Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 05-18-2011, 04:28 PM   #1
way2lo2
way2lo2
way2lo2's Avatar
13" and 14" Corvette Brakes for C10's
Awhile back I posted some Corvette brake conversions we had done for customers and now we are going to offer them to forum members in different stages. The basic setup with include McGaughys 2.5 Drop spindles, bearings, seals, steel hubs drilled for 5x4.75" bolt circle with 7/16" studs, and the mounting bracket to make it all work. This is the most economical kit and lets you find a deal on your corvette parts whether new or used. At this stage, you will only need rotors, loaded calipers, hoses, and banjo bolts to complete the kit.
The next stage is fully assembled spindles ready to install, includes 13" drilled, slotted, and coated rotors, and loaded C5 RED Z06 calipers.
We also have the C6 Z06 14" brakes in red or Gransport Silver.
Prices as follows:
Basic starter kit $599.00
13" Assembled $999.00
14" C6 Z06 assembled $1499.00
I also have all components available separately. Redrilling hubs and rotors to 5x5 is available for $35ea. 6 lug hubs also available. I also have a huge inventory of used calipers.
Dealer for Billet Specialties, Ridetech, Airlift, Vintage Air and others. Feel free to call, email, or PM for a quote.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Way2Lo2@aol.com <----also my paypal
http://www.hubgarage.com/mygarage/way2Lo2
way2lo2 is offline   Reply With Quote
Old 05-18-2011, 05:06 PM   #2
fastbagged68
fastbagged68's Avatar
Re: 13" and 14" Corvette Brakes for C10's
What is the weight difference between the mcgauphys complete kit vs. The corvette? I know the mcgauphys kit is pretty heavy. Thx.
fastbagged68 is offline   Reply With Quote
Old 05-18-2011, 05:40 PM   #3
way2lo2
way2lo2
way2lo2's Avatar
Thats a fantastic question, though I've wondered before I never took the time until just now to check. A loaded C5 caliper with brake hose and hose bracket weights in at 10lbs 10oz while the Silverado caliper out of a Mcgaughys big brake kit weights 17lbs 4oz ea
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 05-18-2011, 05:44 PM   #4
slimneverdies
slimneverdies's Avatar
slimneverdies is offline   Reply With Quote
Old 05-18-2011, 05:45 PM   #5
slimneverdies
Wow. That's 14 lbs just in brakes!!!
Old 07-08-2011, 03:48 AM   #6
andrewmp6
Looks good any plans on matching rear kits?
Old 07-08-2011, 07:55 AM   #7
TxSqueeze
Those 14"er's are beautiful!!
68 SWB- Heads/Cam 6.0 w/4L80E swap in progress
TxSqueeze is offline   Reply With Quote
Old 11-11-2011, 02:27 AM   #8
Spla'nin
What is the minimum clearance inside wheel diameter required on the C5 assembly if you would be so kind...?
I'm trying to find out if I could use an existing set of wheels or not...thanx
'76 SB 350 400
Spla'nin is offline   Reply With Quote
Old 11-11-2011, 03:21 AM   #9
way2lo2
way2lo2
way2lo2's Avatar
.875 should be enough but I like 1" when I'm ordering custom machined wheels
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 11-11-2011, 06:17 PM   #10
Spla'nin
Exclamation Re: 13" and 14" Corvette Brakes for C10's
Are you quoting (1)the backspacing clearance measurement from the wheel / hub interface or the "add to" distance in radius from the caliper to the inside of the rim...? (2)What is the distance required from spindle center to just past caliper mounted (radius)...? plus or minus 8"
Both would be helpful...thanx
'76 SB 350 400
Old 11-11-2011, 10:34 PM   #11
way2lo2
way2lo2
way2lo2's Avatar
yes, thats wms to outside of caliper. The radial dimension your looking for is 7.74" this is center of hub to outside of caliper
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 12-08-2011, 06:57 AM   #12
Valhalla
Valhalla's Avatar
Good God those are sick.
My build thread for Project TiC TaC/Jazzmin Oh Yeahhh
Cheap work is never good and good work is never cheap. Lesson = learn to do it all the right way on your own.
SqueegeeMan
Valhalla is offline   Reply With Quote
Old 12-14-2011, 12:24 AM   #13
aggie91
I'm just glad to be here!
aggie91's Avatar
Boris - nice talking to you today. I look forward to your call back on the shipping. Can't wait to get these. Thanks again,
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-20-2011, 02:12 PM   #14
jimmydean
jimmydean's Avatar
Boris, have you looked at the 2004-2008 CTS-V caliper? i was told the Brembo CTS-V caliper is the same as the 14" Z06.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 12-20-2011, 05:12 PM   #15
way2lo2
way2lo2
way2lo2's Avatar
Haven't had the opportunity yet. If I run across a set, I will mock them up.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 02-12-2012, 03:04 PM   #16
slimneverdies
So if I was to buy the basic starter kit but I wanted it in 6lug hubs do you supply the rotors also? What would the rotors cost and the option for a 14"'rotor. I already have z06 calipers...
Old 06-21-2012, 10:54 PM   #17
1966JSM
What would it cost for a the 6 lug hub and spindle's? I have the brothers trucks disc swap right now and Im wondering if I could use that spindle with your hub
1966JSM is offline   Reply With Quote
Old 06-25-2012, 01:38 PM   #18
way2lo2
way2lo2
way2lo2's Avatar
the 6 bolt hub kit and spindles will be $750, your spindles won't work
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 06-22-2012, 01:18 PM   #19
jimmydean
jimmydean's Avatar
Boris, the Cadillac CTS-V (first gen) is the 4 pot Brembo from the first gen Z06, the same for the second gen CTS-V/Z06 6 pot. Such an awesome setup.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 06-25-2012, 01:41 PM   #20
way2lo2
way2lo2
way2lo2's Avatar
I may be missing something but the vette calipers and cts-v are very different
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 06-25-2012, 02:23 PM   #21
Pzary3233
OK, the Gen1 CTS-V uses 4 pot Brembos.
The Gen1 CTS-V (4 pot):
Gen2 CTS-V (6 pot)
Both are made by Brembo. Did GM cheap out on the Z06?
Correct GM skimped out entirely on the Z06 brakes...
VERY different...
C5 Z06 Brakes - Sliding caliper brakes that are a different color from the regular C5 brakes...
C6 Z06 - 6 piston calipers, but are prone to flex and the brake pads are ridiculously expensive. Some have recently come out with some single pads instead of the "padlets" that have bee used (one pad per piston).
As far as I am aware there has never been a factory adaptation of a Brembo on a Corvette. Vette calipers are made by PBR of Australia.
This is what a lot of the F body guys are doing with that particular caliper:
http://www.ls1tech.com/forums/suspen...-kit-info.html
The newer adaptation has been the Camaro Brembos. As they are being produced currently thus they are easier to get your hand on a set.
Way2lo2 is doing us a great service by getting decent brakes on our trucks... I can't wait to see what else he comes up with. It would be great to adapt a spindle for "modular" use like some of the car spindles that simply take a bracket and you're in business with any brake setup you can imagine. What he is offering is one step closer without going to CPP modular spindles.
'55 3200 283 4 speed
'68 Pontiac Firebird Poncho powered with a 6 speed
Pzary3233 is offline   Reply With Quote
Old 06-22-2012, 04:57 PM   #22
Pzary3233
The c5 z06 did not have the 4 pot brembos... They were simply red painted sliding calipers. The cool part about the brembos though is that they list for 150 or less each from the dealer. C6 z06 calipers is not a brembo...
Old 06-25-2012, 12:47 PM   #23
jimmydean
jimmydean's Avatar
OK, the Gen1 CTS-V uses 4 pot Brembos, I was told the C5 Z06 was the same.
Gen2 CTS-V (6 pot)
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 06-23-2012, 09:09 PM   #24
Valhalla
Valhalla's Avatar
Still making these ?
Old 06-25-2012, 01:42 PM   #25
way2lo2
way2lo2
way2lo2's Avatar
yes
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
