11-03-2014, 09:39 AM | #1 |
My 52 GMC Build
I have always wanted a early 50's GMC P/U and 8 years ago I found it, A 1952 GMC 9700 that used to be a fire truck in great shape. Just cab forward no motor or trans, but all I wanted was the body to make a hot rod.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
11-03-2014, 09:46 AM | #2 |
Re: My 52 GMC Build
Took the 52 cab off the frame. Bought a 1989 s-10 extended cab P/U for the frame only stripped it apart sandblasted frame and primed. Then mounted cab to S-10 frame, there it sat in my garage for 6.5 years. In that time I was planning what I wanted to do.
11-03-2014, 09:52 AM | #3 |
Re: My 52 GMC Build
Spring of 2013 I was ready to start on my 52. The truck had been built in my head for some time now, even drove it in my dreams a few times. As some of you can relate i'm sure. I wanted to make it different in most ways but wanted it to look like a 52 GMC P/U
11-03-2014, 01:03 PM | #4 |
Re: My 52 GMC Build
My neighbor gave me the a motor, trans and axle from a 1994 e350 cube van. I wanted to put a diesel motor in, so this was perfect. 7.3L IDI International diesel. So first step clean up motor and build it to take what I wanted to do to it, then mount it in the frame.
11-03-2014, 01:06 PM | #5 |
Re: My 52 GMC Build
I wanted air bags on all corners to get running boards on the ground. D.O.M. tubular A arms should take the weight of the 1000 lb motor .
11-03-2014, 01:10 PM | #6 |
Re: My 52 GMC Build
I boxed in the frame and added a cross member just behind the cab. I built the transmission with some upgrades and shift kit so it can take the extra hp and tq .
11-03-2014, 10:35 AM | #7 |
Re: My 52 GMC Build
I can't wait for the next chapter!
Love having the photos.
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
11-03-2014, 01:26 PM | #8 |
Re: My 52 GMC Build
wow !
11-03-2014, 09:01 PM | #9 |
6>8 Plugless........
Re: My 52 GMC Build
Great project, and cool build. I can tell you from expreience, don't give that 7.3 more than 14psi of boost or you will get good at swapping engines. You need to install bigger wrist pins to go above 14psi of boost. They're great engines besides that little deal.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-03-2014, 10:35 PM | #10 |
Re: My 52 GMC Build
What a cool project, I will watch this to the finish if you keep the pics coming.
11-04-2014, 09:36 AM | #11 |
Re: My 52 GMC Build
Thanks Dieselwrencher good to know!! I put ARP head studs and good feelpro head gaskets in to hold the heads on. I was planning to run 15psi on the street, then 20psi on the dyno and once and a while on drag strip.
11-04-2014, 09:37 AM | #12 |
Re: My 52 GMC Build
How can I post a video?
11-04-2014, 06:06 PM | #13 |
Re: My 52 GMC Build
Post it to youtube than copy and paste the link in your message.
I put 30psi to a 6.9 at 4200rpm pulling for a summer. I couldn't blow it up. The next owner though, got it accomplished. Haha
11-05-2014, 11:14 AM | #14 |
Re: My 52 GMC Build
That 6.9L must have pulled hard
12-08-2014, 10:11 PM | #15 |
Re: My 52 GMC Build
Friday I got the axle housing back. Then put it all together and lined it up.
It looks sweet being so short!! Its a Dana 70HD By Saturday night I had figured out how I was going to be able to build the back frame, so it would work with the suspension and axle. Got the steel cut and tacked then ran out of welding gas Sunday got the frame welded up. Then put truck at ride height about 5". The brackets for the axle in the 4 link kit where for a 3" tube mine is 3.5" so a bit of grinding opened it up. Ready for Monday Monday got 4 link figured out and welded all but top frame brackets, thats tomorrow. Then air bags
12-09-2014, 03:48 PM | #16 |
Re: My 52 GMC Build
Nice work, it's really coming together.
12-09-2014, 08:14 PM | #17 |
Re: My 52 GMC Build
Thanks. Ya so happy!!
So today I got upper front brackets on and made and mounted lower air bag plate.
12-09-2014, 08:46 PM | #18 |
Re: My 52 GMC Build
I'm Liking where this build is going ! Keep up the good work !
12-09-2014, 11:14 PM | #19 |
Re: My 52 GMC Build
Not throwing any rocks, but I'm wondering if that 4 link is going to work properly and safely with the upper bars at that angle instead of straight above the bottom ones?
http://67-72chevytrucks.com/vboard/s...d.php?t=592642 '48 Chev extended cab with attitude http://67-72chevytrucks.com/vboard/s...d.php?t=592769 My daughter's '46 International PU |
12-09-2014, 11:28 PM | #20 |
Re: My 52 GMC Build
No worries. Its a double triangulated 4 link, its used to keep the axle centered in the frame more. 4X4's use it in extreme. I had to use it due to my limited space and not enough angle left and right. Didn't want a pan hard bar. I talked to the shop that shortened my axle. The only down fall is it increases the height of my roll center. The truck will lean in the corner more but i figured with a 1000 lb motor up front I don' think the back will do much.
12-10-2014, 08:21 PM | #21 |
Re: My 52 GMC Build
Looks very nice!
12-17-2014, 10:59 PM | #22 |
Re: My 52 GMC Build
What a cool build. I own an AD and a '94 factory turbo IDI crew cab dually. My F-350 has a 90cc injection pump, BB code injectors, waste gate adjusted for 15psi(on the stock head bolts and 216,000 mile head gaskets), Hypermax cowl induction with a K&N air filter, Banks down pipe/EGT+boost gauges and 4" straight pipe side exhaust.
What turbo is that? What other mods got done to the E4OD? Whats plans do you have for fueling? A cam swap would be real easy right now.....google R&D IDI Performance.
'55 3100 1st Series |
12-18-2014, 09:57 AM | #23 |
Re: My 52 GMC Build
Got the frame and axle painted. Starting to look like a truck
Thanks Wide load c-30. Its a HX35 from a cummins. I found its a good size for what I'm doing. I'm running 3" mandrel bent sst out the side. I have an electric 35 gph fuel pump. Other than that I'm just turning up the lift pump. For the trans I put in a Transgo tugger kit. It was rebuilt about a year before I got it. I'm also using a US Shift Quick 1 controller that allows me to control anything the trans can do. Its going to be manual shift auto. I've looked into a cam but I want to see what the stock set up will give me first. My goal is 300hp and 500lb-ft if I get close to that I'll be happy, but who knows down the road I may do a full motor build.
12-24-2014, 01:12 AM | #24 |
Re: My 52 GMC Build
Amazingly my steering shaft missed the motor without any major mods. I moved the end if steering column over to the drivers door 1.5" and am going to center the column between the gauges.
12-29-2014, 01:33 PM | #25 |
Re: My 52 GMC Build
Finally got a vid put together, showing what I have done so far and motor running. Enjoy
http://youtu.be/N0C3SOCJPCA
Tags |
bagged, build, diesel, gmc, hot rod |
