06-10-2010, 01:25 PM | #1 |
80 Chevy k10 build
Hello guys, I am new here, I just picked up a 1980 K10 Pickup last Monday. This is my first project truck, and I am really looking forward to getting to work on this.
Pictures: Grill is cracked, you can see it is held together with string, the right head light bezel is broken as well. The Hood is bent, I know this is a problem with this style truck, how do I go about fixing it? It has been bent so many times that I will have to add some kind of support to keep it from bending. It has a 250 engine/ 350 transmission/ 205 transfercase. The fuel pump is missing, and the PO said that the engine is making a clicking noise, but I plan on putting a 350 in it. It also has AC in it! Does anybody know anything about this rear bumper? It sets in really far, and then the ends stick out farther. It has a frame in the bed for a hay lift, and im not sure if that has anything to do with why the bumper is like that. This is where the hay lifts winch was mounted. It seems to be in really good shape for being 30 years old, and being a farm truck. I dont know if I want to replace all of the dented areas on the truck or not. I plan on it being a Daily driver, and a mild offroader, so Im not sure if It is worth it to replace the bed and front fenders or not. The Plan: -Blue Body (Darker) -All chrome, or non body colored things will be black -350 Engine -3/4 ton axles and springs -New Stereo system -Military Surplus Tires |
06-10-2010, 01:56 PM | #2 |
Getting Old; Going Broke
Re: 80 Chevy k10 build
Welcome to the forums!
I'd almost swear that is my Grandpas old farm hands truck, his name was Manny and he passed away about 12 years ago or so. I have no idea where his old truck went, but I'd really have to be convinced that wasn't his. Then again, there are a loooooooooot of those style out there, in that condition. Looks like a good project for you, has some awesome potential though! I'll be watching. |
06-10-2010, 02:30 PM | #3 |
Looking forward to seeing how this goes for you! Looks like you have a solid truck to start with.
I am betting that rear bumper is a custom job with the corners intended as steps.
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original. View Project Pops HERE Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig View Project Cletus HERE - SOLD DD--2008 Duramax CCSB |
06-10-2010, 02:45 PM | #4 |
The bumper is probably homade and in in the center so you could drop the gate down without kinking it in the middle ,If you swap to 350 I pretty sure you ac is on the drivers side and alt is on the passenger,I know alot about these trucks as I bought one in 1980 and still have it today,Dang I feel old now,I got a hood for it though off 79.
Built chevy tuff! |
06-24-2010, 12:49 PM | #5 | |
Real Projects never die
bumper is dealer installed item, we have several trucks with that bumper on -them, but most of them are 73-74s, although i think one of our later 77-80 has it as well. Looks like a clean old 4x4, what ratio are your current axles? overall clean looking truck, i likey
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
06-24-2010, 01:13 PM | #6 | ||
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread Last edited by Mattman2010; 06-24-2010 at 01:17 PM. |
06-24-2010, 01:18 PM | #7 |
jack it up and rotate the pinion and watch and make sure both tires turn evenly at the same speed, and count how many turns of the pinion to one turn of the tire.
06-24-2010, 02:19 PM | #8 |
Alright, I will have to check that out this Sat. I hate working nights, and it being so hot out during the day, not much gets done!
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
06-10-2010, 11:55 PM | #9 |
Well, the guy that farms my parents land said that he has a 1980 3/4 ton, I am going to use it for parts. He says it was a high end truck at the time has power windows, power locks, ect.. I plan on stealing the 3/4 ton axles and springs (if they are 52" rears like mine) to make a Heavy Half ton.
Well the 250 engine has some bad news. It was missing the fuel pump, but I wanted to see if it would crank, because the PO said that it was making a clicking noise, and that it was getting really bad, so they parked it. Well after hooking a battery up to it, and trying to crank it, the engine was locked. So sense it was locked my dad and I started to look at it, and there was a hole in the oil pan from something flying through it. I planned on replacing the engine any way, it just means I have to get a new engine before I can drive it around, but that is what im going to get this parts truck for, it has a working 350 in it.
06-23-2010, 10:32 PM | #10 |
Well I have not updated a lot, but I have done quite a bit lately. I have already removed the front clip, and pulled the engine and the 350 transmission out.
The 250 was blown, the connecting rod went through the block, and the cam shaft was broke, and a lot of metal floating around. After I removed the front clip and engine/trans, I took off the bed and cab. I spend two days going around the frame removing any rust/dirt i could. Tonight I final put a fresh coat of paint on the frame. Should be picking up a 1980 K20 for parts this weekend. I plan on stealing the engine and axles out of it, and any sheet metal that is better than mine. I also plan on stealing the gauges out of it, instead of have the idiot lights in mine.
06-24-2010, 07:57 AM | #11 |
Nice job!!!
06-24-2010, 08:10 AM | #12 |
Looking good!
06-24-2010, 09:33 AM | #13 |
Thanks Guys, So far this has been a really fun project.
I have a few questions to ask though, How should I go about tipping the cab and bed over so I can paint the bottom of them black? Does the back glass on the cab need to be removed, or is there a way to set the truck on the back without removing the window? I just want to clean up the bottom sides of them, they are really muddy, and I'm sure the rust is starting, im just not sure how to go about setting them up and over to paint the bottoms.
06-24-2010, 12:44 PM | #14 |
Always trouble
On the cab, if you can slowly roll it over, have someone to put like a 4x4 at the bottom of the cab and right at the top, right above the back glass. Now, Im just guessing you could do it this way.
91 Silverado Regular cab, 2wd, swb-project truck 97 Silverado Extended cab, 2wd, swb-driver Last edited by GMC91; 06-24-2010 at 12:44 PM. |
06-24-2010, 02:45 PM | #15 |
Slots go on anything!
Are you planning on swapping out the power doors and all onto your truck? If so, it may be easier to swap out cabs and all, since yours is already torn down.
1974 Jimmy- 5.3/4L80e/NP241 |
06-30-2010, 10:47 PM | #16 |
Nice!! cant wait to see this truck done
07-01-2010, 07:39 AM | #17 |
Ohhh, a nice cattle guard on that parts truck, and cab lights. Well, I guess it depends on what the use will be for the truck, but I always loved trucks with cattle guards on them.
07-01-2010, 10:42 AM | #18 |
I plan on using that grill guard, and I have thought about using the cab lights, but I just don't know how I would install them, and I would hate to drill holes in my cab and have it leak.
I did a compression test on the 350, 7 of the cylinders are getting 180 PSI, one of them is getting 150 PSI. What am I suppose to be getting? Should I be worried about the 30 PSI gap between them?
07-01-2010, 11:38 AM | #19 |
Always trouble
Stock should be around 160 PSI.
91 Silverado Regular cab, 2wd, swb-project truck 97 Silverado Extended cab, 2wd, swb-driver |
07-01-2010, 11:41 AM | #20 |
So is that 180 a bad thing? If not, then should I be trying to figure out why that one cylinder will not go any higher than 150? Or should it be ok the way it is?
07-02-2010, 01:40 AM | #21 |
i wouldnt worry about the compression.
07-02-2010, 01:44 AM | #22 |
Always trouble
It will be fine. You might have a stuck lifter or something, or they may not all be pumped up if the motor has been sitting awhile. Had this happen on my old 305. Been sitting for a year and at first it only pulled 90 PSI, after spinning it more, it eventually pumped up to around 210 PSI on all cylinders. But that motor had been rebuilt before I got it.
07-02-2010, 09:58 AM | #23 |
Alright thanks guys. I am planning on taking the heads off of the engine to see what everything looks like just to make sure I do not have to rebuild it before I start buying replacement stuff. The engine was not running great when it was in the parts truck, and I am not sure what was going on with it.
How loose should the timing chain be? Mine has about a 1/2 inch of play in it. I have been thinking about just replacing it now so that I wont have to replace it later, but I was just wondering if there is to much play in it or not. I also noticed some weird things on the exhaust manifold, They are only on one side of the engine, and they are a long skinny tube that just sticks into the exhaust port. Does anyone know what these do?
07-02-2010, 12:39 PM | #24 |
Always trouble
It shouldnt have hardly any play. I would replace it now before you put everything back together.
07-02-2010, 02:28 PM | #25 |
Yeah I think that is the plan. It might seem like it is in ok shape, but sense i am there I might as well replace it, its only like $30, and i wont have to replace it again for a while.
