New GM crate 350 for the '63
Good evening,
Bought my 63 step with a 327 and 3 on the tree this summer. Didn't get to drive it much before the 327 gave out. Just got my 290 hp GM performance 350 crate and everyone says my intake and carb will work from the Sbc 327, the 327 intake has the oil filler neck and spring running to the carb, I have not seen this on a 350. Looking for input on if this will work on the new engine. And yes, I am a Noob. Thanks, love the site and the posts people share. Jim |
60-66 Nut
Re: New GM crate 350 for the '63
Yes the intake manifold from your 327 will bolt right up to your new 350, as well as most everything else like the water pump, pulleys, starter, flywheel. They are both Gen I small blocks.
thank you, the engine will then have two oil fill points and a pvc as well as the vented oil cap at the top of the tube. Any issues with that?
Is one of the oil fill points a breather?
You need a Pcv on one cover and a breather on the other cover. If you have that you can remove the oil fill tube and plug the hole. IIRC a core plug is the same size. You want to draw the air thru the motor from one side to the other so you remove as much of the fumes and moisture as is possible. |
#5 | |
#6 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=366830 |
Thanks for posting the thread Geezer. I will look into that idea.
And if you don’t want to put a hole in your 283 covers, depending on your style of intake, you can put the pcv valve right in the intake between the distributor and the carb on a flat spot. Use a baffle/grommet to keep the oil in the valley.
Some intakes have a flat area you can drill a hole into, some don’t. |
Moderator
![]() ![]() Join Date: Aug 2011
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I like the oil filler tube for the look and convenience.
![]() Join Date: Feb 2010
I dont have pics on my new puter, but i had an older Edelbrock performer intake and it had the pad in the front for the oil fill tube, so i just drilled it out.
I've got that same engine in my '61 Suburban, and put almost 100,000 miles on it in about 8 years.
Here's what I did for the PCV system: Stock chrome 327 valve covers, no vents or breathers. Vintage Edelbrock intake with oil fill tube provision. Stock '62 passenger car/california emissions sealed oil fill tube--this has the screw-on cap, and a threaded port on the fill tube. I ran a screw-in PCV valve in the carb's base plate vacuum port, connected to the port on the fill tube (with a brass screw-in hose fitting). At the back of the intake, I drilled and tapped a hole going into the intake valley. On the bottom side of the intake, under this hold, there were ribs cast in. I took the intake to a shop and had them weld an aluminum plate over those ribs, so it effectively created a small pocket area on the bottom side of the intake. I drilled a 1/4-inch hole in that plate. What this did was create a large oil baffle under the port I drilled in the intake. I then drilled a hole in the air cleaner base (open element air cleaner in my case), on the INBOARD side of the air cleaner element. I then connected a hose from the port on the intake to the port on the air cleaner's base. The PCV valve in the base of the carb sucks air through the fill tube, which pulls from the lifter valley and heads, which pulls through the hose in the base of the air cleaner--which is filtered air through the air cleaner. The PCV valves are directional. If you put the wrong valve in, it will CLOSE when the carb base's vacuum port pulls it. That will then allow the top of the carb to pull air through the system the wrong way (from the back of the intake into the air cleaner). You'll know you have the wrong valve when your air cleaner fills with oil. This is essentially a recreated closed PCV system for early '60s California Emissions equipped vehicles: The difference is those engines used the breather port in the back of the block, where other vehicles used the road draft tube. If you google things like "1962 Chevy PCV system" or "Emissions" or such, you can probably find a diagram. I found one in a YearOne catalog and based my system off of it. Hope this helps. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
Thank you all!
#15 |
#16 |
The new one.
