I'm just glad to be here!
2 for 1 Part II...
You guys have probably seen my son's build that was the first part of this 2 for 1 deal we got on a couple of square bodies. There is a link in my Signature below for Korbin's Sunburn.
Well, this truck is the second of that 2 for 1 deal. We brought it home a couple of months ago and gave it a bath just so it does not look like an eyesore at the house. We really had not touched it other than a good external cleaning. Here are some pictures: ![]() ![]() ![]() ![]() ![]() ![]() ![]() From the SPID it is a VERY basic truck: ![]() After a bath it did not look to bad. The body is reasonably straight and hardly any rust. The cab is good and solid. This one is actually the beter of the two, we just did not look hard enought the first time around...live and learn.. ![]() ![]() Plans at this time are to get it running and driving to use as a parts hauler for now... ![]()
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
Re: 2 for 1 Part II...
Since I have a couple of project trucks, I have decided to do the basics on this one and use my "good" upgrade parts on my '65 once I can get back to it.
Korbin started to get the carpet out and clean the interior to reduce the smell and see how the floors really are: ![]() That was a few weeks ago. So, the other evening my wife and I were out for our walk the other evening, I told her that I wanted to work on getting this one to make a driver/parts/trash hauler out of it. My initial plan is to keep the costs under control and REALLY low. She said OK and that got me thinking.... This week I told her that for Father's Day I did not want any gifts but to have the day to work on this thing. So, I got the green light and Korbin agreed to help for the day. Last night I did a bit of prep work for Sunday. I got under it and disconneted most of the items from the bottom related to pulling the engine/trans. I also placed an order for rear brake parts (minus the drums) with Rock Auto. Hardware kit, Shoes, Wheel Cylinders and Flex Hose shipped to my door for a total of $30.36. Those won't be here till next week but they will be needed. My '65 has new calipers, pads and bearing with good rotors that were turned when I started redoing it a couple of years ago along with new ball joints. Those will make its way onto this truck for now, no money out of my pocket today for those items. This weekend's plan is to pull the engine and trans, and replace the front brakes if time allows. Stay tuned.
Good Luck! Oughta be a good little beater!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
Great deal on those trucks and to have one stored for 4 years
![]() I did read in the first page of the other square body build that your younger son was then 9 years old, so now he's maybe 13 ? That would give you and him 3 years to do this up for him, maybe .? Just say'in. ![]() |
I'll be watching!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#6 | |
Thanks for checking in guys. I got some stuff done over the weekend, but not everyting I had planned. I'm loading up pictures now, so I will post updates later.
Well got some time to work on it on Saturday too. Glad I did, since Sunday I was not able to spend as much time as I wanted. My help had worked all day before and was too tired. I finally did get some help and we got the motor out and on the stand.
Started with this: ![]() Ended up with this: ![]() The 4.3 V6 uses different mounts then the traditional small block. Here is a pic of the frame side of things: ![]() They are further back on the crossmember. The passenger side is similar to a V8 with the rubber mount on the frame bracket and the clam shell on the engine. The driver side had the rubber mount on the engine and the clam shell on the frame bracket. Got everything labled on the harness still attached to the truck. I started removing other parts of the AC system since the front boot and engine are out. Got some cleaning to do now... ![]()
I'll be watching this one! Looks like a very solid start!
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) Instagram- shaggin_c10 |
So far this truck looks to be real solid. the only rust found so far was the battery try and the two bolts holding the core support on. There is some signs of rust in the horizontal seam on the firewall in the recessed part, but I should be able to treat it and not replace the metal on the firewall.
The frame mounts for the engine look promising for doing the LS swap, but I have not taken any measurements to see what it will take. I know that I can swap out the mounts for regular SBC ones and use what's out on the market, but this is going to be a low buck swap and if needed, I can fab my own. Time will tell. I hope to get a short amount of time this evening to measure some stuff, but today is Korbin's birthday, Owen has an All Star scrimmage from 7-9 and Katie has her gymnastics/tumbling class from 4-6. Needless to say we are kind of busy today...LOL
Watch out for your cornhole !
What's the story on the V6 ? Did it not run ?
Kevin - You can find me working on something or the other on Instagram, link below... My Instagram |
No the V6 did not run, I found a rat skeleton in the air cleaner, the carb is full of rats nests, not even sure what had gotten down into the intake. My plan is to get it stripped down to a long block and have a look at it. That my take awhile before I get to that point. Current thinking is rebuilding it with a mild performance twist to put into my '65. Not real sure yet. I might even trade it off...
Main focus now it getting the LS into the frame rails. I know that does not sound like a low buck approach to things, but I already have the motor/trans and stand alone harness/pcm. Right now looks like I have everything I need for the swap except for maybe a fuel line or some other small item. Not sure what I will do about a speedo for now...
If your V6 had a carb full of rat's nest, you just know it has a block full of rat urine. You can nearly bet of trails of rust running down into the bores.
I guess I need to build me an LS powered truck just once. Everybody says an LS engine cures everything from poor mileage to male pattern baldness. But crap, dealing with exhaust manifold clearance, drive by wire pedals, computer programming and high pressure fuel systems sure doesn't seem like the slam dunk swap everyone makes it out to be. Yes, I'm sure I could do the swap, but the hassle seems significant.
#13 | |
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205 |
#14 | ||
Follow along as I get into this one. I am out for a few days because of my job, but my next step is just getting the engine/trans in between the frame rails...Stay tuned... ![]()
#15 |
Nice start. I read all of the other build, It was a great job from both of you.
2014 Dodge Charger SXT 100th Anniversary Edition 2009 Chevy Silverado Z71 1978 Chevy Scottsdale 4x4-Project "Colonel"- Build http://67-72chevytrucks.com/vboard/s...d.php?t=632039 |
#16 |
Karl, I'll be following the LS swap closely. I'm interested to see your approach. There's been multiple times on here where guys have said you can buy an LS and install it as cheaply as buying a 1300 dollar crate engine and installing it. That's sounds like horsesh1t to me but I have never called anyone out on it since I haven't personally done this swap. I'm hoping you can pave the way for some sensible and simple money saving swap tips.
#17 |
I know doing it in a square makes it a lot easier. See the "Fred" thread. Especially if you find a robbable '87 in the yards. I'll be excited to see this as well, y'all do nice work!
#18 | |
Slots go on anything!
![]() Karl, I am interested to see how you do it. I have tried to do mine the poor boy way, but I broke down and bought a harness and a few other things along the way. Not 100% budget minded, but close.
1974 Jimmy- 5.3/4L80e/NP241 |
#19 | ||||
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 06-19-2014 at 02:11 PM. Reason: left out a response... |
#20 |
If you aren't going for the show car look under the hood, the easiest way is to use the under hood fuse block from the donor truck. It's a 3 wire hookup...12+ constant, 12+ switched and the fuel pump hot. Then there is one wire to the trans that has to be moved in the fuse block. Pretty simple.
I used the factory covers for the fuse block and mounted it to the fender. I also used the drive by wire and hooked up cruise. I also did a swap in a 55 nomad and modified the stock harness myself following lt1 swap.com. It's not hard just time consuming and be careful and don't accidently cut a wire that your not supposed too. Don't ask me how I know about that.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
#21 |
Not going for a show car look, but I do not like the look of the factory fuse box especially if your not using ALL of the circuits inside it. Takes up to much space.
I have the harness already done, I am just going clean it up a bit and re-route it some. Current thinking is to place the PCM where the auxillary battery tray would be on the driver's side front corner of the engine bay.
#22 |
I spent some time last night measuring the engine block mounting bosses relative to the bellhousing flange on both the 4.3 V6 and the LM7 engine.
The 4.3 has a distance of 9 13/16" from the flange to the rear upper bolt boss for the enging mount. The LM7 has a distance of 10.27" per some online info (I measured 10 1/4" with my combination square) from the flange to the upper rear bolt boss for the enging mount. Give these two distances, if I was to put the traditional clam shell mount on the LM7 engine so that the upper rear bolt of the mount is shared by both engines, that would put the new LS based engine BACK by 7/16" from where the 1985 OE 4.3 V6 was mounted. While searching the internet, there are is not a adapter plate that makes this work with the OE 4.3 V6 frame or motor mounts. Yes, the frame mounts are different for the 43. compared to the SBC of BBC frame mounts. The readily available 3" forward mounts look right, but most are machined for using flat head screws to mount the traditional V8 engine mount. There is one exception that I have found. The Holley 3" forward mount uses the flat head screw to mount the adapter plate to the LS block on 3 of the bolts and the upper front bolt is shared. The other 2 bolts for the traditional mount are drilled and tapped into the adapter to use a standard hex head bolt. The Holley part number is: 12622HKRUPC. Here is a picture of that adapter plate: ![]() For this one to work for my idea, they need to be mounted opposite of Holley's intention. I.E. the Driver's side mount need to be used on the Passenger side and vice versa. In the picture above, the bottom one would go on the driver's side of my LM7 to make this all work. Best price I found on the net so far is about $80. I will still need to get new rubber mounts also.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 06-26-2014 at 09:53 AM. Reason: Sorry for the HUGE picture, best one I could find... |
#23 |
Based on my comments earlier in the thread, the $80 is too much to spend on these for this project.
So, I made my own drawing and will not be using any fancy tools to make these. They could be made with a cut off wheel in a grinder and a drill/drill bits for the holes. I have a local shop making these on a plasma table for about $20 with me supplying the material. I have the material in my stash and I figured that the $20 is worth my time to not make them. These will not use any flat head bolts, so there is no counter sinking needed on them. They will be 1/4" thick. Here is the drawing: ![]() I will also need new rubber mounts for this. I looked them up on RockAuto and found them. Anchor brand, Part numebr 2435 & 2436, $5.01 & $3.36 each respectively ($18.27 shipped to my door with my 55 discount). AutoZone is $11.99 & $8.99 for the same mounts, ($22.71 out the door with taxes). I might just do the AZ ones since I am a rewards member there and it would qualify as one of my $20 purchases and they are in stock. I will hold off on getting them until I have the adapter plates in hand and can mock up the parts with the old ones. No sense having to waste a trip and gas if this idea does not work... ![]()
#24 |
Karl, I used the left side to mount my battery, so I was able to use the factory LS cables and routing that way. For the PCM, I used the PCM tray for a 98 S10. It mounts pretty flat, so I used 1/4" carriage bolts of different lengths to get it level. The way my harness came, the TAC module plug was pretty close to the PCM plugs, so the TAC and fuel pump/fan relays went on the inner fender right above the PCM. Auxillary fuse box went just inside of the PCM. It isn't exactly car show ready, but it will work. I figured I can church it up a bit if I need to, but I probably won't.
#25 |
![]() Join Date: Oct 2013
Definitely tuning into this one. You've always been a big encouragement to me and I love Korbin's truck so I'm excited to see how this one plays out.
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB Light Green LS Build |
Thread Tools | |
Display Modes | |
