Old 11-03-2014, 09:39 AM   #1
lower50's
lower50's's Avatar
My 52 GMC Build
I have always wanted a early 50's GMC P/U and 8 years ago I found it, A 1952 GMC 9700 that used to be a fire truck in great shape. Just cab forward no motor or trans, but all I wanted was the body to make a hot rod.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 11-03-2014, 09:46 AM   #2
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Took the 52 cab off the frame. Bought a 1989 s-10 extended cab P/U for the frame only stripped it apart sandblasted frame and primed. Then mounted cab to S-10 frame, there it sat in my garage for 6.5 years. In that time I was planning what I wanted to do.
1951 MG TD
Old 11-03-2014, 09:52 AM   #3
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Spring of 2013 I was ready to start on my 52. The truck had been built in my head for some time now, even drove it in my dreams a few times. As some of you can relate i'm sure. I wanted to make it different in most ways but wanted it to look like a 52 GMC P/U
1951 MG TD
Old 11-03-2014, 10:35 AM   #4
Highsider
Highsider's Avatar
Re: My 52 GMC Build
I can't wait for the next chapter!
Love having the photos.
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 11-03-2014, 01:03 PM   #5
lower50's
lower50's's Avatar
Re: My 52 GMC Build
My neighbor gave me the a motor, trans and axle from a 1994 e350 cube van. I wanted to put a diesel motor in, so this was perfect. 7.3L IDI International diesel. So first step clean up motor and build it to take what I wanted to do to it, then mount it in the frame.
1951 MG TD
Old 11-03-2014, 01:06 PM   #6
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I wanted air bags on all corners to get running boards on the ground. D.O.M. tubular A arms should take the weight of the 1000 lb motor .
1951 MG TD
Old 11-03-2014, 01:10 PM   #7
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I boxed in the frame and added a cross member just behind the cab. I built the transmission with some upgrades and shift kit so it can take the extra hp and tq .
1951 MG TD
Old 11-03-2014, 01:14 PM   #8
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Then I rerouted the exhaust to add a turbo to my N/A motor the plan is inter-cooled 15-20 psi should give me 300 HP and 500 LB/tq
1951 MG TD
Old 11-03-2014, 01:17 PM   #9
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Cab mounted on frame with trans. hole cut. Then I got the cab sand blasted and primed
1951 MG TD
Old 11-03-2014, 01:24 PM   #10
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Then the plan for the rear end is to run the dually from the cube van with car tire. But I still want to keep the P/U look so it is out right now to get shortened 21". I am going to build the back half of the frame, also triangulated 4 link with air bags.
1951 MG TD
Old 11-03-2014, 01:26 PM   #11
Daze57
Daze57's Avatar
Re: My 52 GMC Build
wow !
Daze57 is offline   Reply With Quote
Old 11-03-2014, 01:30 PM   #12
lower50's
lower50's's Avatar
Re: My 52 GMC Build
That's all I have now till the axle comes back. I'm doing most of the work myself, with a bit of help now and then from friends. It's also all seat of your pants engineering.
1951 MG TD
Old 11-03-2014, 03:05 PM   #13
shopteacher
Re: My 52 GMC Build
NICE< Real NICE !!!
shopteacher is offline   Reply With Quote
Old 11-03-2014, 09:01 PM   #14
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 52 GMC Build
Great project, and cool build. I can tell you from expreience, don't give that 7.3 more than 14psi of boost or you will get good at swapping engines. You need to install bigger wrist pins to go above 14psi of boost. They're great engines besides that little deal.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-03-2014, 10:35 PM   #15
lv2tri2
Re: My 52 GMC Build
What a cool project, I will watch this to the finish if you keep the pics coming.
lv2tri2 is offline   Reply With Quote
Old 11-04-2014, 09:36 AM   #16
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks Dieselwrencher good to know!! I put ARP head studs and good feelpro head gaskets in to hold the heads on. I was planning to run 15psi on the street, then 20psi on the dyno and once and a while on drag strip.
1951 MG TD
Old 11-04-2014, 09:37 AM   #17
lower50's
lower50's's Avatar
Re: My 52 GMC Build
How can I post a video?
1951 MG TD
Old 11-04-2014, 06:06 PM   #18
Dieselwrencher
Re: My 52 GMC Build
Post it to youtube than copy and paste the link in your message.
I put 30psi to a 6.9 at 4200rpm pulling for a summer. I couldn't blow it up. The next owner though, got it accomplished. Haha
Ryan
Old 11-05-2014, 11:14 AM   #19
lower50's
lower50's's Avatar
Re: My 52 GMC Build
That 6.9L must have pulled hard
1951 MG TD
Old 12-08-2014, 10:11 PM   #20
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Friday I got the axle housing back. Then put it all together and lined it up.
It looks sweet being so short!! Its a Dana 70HD
By Saturday night I had figured out how I was going to be able to build the back frame, so it would work with the suspension and axle. Got the steel cut and tacked then ran out of welding gas
Sunday got the frame welded up. Then put truck at ride height about 5". The brackets for the axle in the 4 link kit where for a 3" tube mine is 3.5" so a bit of grinding opened it up. Ready for Monday
Monday got 4 link figured out and welded all but top frame brackets, thats tomorrow. Then air bags
1951 MG TD
Old 12-09-2014, 03:48 PM   #21
Dieselwrencher
Re: My 52 GMC Build
Nice work, it's really coming together.
Ryan
Old 12-09-2014, 08:14 PM   #22
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks. Ya so happy!!
So today I got upper front brackets on and made and mounted lower air bag plate.
1951 MG TD
Old 12-09-2014, 08:46 PM   #23
shopteacher
Re: My 52 GMC Build
I'm Liking where this build is going ! Keep up the good work !
Old 12-09-2014, 11:14 PM   #24
alaska gasser
alaska gasser's Avatar
Re: My 52 GMC Build
Not throwing any rocks, but I'm wondering if that 4 link is going to work properly and safely with the upper bars at that angle instead of straight above the bottom ones?
http://67-72chevytrucks.com/vboard/s...d.php?t=592642 '48 Chev extended cab with attitude
http://67-72chevytrucks.com/vboard/s...d.php?t=592769 My daughter's '46 International PU
alaska gasser is offline   Reply With Quote
Old 12-09-2014, 11:28 PM   #25
lower50's
lower50's's Avatar
Re: My 52 GMC Build
No worries. Its a double triangulated 4 link, its used to keep the axle centered in the frame more. 4X4's use it in extreme. I had to use it due to my limited space and not enough angle left and right. Didn't want a pan hard bar. I talked to the shop that shortened my axle. The only down fall is it increases the height of my roll center. The truck will lean in the corner more but i figured with a 1000 lb motor up front I don' think the back will do much.
1951 MG TD
bagged, build, diesel, gmc, hot rod
