12-04-2018, 05:31 PM | #1 |
AC/Heater housing sticky stuff
Working on a previous truck, it had this gritty rubbery stuff insulating the housing where the two came together. I removed it while working on it and then misplaced it.
Any ideas what this stuff is so I can get some more?
1972 C10 LWB 2WD 307 4 speed Rescued from Field July 2017 |
12-04-2018, 05:34 PM | #2 |
Re: AC/Heater housing sticky stuff
Parts stores sell it. Getting the sales person to look for it in a book may be a challenge, depending on where you buy parts.....
12-04-2018, 05:52 PM | #3 |
motor exploder
O'Reilly sells it in a 30' roll. Murray #59010 - I used it on my '65 Bel Air this summer when I rebuilt the a/c system. If you go in there and ask anyone born after 1980 about it, they probably won't know what you're talking about!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 12-04-2018 at 06:01 PM. |
12-04-2018, 06:23 PM | #4 |
Butyl tape, is what it's called, comes in flat 3" wide 1/4" thick, all the way down to rope strips, 1/8" around... stretches, squishes flat to seal when clamped between 2 surfaces... gummy all the way thru..Most of the time its gray, but can be found in black.
12-04-2018, 08:08 PM | #5 | |
3M 08578 Black 1' Strip Calk https://www.amazon.com/dp/B000PEZ1L4..._CAXbCbT8GHWNF
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
12-04-2018, 06:26 PM | #6 |
Strip caulk from 3m
12-04-2018, 07:26 PM | #7 |
I think Boss Hogg has it up on top.
Looking online with the words insulation tape I found a couple of websites of 72 Gran Torino Sport 17 year Barn nap find and a hot rod installing old Air Products hurricane heat and AC hot rod Network. Had pictures of it. So it's looking like that's what I need. I really do appreciate it guys!
12-04-2018, 07:39 PM | #8 |
Yes its called Butyl tape it comes in a varity of forms,but the tape type is what you want , if you have a hard time finding it you can always find it at your local HVAC supply house or roofing supply that carries flashing and or metal roofing.
12-04-2018, 08:26 PM | #9 |
Attached is what this stuff looks like. It's certainly not grey butyl to hold in an RV window that's for sure. Is the grittiness that's in it from Cork?
12-05-2018, 04:58 PM | #10 |
...on Ebay.... $8.99...Camaro air conditioning insulation wrap, evaporator core upper tube.
12-05-2018, 08:40 PM | #11 |
I work in HVAC. We use same stuff. It is also called cork tape. What I use comes on a roll about 2" wide. It is just a sealer that does not come loose if it gets wet.
12-05-2018, 10:39 PM | #12 |
Awesome thank you guys I was wondering if it was that cork stuff?
12-05-2018, 10:58 PM | #13 |
You can get it from NAPA
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
