01-26-2013, 01:04 AM | #1 |
66 SPID sticker language - share and learn!
During my brief research of RPO and SPID codes i've found that, although the list of option codes (and what you could get them on) is available, you need an original sticker example in order to put the right description.
Also, a lot of original stickers have letters after them, and the paint code, and i haven't found ANYTHING on what they mean. Like lets say option "laser beam" was option "G99" in the RPO list. On the decal it may say "FG99AA" "Laser Weapons System" and the paint code may be "910" but the sticker shows "910AF". If anyone knows what those letters may mean, throw it in. There is a lot of examples of SPID stickers here, and i've PM'd a lot of you this last week asking questions, in order to properly list all the options my truck had (and is getting) in the glove box. To me, stickers are the best part of a restoration (Decals in the engine bay, etc) and i collect and save them until the car is "done", and it's a happy day when the car is done and clean and i get to put them on. They really make a restore job "pop". So, i think this is good info to have, because it seems lost for the '66s, but the 67 and later seems fairly well documented. I have posted codes here (the base codes, not the extra letters, you can find them in the pics below if you wish to see examples of the extra letters) and the text that goes with it for those of you who may find it useful. If you have an original sticker or one copied exactly from an original sticker, please post it. If you have an option code and its correct text, please post away. If you want to know what an option is, (like hydraulic brakes, that's power vacuum brakes), ask, or look it up in the code manual. Also, some options "include" another. Like i think A/C includes HD radiator. It'd be nice to be clear if HD radiator would be on the SPID or would it be omitted because the A/C code implies it? (seems the later would be the case), but option L30 327, requires option F60, hd front springs...and one tag shows both. Here's what i found today: V74 - HAZARD WARNING SWITCH N01 - 21 GAL GAS TANK B98 - SIDE TRIM MOLD EQ F60 - HD FRONT SPRING L30 - 327 CU. IN. V-8 ENG Z81 - CAMPER SPECIAL EQ K24 - CLOSED ENG POS VENT Z53 - AMMETER-OIL GAUGE J70 - HYDRAULIC BRAKE M49 - 3 SPD AUTO TRANS T60 - HEAVY DUTY BATTERY Z20 - ENGINE CONVERSION Z52 - FOAM SEAT D32 - R/V MIRROR RH G50 - HEAVY REAR SPRING L32 - 283 CU. IN. V-8 ENG U60 - MANUAL RADIO A94 - SAFETY DOOR LOCK A10 - PANORAMIC CAB M35 - POWERGLIDE TRANS G60 - AUXILIARY SPRING EQ C60 - 4 SEASON AIR COND V37 - CHROME-BUMPER FRT Z62 - CUSTOM GROUP Z62 - CUSTOM C&C EQUIP K48 - OIL BATH AIR CLEANER A11 - TINTED GLASS A11 - TINTED GLASS ALL Z61 - CUSTOM GROUP Z61 - CUSTOM APPEAR INCL Z53 - AMMETER C42 - DELUXE HEATER C42 - DELUXE AIR HEATER F76 - FRONT WHEEL LOCK HUBS M20 - 4 SPD TRANSMISSION N40 - POWER STEERING D29 - R V JR MIRROR RH&LH DECAL - DECAL V01 - HEAVY DUTY RADIATOR Link to info packet for '66 which has more detail about options (descriptions, options required, what series you could get them one, etc.) http://www.gmheritagecenter.com/docs...olet-Truck.pdf Thanks OEM4ME and GM Heritage, for the link. Last edited by cortcomp; 01-26-2013 at 11:02 AM. Reason: add link, typo |
01-26-2013, 01:07 AM | #2 |
Re: 66 SPID sticker language - share and learn!
Supporting documents:
01-26-2013, 01:07 AM | #3 |
More supporting docs
01-26-2013, 10:37 AM | #4 |
nice work i will try to post some as well
01-26-2013, 11:02 AM | #5 |
The more info in one place the better...curiously, i wonder what decal - decal is? Shooting from the hip, i'm guessing the AC sticker on the rear window??
01-26-2013, 11:10 AM | #6 |
There has been a lot of speculation on the printers used for this, some even speculating typewriters. I've read discussion across a lot of sites, and, from my tech experience, and knowing GM (why pay 1000 typists when you can spend 800 times that on a mainframe and some printers) i'm betting that this was the series used:
http://en.wikipedia.org/wiki/IBM_1403 others have more info on this, but i haven't found anything that confirmed that, other than a gentleman on a forum claiming to have serviced them, but didn't remember the typeface used. Here's a link to a similar discussion about font and machines used: http://nastyz28.com/forum/archive/in...p/t-46459.html And here's a guy working on making a font matching that typeface using the output from an actual IBM 1403, and his sample looks pretty good: http://slantedhall.wordpress.com/201...e-in-progress/ Another link from someone else about the same project: http://brainwagon.org/2013/01/23/an-ibm-1403-font/ Last edited by cortcomp; 01-26-2013 at 11:31 AM. |
01-26-2013, 11:35 AM | #7 |
The Older Generation
This is from my Janesville built 1966 LWB C-10 L32 - 283 CU. IN. V-8 ENG V37 - CHROME-BUMPER FRT B98 - SIDE TRIM MOLD EQ C42 - DELUXE AIR HEATER F51 - FRT & REAR SHOCK ABS D29 - R V JR MIRROR R & L G50 - HEAVY REAR SPRING P13 - SM WHEEL CARRIER Z53 - AMMETER-OIL GAUGE U60 - MANUAL RADIO Z61 - CUSTOM GROUP Z62 - Only the word CUSTOM is readable so I don't know which one of the following is correct. I would like to know. Z62 - CUSTOM GROUP Z62 - CUSTOM C&C EQUIP On my metal ID tag the Z62AA is stamped in the "TRIM' location.(see picture) I think the information would have to include the assembly plant and year to be really useful. Obviously different plants or different years used different wording. Just my 2¢ worth... LockDoc
01-26-2013, 12:05 PM | #8 |
"Z62 - CUSTOM GROUP
Z62 - CUSTOM C&C EQUIP" I have seen it both ways in stickers above, you could decode the vin to see if one of the assembly plants matches yours and decide which to go with. "On my metal ID tag the Z62AA is stamped in the "TRIM' location.(see picture)" On my trim tag, it's just Z62 and 544. no extra letters. " I think the information would have to include the assembly plant and year to be really useful. Obviously different plants or different years used different wording. Just my 2¢ worth..." On the year, these stickers are only on 66's as i understand it? At least for this thread, 67-72 have their own threads with a ton of information. If these were really mainframe printed with chain impact printers, and written in cobol, my guess is one group wrote the program, and did the data entry on the codes, and then sent the program copies to each assembly plant. 99% of the codes would read exactly the same, and if an option was changed or adjusted, the tech guy at that plant would likely change the relevant code. That's just a GUESS, but that's why i'm thinking that 99% of these codes are identical even between series, down to the punctuation (like CU. IN. V-8, but another plant doesn't show CU IN V8. or CUB IN V8). So, my personal feeling, is that you could lift an option code and description off a similar truck, and be pretty damn sure you nailed it. |
01-26-2013, 12:19 PM | #9 | |
Although I have had a few '67-'72 trucks I am new to the '60-'66 trucks and didn't realize there were no SPID's before '66. So I guess the only thing that might help is listing the assembly plant. Thanks, LockDoc
01-26-2013, 01:06 PM | #10 |
As long as we are discussing the details of the SPID stickers, I wonder why mine is the only one with the white band and number at the top? My guess is that it was probably not meant to be there. Does this make my truck more rare/valuable? lol
01-26-2013, 11:34 AM | #11 |
Those mean a lot to the Assembly Plant. For example, the A/C system parts that get installed on a 283 V8 will be different from those for a 230 L6 and different from a 292 L6. The Corvette guys have it all figured out and I remember reading a full explanation and decoding of them. Those codes will be different from 66 Corvettes and 66 trucks. |
01-26-2013, 11:59 AM | #12 | |
01-26-2013, 01:16 PM | #13 |
Honestly, that looks like that's part of the sticker that would stay on the whole printed sheet. I wonder if someone who put it on accidentally peeled it with it? Or it stuck to the option sheet so he didn't catch it? I'm guessing it was supposed to stay on the backing paper he peeled the label from, looking at what appears to be a seam there between the two pieces.
01-26-2013, 01:18 PM | #14 |
One sheet shows 9512A - REAR AXLE, haven't seen that one in the lists, if anyone has info on what that is, throw it out there.
01-26-2013, 03:28 PM | #15 |
The 4 digit number on these sheets your referring to I think is the " Special Equipment" number . Options that were not on the normal list of dealer options.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK Last edited by 60-66; 01-26-2013 at 03:56 PM. |
01-26-2013, 03:06 PM | #16 |
Quote "Also, a lot of original stickers have letters after them, and the paint code, and i haven't found ANYTHING on what they mean"
Guys, those letter codes your asking about are the letters they put on the Build Sheets.Heres the build sheet from my 65 K10.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
01-26-2013, 05:26 PM | #17 |
Here's two samples, both '66 Baltimore trucks. Both C10s, solid white,and 283 V8s. Serial number '4212 is a LWB stepside pickup and '1632 is a Suburban. Notice they both have Z62 Custom Group, but the stepside is Z62AA and the Sub is Z62CA because the Custom molding on the sides were completely different between the two.
Also notice the difference between fonts of the Serial # and the rest of the page. Look at the 3's and 4's. It appears that this sheet was printed at separate times on separate printers. I don't see that on Fremont trucks for example. Just one of the quirks between different plants building the same truck in a slightly different manner. |
01-26-2013, 06:37 PM | #18 |
That does make sense about the extra digit codes, and it looks like we have a nice amount of samples so that those making labels can pick a similar truck to theirs and likely get all the right codes, not just the short option code.
I wonder if the stickers were printed with serial number in one place and then the rest of the options done at the plant where it was built? Or maybe the serial number was put on the sheet at a later point in the process? Seems unlikely, but would love to hear the stories of how these things are inconsistent between plants. |
01-26-2013, 08:13 PM | #19 |
Looks like it's a little too dark, or bold I guess but still a good match I think. Here's the link if anyone else wants to give it a try: http://www.network54.com/Forum/74182...bably+IBM+1403 |
01-26-2013, 09:10 PM | #20 |
Here's an example of what I was trying to say earlier about build sheet codes. Those letters that are after the option code on the spids sheet will also be on a build sheet. Tomorrow I will try and get some pictures of the 66 I have with both sheets so we can compare. The picture below is of my 1967 trucks master cylinder, its a low miler with its original master cylinder. On the front there's a machined boss with the stamping AB. This will also be on the build sheet . ( will look for that tomorrow also) . This letter code told the person on the assembly line which type of master to put on the vehicle. A better example is lets say a 1967 Chevelle with drum brakes and one with disc brakes, two different master cylinders, both stamped differently with their own unique code.The master cylinder would also have a paper tag with that letter code and this would be on the build sheet..pho
This same 67 truck has a paper tag on the brake drum with letter codes. Build sheets are great when restoring your vehicle, the letter codes can help you ID parts like pulleys, fan clutches and many other parts as many of those items are either stamped or ink stamped. Things like trim as VictoriaHardware stated are a little harder to figure out by letter codes unless you have the info we all are providing on spids. I'm guessing here but there could be several different letter codes for all the different combinations of trim ??
01-26-2013, 10:41 PM | #21 |
Here's more examples-
01-26-2013, 10:43 PM | #22 |
2 more-
01-27-2013, 12:14 AM | #23 |
i like that one that that use to be my old truck 126162
01-27-2013, 06:26 PM | #24 |
i noticed that the fremont stickers start printing at the very top with no space the others space down till print
12-22-2017, 06:31 PM | #25 |
Didnt see this thread til after I posted my thread on the missing spid on my 66k10 burb.
http://www.67-72chevytrucks.com/vboa...d.php?t=753214 I have a question on a couple things. First I do not see A/C as an option on the K10 options list and a few people have told me it was not available on K series prior to 67. Mine definitely has factory A/C. Were other options available for 2WD also available for 4WD? I find it strange that a posi rear was available for 2wd but not for 4wd. I also saw that tow hooks are not available for 2wd trucks with chrome bumper, were frame horns different for K trucks compared to C? Do any 66 spids list wheel and tire options like later spids? Also reading through the whole thread it looks like many images were lost. Is there any way 60-66 could fix his pics? |
