Old 05-19-2019, 10:54 PM   #1
65 GMC
1965 C10 Long Stepside
I picked up another one last week. Its a 65 C10 Long stepside 283 with a 4 speed. Its a very solid truck with minimal rust staring in the outer rocker panels and lower front fenders. The motor was out and sitting in the bed, I was told it was pulled when some wiring by the distributor caught on fire. Motor turned over good and has decent compression so I dropped it back in. Hopefully I will have it running next weekend.
65 GMC is offline   Reply With Quote
Old 05-20-2019, 08:45 AM   #2
Clyde65
Clyde65's Avatar
Re: 1965 C10 Long Stepside
Cool project!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-20-2019, 11:52 PM   #3
Lil Loafer
Awesome! There are not enough long stepsides out there.
1966 c10
1937 Willys truck
Lil Loafer is offline   Reply With Quote
Old 05-20-2019, 11:54 PM   #4
shp4man
shp4man's Avatar
Nice! Like those long steppers.
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 05-21-2019, 07:47 AM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Very nice, can't wait to see it on the road.
Old 05-21-2019, 08:00 AM   #6
65 GMC
That's 2 of us. Plans are to pretty much just leave it as is and make it safe and reliable first, including a complete rebuild of the brake system. Keep it running while I do other things, like fix up the interior and replace the missing bed wood. I don't plan on doing anything with the body, it has neat patina . Hope to have the engine running this weekend.
Old 05-21-2019, 08:49 PM   #7
Bushman66
Great truck! Almost a mirror image of my truck (except mine has a 292) and my PLAN to get mine safe and running. Keep running into little roadblocks, but brakes are done, cooling system is done, steering column is rebuilt and safe and new exhaust (old one was rusted, held on with baling wire and rubbing on the driveshaft).
It's running, but the head needs to come off (smokes like crazy...hardened seals), the wiring needs to be completely redone, and the carb needs a rebuild. Windshield and rear window will be installed next week. Bed wood and new rails waiting to go in.
Good luck with yours, and keep us up to date!
Bushman66 is offline   Reply With Quote
Old 05-27-2019, 08:14 PM   #8
65 GMC
I got the motor back in the truck, I have had it running by pouring gas down the carb. This thing has fought me every step of the way. First I had no fire due to some dirty points, then the fuel pump wouldn't pickup fuel. I replaced the pump and then the carb was flooding out and dumping fuel down the engine. At this point I was frustrated and decided it was time to walk away for a while.
I found another carb and took it apart ,sprayed everything out and made sure it was working as it should. I will try to get it on, and fire it up later in the week.
Old 05-28-2019, 06:15 PM   #9
plmadding
Great looking truck! I'm going through replacing every piece of the brake system on my '66 C20. Just prepare yourself for more frustrations!
plmadding is offline   Reply With Quote
Old 05-29-2019, 11:03 PM   #10
65 GMC
Got it running this evening. It holds 30+ pounds of oil pressure warm at idle, and runs smooth. It makes no unusual noises, and rpm's pick right up when you crack the throttle. Now that I'm fairly certain the motor is good I can move on to other things with it.
Old 05-31-2019, 12:23 AM   #11
plmadding
That is great news!
Old 06-01-2019, 10:35 AM   #12
65 GMC
The KHP did my VIN inspection last night, all is good. Now I can send off for a title on Monday.
Old 06-07-2019, 03:03 PM   #13
65 GMC
I hit a snag with the paper on this one. Turns out it was still in the "system" so I have to have a title. I bought the truck from a State Trooper, so I'm sure I wont have any issues. Just have to wait for it to get done.
Old 08-04-2019, 09:55 PM   #14
65 GMC
Been awhile since I updated this. So far I have completely rebuilt the brakes, and front suspension. I have bead blasted and repainted the wheels white, it will be running narrow white wall tires with reproduction 64-66 chrome hubcaps and trim rings.
I drove to Kansas City last Monday and picked up a oak bedwood kit and new steel bed strips, along with a bunch of other parts while I was up there.
This weekend I replaced the rear axle shaft seals, cover gasket, replaced all 4 shocks, and bled the brakes. I still need to schedule a front end alignment and have the tires balanced.
In the coming weeks I will be finishing the bed wood and getting it installed. Then I will be busy getting some of the lighting problems ironed out, and plan to pull the engine back out to clean it up, reseal and repaint it before dropping it back in.
I will try to post some better outdoor pictures of the truck later in the week. But I'm making pretty good progress.
Old 08-04-2019, 10:10 PM   #15
65 GMC
Can a moderator move this to the project section?
Old 08-05-2019, 12:16 PM   #16
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Good Looking Truck, Any update Pics??
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 08-05-2019, 10:39 PM   #17
65 GMC
This evening I was able to change the oil in the transmission, put oil in the rear axle, and removed the track bar so I can replace the bushings. Here are some updated photos, along with a good photo of my wheel choice.
Old 08-05-2019, 10:48 PM   #18
65 GMC
As you can see I have some small areas of rust. I have mixed feelings about fixing it. I'm afraid that I will lose the patina that this truck has. The interior is in bad need of a cleaning, the floor looks like they spilled a gallon on used motor oil on the floor. What a mess. But it will get new black carpet, along a recovered seat and visors once cleaned up. I plan on leaving the painted surfaces inside alone, I think it will give it some character.
Old 08-05-2019, 11:50 PM   #19
Captainfab
60-66 Nut
Regarding the rust areas. I would leave them alone except for cleaning out behind them so they don't get worse sooner rather than later.
Old 08-06-2019, 08:52 PM   #20
65 GMC
I dropped the seat and visors off to be recovered after work today. He is really busy right now, so it may be a few weeks. But that's no problem I won't need it for a month or two. I also cleaned up the track bar this evening so I can install new bushings in it. Going to try to schedule the alignment and tire balancing next week.
Old 08-08-2019, 11:32 AM   #21
roll_the_dice
roll_the_dice's Avatar
Nice find! Love me some LWB steppers!
roll_the_dice is offline   Reply With Quote
Old 08-17-2019, 04:41 PM   #22
65 GMC
I had the 65 lined up this morning and the tires balanced. Then took it over to a friend that installs auto glass to replace the windshield gasket. We took the old cracked windshield out and was going to put in another used one out of a truck I parted out earlier this year. The replacement windshield cracked when they put suction cups on it to lift it into place, another one was ordered and the truck is sitting in their shop until it arrives on Monday. So I guess now is a good time to start on the bedwood. The seat is still in the shop being recovered, I will check on it later in the week.
Old 09-09-2019, 10:50 PM   #23
65 GMC
I've been busy on the 65. In the last few weeks, I have finished and installed the bed wood. Sorted out most of the wiring issues, the tail lights are not working after the bedwood installation. I installed rubber pads between the bed and frame, so I think a couple of grounding straps will solve the issue. The seat is still in the shop waiting to be recovered. I will be pulling the 283 out later in the week to get it cleaned up, resealed and painted. Then once its back in and the truck is up and running again I will start getting the interior ready for when I get the seat back. I will get some updated pictures later in the week.
I still need to decide if I'm going to convert to power steering or if I buy a rebuilt manual steering box. I converted my 64 C20 and 65 GMC but I'm not sure I want to convert this one.
Old 09-11-2019, 09:57 PM   #24
65 GMC
Here are some updated pics
I plan to pull the engine out Saturday afternoon, so I can get cleaned, painted and resealed. Should have my seat back the middle of next week. I will post some pics of it when I get it back.
Old 09-19-2019, 09:56 PM   #25
65 GMC
I was able to get the engine out and have been busy getting it cleaned up and painted. I picked up the seat and from the upholstery shop. I'm very pleased with the results. The vinyl is original to 1964 Chevelles but the cloth is from 2009 Ford F150 pickups. Now to get the engine back in and running. then on to the interior.
