10-25-2016, 03:42 PM | #1 |
Moderator
May Have Found Deluxe Seat Foam :)
I was looking at the seat foam I have for my truck. It came from a Custom Cab so the seat foam is full foam.
The number on it says 3187055. I search GM Parts Wiki and found in the 1969 page (among others) 3817055 fits 1969 bench seats. Am I reading that wrong? http://www.gmpartswiki.com/getpage?pageid=219986 Cause if it's right . . . And in the 1976 parts catalog it says it fits 65-68: http://www.gmpartswiki.com/getpage?pageid=62700
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 10-27-2016 at 03:42 PM. |
10-25-2016, 11:49 PM | #2 |
Ol' Blue Viking
Re: May Have Found Custom Seat Foam :)
Wow, thats cool
Driving Paw-paws truck into the Sunset! |
10-26-2016, 08:24 AM | #3 |
When reading the parts book you have to included the sentence above also where it says 62-68 Cab W full Foam Seat
69 Cab .....3187055 The full Foam seat was also available for standard seats.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
10-27-2016, 10:28 AM | #4 |
Moderator
That's exactly right full foam.
10-27-2016, 10:32 AM | #5 |
Moderator
This seat frame.
10-27-2016, 01:05 PM | #6 |
Does the foam from later models work on 64-66 seats. If so standard or deluxe?
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
10-27-2016, 03:14 PM | #7 |
Moderator
That's what the question in post #1 is about.
The Deluxe seat is the Full Foam seat shown in #5 above. The standard seat has straight springs front to back of the seat frame.
10-28-2016, 10:28 AM | #8 |
Moderator
So the foam would be this?: https://www.tuckersparts.com/67-68-C...ion-only..html
Looks like the foam bottom I have:
10-28-2016, 01:09 PM | #9 |
Just a note--not for 60-61. 62up as you have posted. my seat base is different and my tk has the custom comfort op. It had the cloth cover also (found a few pieces) my seat base is flat.
1961 chevy K10 my build is------------61K10 build |
10-29-2016, 03:40 PM | #10 |
Moderator
Man I thought I'd get a bunch of kudo's (Bravo Zulu's) on this one. I guess everyone already knew? Expect me. I'll go back to sleep.
10-29-2016, 04:54 PM | #11 |
Check The Champ, Demonstrator
KUDO's to ya Bud,
didn't know that fact. It takes someone to ask the question in order for the research to be done.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
10-29-2016, 11:57 PM | #12 |
Airport Bum
I was excited to see this, Master Chief!
Nothing worse than a nice truck with a crappy uncomfortable seat.
1964 Chevrolet C-10 1941 Chevrolet coupe 1962 Thunderbird 1959 Edsel Villager 1963 Skylark |
10-30-2016, 12:38 PM | #13 |
I don't think most knew about this. Not much info about seat springs and foam, just what fabric pattern and color. So thanks for posting.
10-30-2016, 12:56 PM | #14 |
Kudos for this great info find Rocknrod!
I know this will help many others, Thanks.
MusicMan70 1961 GMC Suburban |
10-30-2016, 01:55 PM | #15 |
Thank You, Thank You. You just saved me a ton of time. Was just starting to look for foam with ZERO results.
10-30-2016, 04:24 PM | #16 |
Moderator
Ya there is no info anywhere I can find on the full foam seats either and the aftermarket sellers cannot address the issue. I was just lucky finding that number I guess.
10-31-2016, 12:47 PM | #17 |
So lets go one step further. Is there two types of seat base springs? 62-up? the one you show is not flat but recessed for the thick foam.
10-31-2016, 04:21 PM | #18 |
Moderator
Here is a great post that shows the difference in the two types of seat springs:
http://67-72chevytrucks.com/vboard/s...78&postcount=2 The better post: http://67-72chevytrucks.com/vboard/s...23&postcount=7
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 10-11-2017 at 09:43 AM. |
10-11-2017, 12:37 AM | #19 |
So if I currently have the standard seats, I can use this full foam replacement on my seat frame?
1965 Chevy C-10 350 V8 2003 GMC Sierra Crew Cab 6.0L 4x4 |
10-11-2017, 08:41 AM | #20 |
Moderator
No.
10-11-2017, 09:25 AM | #21 |
What do you think of it's quality? Made in USA?
Good to know same as later year trucks. Thanks, Les |
10-11-2017, 04:20 PM | #22 |
10-11-2017, 09:40 AM | #23 |
Moderator
Some info on standard seat foam. http://67-72chevytrucks.com/vboard/s...d.php?t=640827
We should start a thread on Standard Seats maybe?
10-11-2017, 10:36 AM | #24 |
great info rocknrod,so this should fit my 66 with deluxe seat?an extra 10% off at
tuckers right now too!pulled my seat apart and foam has number 3816940 thanks for the info! |
10-11-2017, 11:35 AM | #25 |
Moderator
That's my opinion. Haven't heard anyone say otherwise. Can't seem to find your part number in the GM parts Wiki. Make sure your lower seat springs look like post #5, not straight from front to rear. Ya the lower foam is only $130'somethin bucks right now. If I had a job I'd buy it.
