Old 04-05-2009, 02:33 PM   #1
JimmyFloyd
Rocker box pictures
I am looking for some pictures of the stock rocker boxes on a 1970 blazer. The PO of my truck was an amature welder, and it looks like he took some liberties to strengthen some spots, and "create" his own panels. I am looking for pictures of the stock ones so I can compare them to mine and decide if I can just remove some of his handiwork, or if I need to get new ones.
JimmyFloyd is offline   Reply With Quote
Old 04-05-2009, 07:12 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Rocker box pictures
Top or bottom? The bottoms should look like snow sleds..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-06-2009, 12:26 AM   #3
PHAT TONY
PHAT TONY's Avatar
I don't know if this gives what you need, but it's what I've got of mine so far.
PHAT TONY is offline   Reply With Quote
Old 04-06-2009, 12:28 AM   #4
PHAT TONY
PHAT TONY's Avatar
The bottom lip you see is the pinch weld(outer to inner), other than that they look like loonngg shoe boxes.
Old 04-06-2009, 05:51 AM   #5
vtblazer
vtblazer's Avatar
Phat Tony, good pics but he's looking for rocker box pics, not torsion box pics...at least that's what he asked for anyway.
Jimmyfloyd, show us whatcha got to work with.
Here's a few of a stock outer rocker for ya, if you need or want more just ask but be descriptive.
I have pics of any & all stages from rip-n-tear through install.
vtblazer is offline   Reply With Quote
Old 06-30-2019, 11:20 AM   #6
JDSurge
Hey VT, I am getting ready to start repairing my 1972 Blazer, it has both inner and outer rocker panels rusted and about 8" of floor board rusted out on each side. I've looked thru YouTube for instructions but could only find Trucks, no Blazers. I would love to see your pictures from start to finish before I start mine. I'm not even sure what patch panels to purchase.
Any help would be appreciated.
JDSurge is offline   Reply With Quote
Old 07-01-2019, 08:28 AM   #7
JimmyFloyd
That portion of the blazer should be the same as the trucks, with the exception of the torsion boxes that cover the bottom side and add support when the top is off.
I would brace that area is you decide to remove the torsion box to access the underside. If you are not going to, take this time to clean the rust inside the box and coat it with something like POR15 or some other rust proof coating. You could remove the back access panek of the torsion box too for access, but it will be tight working space and your bolts may be rusty/tough to remove.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
Old 07-01-2019, 10:47 AM   #8
JDSurge
Thanks Jimmy. I wish someone on here has some pics to share so I could see what I'm getting into. Lots of Trucks on Youtube but no Blazers. I think I know what patch panels to order now.
JD
Old 04-06-2009, 07:30 AM   #9
litebulblsc
litebulblsc's Avatar
vtblazer, the rocker box and torsion box are the same thing.
http://www.gmcpauls.com/pictures/blazerrockerbox.jpg
litebulblsc is offline   Reply With Quote
Old 04-06-2009, 07:37 AM   #10
vtblazer
vtblazer's Avatar
You just posted a link to a set of replacement TORSION BOXES.
Don't believe everything you read, if GMC Pauls is calling those parts rocker boxes, they're wrong.
Trust me, I know the difference here and now, so do you.
Old 04-06-2009, 08:53 AM   #11
69-72
69-72's Avatar
Rocker boxes are the same as torsion boxes except that very few people call them torsion boxes, you posted a picture of rocker PANELS.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 04-06-2009, 09:44 AM   #12
PHAT TONY
PHAT TONY's Avatar
I assumed rocker "boxes" were the assembly of inner structure and outer rocker panel.
Old 04-06-2009, 12:22 PM   #13
RED72blazer
urban fourwheelin
RED72blazer's Avatar
that what I thought as well.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 04-06-2009, 11:13 AM   #14
JimmyFloyd
hrm... Mine don't look like that exactly (or not at all) looks like I had a happy home welder working on mine before. Ugh.
Will get pictures later.
Old 04-06-2009, 12:23 PM   #15
vtblazer
vtblazer's Avatar
No - no - no ...
There are THREE main pieces that make up the structure that keeps the door openings from sagging when the hard top is removed.
Working from the outside in:
1) Outer rocker
2) Inner rocker
3) Torsion box
ALL different, ALL separate and ALL necessary.
I posted a pic of a replacement pair of TORSION BOXES.
Old 04-06-2009, 12:35 PM   #16
RED72blazer
urban fourwheelin
this thread is confusing.
Old 04-06-2009, 09:37 PM   #17
69-72
69-72's Avatar
No - no - no ...
1) Outer rocker
2) Inner rocker
3) Torsion box
Do you happen to know what size spanner is required to take the bolts out of the end caps of the rocker boxes?
Old 04-06-2009, 09:43 PM   #18
vtblazer
vtblazer's Avatar
If your asking about these, they're 9/16th.
To make my life easier during this repair, I welded the nuts inside.
Old 04-06-2009, 09:57 PM   #19
RED72blazer
urban fourwheelin
are they normally the other way?
Old 04-07-2009, 12:07 AM   #20
70 Suburban
Rods
is a bitt of humor i see here......
70 Suburban is offline   Reply With Quote
Old 04-07-2009, 05:25 AM   #21
vtblazer
vtblazer's Avatar
Nope
Originally Posted by JimmyFloyd View Post
Well, this is what mine looks like on the driver's side
Looks like an outer, an inner but not torsion box.
Depending on your focus, there are 'other' ways to support the tub.
Was thinking the same...
Old 04-07-2009, 07:55 AM   #22
Garagmahal That`s rich!!!
Old 04-06-2009, 01:03 PM   #23
PHAT TONY
PHAT TONY's Avatar
I haven't been inside a blazer rocker yet, I'm thinking the outer rocker(same as a truck) has an inner rocker(same as a truck) that is attached to the larger structure(box), yes?
Old 04-06-2009, 01:19 PM   #24
70 Suburban
Rods
not realy vt laied it out. as per fsm and not some sales ppl at some store. outer and inner. and torsion. if its was a rocker box as a standard part woulnt you think all truck would have them.... hmm somthing to consider.
Old 04-06-2009, 01:55 PM   #25
PHAT TONY
PHAT TONY's Avatar
No, I wouldn't think a truck would have them, a truck has a roof and rear cab structure to keep the a and b pillars from spreading.
