to the 700r4 is the engine i have came from a 75 blazer with a th350 np203, so everything motor wise is setup for a th350 already, and plus they are more simple in my oppinion)
Ill put it this way, ive got a few lawn ornaments ![]() ![]() My name tag says Ryan KansasTwister On other forums
Re: 1986: np208. 700r4---->th350 swap, need advice
Man ive tried searching for this. Does anyone know of an aftermarket adapter opposed to an orignal gm?
Everyone else is going th350 to 700r4, and im going backwords. I guess i should be finding people going with the grain and get there stuff off them lol. Any help or info you guys can give me will be appreciated. I just wanna make sure i do this once, and do this right.
the pollock
hey heads up, i mis red the PM you sent me..
sorry... but here's what i got, the PO never stated anything about an adapter etc.. so i honestly have no clue, but here's pictures.. maby they will help ![]() ![]() ![]()
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
![]() ![]() ![]() Best pics i could get of her. Shes in the weeds right now, front right tires flat. Its been sitting so long, bought it from my brother, he pulled the motor 5 years ago. Ive had it in my name for near two years now, and the stars havent aligned enough for me to be able to dorp the motor back in. But my birthday is march 10th, and i really want this done by my 19th.
![]() Join Date: Jan 2007
I seriously doubt that there is any difference in the mating surfaces of the two adapters.... I would gues you could make it work with your original adapter.
Also, the same spacer/adapter that people are using when they trade in a 700r4 for a th350 could be used in your conversion to make up the space lost by the shorter th350 but I think that requires a longer output shaft for the tranny. I think. But, if the tranny is already hooked to the engine I would think you're just gonna move the engine back.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() Last edited by OldCreek; 02-14-2009 at 07:04 PM. Reason: because |
![]() Join Date: Oct 2006
you can use the 7oor4 adaptor. One of the two has a slitly longer output shaft that needs to be trimed, but I think it is the 700r4. If you are going to be towing, why not use a 400? just wandering because the 350 is not any stronger than the 700r4.
th350s are pretty strong, ive never had a problem unelss they were ran hard. There is a guy who had a th400/np208 combo, but to use a th400 id need to change the kickdown. the reason i picked a th350 is becuase the 350 im dropping in is already setup for a th350. And more than likely it will end up be an occasional tow, nothing heavy like a bobcat, at most my trailer and camaro.
Well, Whoop-dee-do!
![]() Join Date: Mar 2003
If you don't want to move the crossmember forward & modify driveshafts, you need this:
http://advanceadapters.com/product/1784/50-7100.html The transmission has to be torn down to put the shaft in though. As I think was said earlier, I think there is a stock length output shaft from a long tail 2wd that comes close, but then you have to do the crossmember & shafts rework. Or, I think there was an oddball "extra long" tailshaft in some vans or maybe subs that would work with the aftermarket case spacer.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD ![]() '72 K20 500 Cad/TH400/NP205 SOLD ![]() '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car ![]() |
i figured the 350s w/np208 wouldnt have been any different forward or backward than the 700r4s with a np208. Looks like im looking for a parts blazer.. lol.
Well, Whoop-dee-do!
Yeah, the 700r4 case is longer. somewhere buried in my trailer I think I have the "couple year deal" TH350 off a 208. A friend has the same in his truck. It's been his daily driver forever. He's getting the tranny rebuilt right now- only because someone else borrowed it and burned it up trying to pull a 4dr pickup & gooseneck out of a hole.
i just dont wanna go through the hassle of dealing with the factory computer carb junk that was on it. Was a real rats nest, i never saw it before my brother started tearing it apart. But from what i can tell, had an edelbrock performer intake, and the stock computer qjet, so it must of been a real canoworms. just trying to simplify things like my 77 c10, heavy half 350/th350, bullet proof combo imho. Ive never even had a lick of trouble from the trans.
I would really like to find someone with an 82-83 to take some measrements from to see if the transfercase is in the same place as my 86 or not, becuase that would determine if different driveshafts are required.
There is a th400/np208 on cl but i dont think a th400 would bolt right in a light duty k5 lol.
the pollock
well what and where do you want measurements?
Youve got a 4 speed right? I need somebuddy with a th350 automatic, not a 350 small block, different ball games.
Id like to see a front driveshaft and rear driveshaft length, from center of ujoint to center of ujoint. Should pretty much say if the transfercase sits in the same spot.
#15 |
Still wondering if anyone out there has a factory turbo 350 np208, especially in a blazer that they could take measurements off of. thanks guys.
Gonna drop advance adapters an email, see what they say about it.
#16 |
Hey Walts_restoration,
i have an 82 k10 longbed that i'm pretty confident has the th350/208 combo in it. It probably would not help much for the rear shaft measurement but I assume the front would give you the information you are looking for. I live in Independence, MO but the truck is at my brother's in Tonganoxie (just down the road from Lawrence). I'll drop you a PM and see if we can get together to get the measurements you are looking for. If you want we can meet and you can look at the truck to get a complete picture of what it would take to convert yours. Ron
1957 Chevy SWB Step Side 1970 Chevy 4x4 SWB Step Side 1970 Chevy 2wd LWB Fleet Side 1982 Chevy 4x4 K10 Scottsdale 1999 Dodge 1500 Quad-Cab 1993 Jeep Wrangler YJ 1981 Kawasaki KZ650 |
#17 | |
pm'd ya back, thanks for the help.
