07-02-2018, 09:49 AM | #1 |
Help a NOOB - A continuing saga
Hello all, first time posting, after a long time lurking. Great site, with lots of knowledge and advice!
I'll try not to get too wordy with this, but I want to provide a short history of my trials and tribulations with a 1972 C-10. I inherited the truck just about 2 years ago now, and had it shipped from AZ to NC where I now reside. It ran when I got it, though not well. I remember having to drive it home a few blocks from where the car hauler could drop it off, and I had to put it in neutral at intersections so I could rev it up a bit so it wouldn't die. I didn't do much to it, as I am NOT a mechanic. Changed the oil, tried to clean things up a bit so I could see what I was looking at. Made some small idle adjustments so it would run semi-smooth. I drove it rarely, as it was more stressful than enjoyable. It pretty much sits in the driveway, and I would start it three or four times a month. I knew I had carb issues, as every once in a while it would drip gas when I tried to start it. My solution was always to pull the filter out and give a couple squirts of carb cleaner into it. Temporary I know, but always worked, so I could at least start the thing. Two things in particular I wanted to figure out. There was always a slight ticking under the drivers side valve cover, it would come and go. And the thing smoked like crazy. White smoke; always seemed more on the drivers side to me. Anyway, I just kept starting the thing. Added rislone to a few oil changes, thinking if something was just "sticking" that might help. And I was basically too much of a chicken to even take a valve cover off and have a look. I have no experience doing any of this, and also have a history of making things worse when attempting to do this sort of stuff. Time for a bit of honesty here. Being white smoke I suspected (feared) head gasket issues. So I tried a bottle of that Barr's leak fix stuff. Now I don't think this could have hurt anything, but I could be wrong. Something more severe did occur within the next few weeks. One morning I started it, and it started backfiring. I didn't run it long, but it was long enough. Dejected I know I was getting nowhere, so I called an auto repair shop to come and pick it up. I'm not originally from the area, and have only owned newer vehicles while living here. So I had to roll the dice with the choice of mechanic. I mean I asked around, and looked up what reviews I could find, but it was still just a shot in the dark really. The day they picked it up, they called me back within about two hours with a report. What they had found were two SEVERELY bent push rods. We talked about how everything else looked in there, and how much the repair would be. I didn't want to start putting money into a repair, and have to have it torn open again later. But the guy said everything looked good, and for a couple hundred bucks he'd replace the pushrods. On reassembly he said he would adjust all the rockers, and check the timing. I was pleased with how quickly they got back to me. But, I think that first day they had the truck was the ONLY time they called me. I called them that Friday before they closed for the weekend. No parts yet but should be early the following week. I was out of town for work that next week. Never heard from them, so I called on Friday again looking for an update. I had to stop them half way through, when I realized they were not even talking about my truck but some other vehicle. But the report was that it was done, but not running well. They said something was wrong in the motor, and the labor required to get to it, find it, and fix it, might mean a new motor was the best option. I didn't want to make that decision without thinking about it, and thinking about how to make it work money wise. So the following week I went to pick the truck up. The mechanic took me out to the truck, and tried to start it. It wouldn't start, popped the hood and he tried to start it again. Gas was leaking out of the carb, it wasn't happening. We went back inside and got the owner of the shop out to look at it. But the battery was pretty much done now anyway. SOOOO they talked about a number of things, but the carb needed to get fixed first. Which I agreed with, I knew it would need to be rebuilt at some point. Might as well be now. So they said $300 to rebuild it, and I just said fine. Another Friday comes along and I hadn't heard from them. I didn't get to call them in time before they closed. So I called during the day early that next week, and sure enough they said it was done a few days ago. So I go to pick it up, pay them close to $800 and they hand me the keys. I had a heck of a time starting it, and it was running very rough. Any throttle would cause coughing, spitting, backfire out of the carb? I looked around, and noticed the plug wires on the passenger side laying on the exhaust manifold. I shut it down, moved the wires, and went in to get some zipties or something. The owner came back out with me, and I showed him the wires and asked for something to tie them up. While I was showing him, I noticed the 6 wire wasn't even on the plug. I was disappointed to say the least. I just wanted out of there. He plugged the wire in and tied up the wires. Unfortunately it only ran nominally better when I started it again. But again, I just wanted out of there. It died the first few times I tried to pull out on the highway. I took a little longer route home on some back roads where I could limp along. It was smoking like crazy, and coughing/missing quite a bit. It was hot, I was upset, and stressing about getting home. I will say that it ran a little bit better further into the ride. Anyway, I made it home, and didn't even want to look at it. What to do next? I decided to take some baby steps. I have no confidence remember. On the way home from work I bought some plug wire clips to route them more properly, and borrowed a compression tester. The next day I pulled all the plugs, to do compression test. Plugs looked pretty nasty. Compression test seemed positive to me. Pretty much 120 PSI across the board, with an odd 115 or 125. Got 130 once, but retested and got 120. I'm hoping this tells me things aren't hopeless at least as far as rings and valves go. The next day I went to buy new plugs. BTW has anyone else struggled getting to the #4 plug? There was no way to get a socket on it with the exhaust manifold. I finally puzzled a way to sneak a box wrench on it and get a small turn at a time. When I went to get the plugs I found a set of those thru-sockets they use for long bolts. The plug slid through that, so it worked well to put #4 back in. I measured all the old plugs. And they were a consistent .9mm gap (about .035). So that is what I gapped the new ones to. I then tested each new plug on its intended plug wire for spark. Everything looked good, so I put them in with a little anti-seize and connected all the wires back up. Was all set to start it up... and the battery was dead from all of my tests I guess. Left it on a charger over night to try again the next day. Next day, it starts. Not running all that well. And anything but the gentlest application of throttle caused it to "caugh" or miss or bogg or whatever that is. Noted that the 'tick' I used to hear did seem to be gone (probably valve/pushrod related). I also looked around the carb and noticed an unplugged vacuum port. If I put my finger on it the rpm would change and it would sound different. I don't know about better but different. I also saw that my choke was not connected. The clip holding the bar to the linkage was gone. Once I shut it down, I looked at the carb some more and discovered the hose for the choke vacuum canister (cutoff?) was tucked under the fuel inlet but not actually plugged into anything. Looking on-line I think it should go to the port right above/behind the fuel inlet which was plugged. So I hooked it up there, and used that plug to cover the port I noticed was open. This port is straight out of the passenger side of the carb. When I restarted it, I was actually pretty pleased. I would say that it was probably the best I heard it running since I got the truck. A few hours later, however, was a different story. I had fashioned a clip out of a beer can and connected the choke back up to the linkage. I had also checked the oil, and added a little. I think that's all I did, and the darn thing was difficult to start. And I had to feather it or keep some throttle to keep it running. I can't think what could be so different from when it ran fairly well a few hours earlier. I shut the hood frustrated again. Sorry this is such a long post, but I wanted to share as much "history" as I could, before humbly asking for any advice/support. I had planned on putting my timing light on it next, but if it runs like it did the last time, that seems pointless. Any thoughts or advice for a NON mechanic? THANKS! |
07-02-2018, 10:19 AM | #2 |
Proprietor of Dale's Corner
Re: Help a NOOB - A continuing saga
You need find a friend with some experience to help to you some basic diagnostic stuff. Does it still have points or was it converted to electronic ignition? You also need to recheck everything the shop messed with to insure it was done correctly.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
07-02-2018, 10:47 AM | #3 |
Call me crazy ,But wasn't this "saga " posted before about a year or two ago ?
07-02-2018, 10:54 AM | #4 |
07-02-2018, 11:39 AM | #5 |
The Older Generation
Sounds like the fuel filter sock might be plugged or deteriorated in the tank. It is on the end of the sending unit fuel pickup tube.
07-02-2018, 07:26 PM | #6 |
I have never heard of this filter sock. I assume this requires draining the tank somehow to remove the sending unit to have a look?
07-02-2018, 10:44 AM | #7 |
Active Member
Hi and good morning! Welcome to the place. I'm not savvy on diagnosing issues, but I'll be interested to hear what other members have to say. There's a lot of good people out here that know a lot and have helped me through changing the motor on my 72.
The Dude abides. |
07-02-2018, 11:38 AM | #8 |
Impressive. I never considered using the container as an excuse to pound a few for a project. Sorry I'm not able to offer any incite or assistance to your plight, but I shall use your example as an excuse to ingest more alcohol. "Honey, fetch me a few beers, I need to drink couple to fab parts for the project."
Stupidity was meant to be painful! |
07-02-2018, 11:51 AM | #9 |
Where’s the pics?
Some pics of your motor from several angles would help a lot. |
07-02-2018, 12:06 PM | #10 | |
To answer an earlier question, I am pretty sure I am dealing with points. I did some more searching for similar "saga's", and one I read made me remember something else. When I started it last, before calling it for the day, I remember my eyes burning the fumes were so bad. I may just disconnect that choke lever that I reattached, and see if that changes things. Thanks for the feedback. |
07-02-2018, 02:51 PM | #11 |
Youtube can be your friend especially ff you aren't afraid to turn a wrench. Sounds like you aren't. You can learn a lot and do it yourself.
Fire, Fuel, Air. That's what makes her chugga chugga. Sounds like you had a vacuum leak. Open port at the base of the carb. Maybe a stuck choke. That will make you run rich and burn your eyes. You picked the right vehicle to learn on! Take pics, post questions! Don't be afraid to take the valve covers off! We are here to help! |
07-02-2018, 07:47 PM | #12 |
My "guess" would be you need new points, condenser, rotor button, distributor cap, fuel filter, and probably a new carb. I would get someone I could trust to take a look at it before spending any more money though. Sometimes you can just file the points and reset them to get by for a while but few mechanics know how to set points anymore.
The shop you went to was a rip off. just saw your pictures, definitely points. Also looks like the motor was replaced with a GM crate engine. |
07-02-2018, 08:46 PM | #13 |
Who Changed This?
Let me get this straight. They rebuilt the carb to the tune of $300 and it's leaking fuel? Tack them to a tree for stealing your money. You should go ask for a refund, and if you don't get it, go to your state's version of the Bureau of Automotive Repair.
07-02-2018, 08:59 PM | #14 |
First of all I commend you on the work you personally have done so far. You have done more to fix your situation than the shop it was at. Keep being methodical and purposeful. Even compression over 100 is a great engine vital sign. Search Youtube about timing, points, condenser, and dwell next. At that point you should be seeing some improvements. Then air/fuel/vacuum is next on the agenda. Have confidence and know upfront it is three steps forward and two back sometimes. Keep asking questions, invest in simple quality hand tools, and may you not round off bolt heads, cross threads, and put things back the way the factory intended.
07-02-2018, 09:21 PM | #15 |
Trust me, I am not happy with the shop it was at. But I have yet to get a good referral.
I think, though, that if its a gunked up tank that is the problem and maybe the needle not seating because something got in there. Would that eventually cause fuel to seep out somewhere, even after rebuild. I really do not know. A few of you have focused on the ignition. I will try to do some reading and maybe look at the distributor on the 4th when I am off. I wasn't really thinking that since it ran so good (that ONE time) after I changed the plugs and all. And I did check each for spark, with its dedicated plug wire. Thanks again for all the help. I'll keep plugging away. |
07-03-2018, 01:21 PM | #16 | |
EDIT: Found the paper work in the manual the other day. It was early 2002. Did some YouTube learning about points last night, might get into it tomorrow. Thanks! Last edited by ncpetersc; 07-05-2018 at 08:05 AM. Reason: Found date new motor was purchased. |
07-03-2018, 04:50 PM | #17 |
Kung Fu Master
Be nice to get a timing light on that and see where you are at. For some reason it looks like it's severely retarded, the timing that is, or the dist is off a tooth.
72 GMC SuperCustom 4x4 1972 Chevrolet Cheyenne Super 4x4 |
07-03-2018, 05:28 PM | #18 |
Moderator
Sad to see a noob or anyone for that matter, seek professional help only to get ripped off....
The plugs pic tells me straight away the engine is too rich...way to black on the electrodes. Overhauling a Quadrajet is always a risk...and $300 is a joke...new Edelbrock 1905 retails at $318... I am in NC but west of Charlotte, but am more than willing to help you out via this board... You will need the following tools...a compression test gauge, a timing light and if possible, a dwell meter. Please remove the spark plugs and taking a compression test of each cylinder...post the results on here... Go to your local auto parts store and purchase a new set of points and a condensor...AC Delco part # is ACDELCO D116 {#19106521} I would also replace the distributor cap...but dont replace the cap just yet... Post the results of the compression test here and we will get you right. We need compression figures first to determine if there may be a blown head gasket or poor compression thru burned valves etc. Stay cool dude...Aussie Bill |
07-03-2018, 05:38 PM | #19 |
Moderator
Just noticed in your pic the distributor appears to be one post off on its installed position...someone has obviously had the dist out and been sloppy putting it back in...Cyl # 1 wire usually points direct at Cyl 1...drivers side front...yours points at Cyl 2...
Just post the compression readings and we will go from there... |
07-02-2018, 09:58 PM | #20 |
Fuel seeping out isn’t always caused by a leaking needle/seat or a float problem.
A lot of times it’s caused by the person pumping the crap outta the pedal to try to get it to fire. All that pumping sends a big shot of fuel into the inside of the carb. If your choke worked, you likely won’t need to overwork the pedal. Likely your inexperience is causing the seeping. Don’t fret, I mean no harm. Just pointing out one of the ways you’ll see seeping. We’ve all been guilty of the same action. You need to get your choke working. |
07-02-2018, 10:40 PM | #21 |
Junior Member
Also you're using a divorced choke and it appears in the pix that the rod is not connected to your linkage.
07-03-2018, 07:16 AM | #22 | |
The actual rod feels like it is rubbing the cover when connected, so I thought maybe the friction was preventing the linkage from behaving properly. I think I need to bend it some to try to eliminate the rubbing, but I will reconnect it. |
07-02-2018, 10:53 PM | #23 |
Were you able to see or tell where the fuel is leaking from?
The fuel leaking out isn’t nessasarily “the problem” if that makes sense. It is a problem but might not be what’s making it run poorly.
1951 GMC 250 Open Express Pickup 1968 Suburban C10 1971 C20 Olive “People are shocked when they find out I’m not a good electrician” Dad told me “Son, never strike a man in anger- unless you’re certain you can get away with it” |
07-02-2018, 11:20 PM | #24 |
Who Changed This?
If I was on your side of the continent, I could lend a hand. It just grinds my gears that stuff like this happens and the owner can't get decent help.
07-03-2018, 07:19 AM | #25 | |
Incidentally, I am going to have to get some pics up of the whole truck, because MAN it's almost a clone of the one in your pic. |
