![]() Join Date: Jul 2009
door alignment
Hello everyone, having great difficulty in aligning my 1967 Chevy C10 pickup doors so that they will close without the use of slamming them to pieces. I put new door hinges on, but just can't get the doors to shut with a "reasonable" amount of support. Any suggestions? All would be greatly appreciated. 1950ace
Re: door alignment
Have you got new rubbers on? Almost everyone that has new rubbers says the doors are real hard to shut until the rubber settles in a little. Have you moved your stricker plates in or out to try to adjust the door?
![]() Join Date: Sep 2005
Re: door alignment
same here...put new rubbers on my 68 and the driver side door just barely catches the little rod in the door well. It shut perfectly before i changed the rubbers. Pass side is fine. I've changed door seals on over 25 trucks and this has NEVER happened. Somedays ya just wanna scream!!!
Re: door alignment
Besides adjusting the catch plate where the latch contacts, I have also had to loosen the hinges at the front fenders and move the doors up a 1/8" or so to keep my lines straight and shut the doors!
