04-06-2009, 07:05 PM | #26 |
Re: Rocker box pictures
Glad to see you made it over, Jimmy!!
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
04-06-2009, 08:00 PM | #27 |
GOSH! I was just posting a couple pics of the area he was asking about because mine is complete and original and i assumed by the initial post a comparison was needed. wow.
04-06-2009, 08:15 PM | #28 |
Rods
04-06-2009, 09:30 PM | #29 |
And we thank you.That is what he wanted,but terminology just got goofy.People have been calling wheelcovers hubcaps forever and they are wrong.it`s all about the education here and fun.I just don`t like seeing people shunning correct information.GM calls them torque boxes.
04-06-2009, 09:37 PM | #30 | |
Do you happen to know what size spanner is required to take the bolts out of the end caps of the rocker boxes?
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
04-06-2009, 09:43 PM | #31 | |
To make my life easier during this repair, I welded the nuts inside. |
04-06-2009, 09:57 PM | #32 |
urban fourwheelin
are they normally the other way?
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
04-06-2009, 10:45 PM | #33 | |
SKINNY TIRES RULE!
Just kidding....
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
04-07-2009, 12:04 AM | #34 |
Well, this is what mine looks like on the driver's side
and some other of his handiwork: |
04-07-2009, 12:07 AM | #35 |
Rods
04-07-2009, 05:25 AM | #36 |
Nope
Looks like an outer, an inner but not torsion box. Depending on your focus, there are 'other' ways to support the tub. Was thinking the same... |
04-07-2009, 07:55 AM | #37 |
Garagmahal That`s rich!!!
04-07-2009, 11:41 AM | #38 | |
Ok, so what are some of my options? Would more pictures be helpful? I can try and take some tonight. I would like to try and do it right, and correct some of this mess. |
04-07-2009, 12:27 PM | #39 | |
New Member
04-07-2009, 10:35 PM | #40 | |
Rods
04-07-2009, 11:00 PM | #41 |
New Member
So what's a hubcap? They may be wheelcovers according to GM but maybe Ford or Chrysler calls them hubcaps. Someone somewhere has to call them hubcaps or else that term would not be so widely used. I bet if there was a survey done, more people would know what a hubcap is over wheelcover.
04-07-2009, 11:22 PM | #42 |
Rods
you are correct... but we are on a gm site....... so wheelcovers over caps....In general conversation I may call them hub caps......but a hub cap is icorrect... see its like this... a wheel cover is just that a wheel cover.. a hub cap is just that.. the little round thing on the end of the spindle (knuckle for those that realy know what it is) is a cap.the little disk that only coverd the lugs and knuckle cap is a hub cap.
04-08-2009, 12:30 AM | #43 |
I believe the dead horse can be drug/dragged away now.
04-08-2009, 06:37 AM | #44 |
Don't drag the horse away guite yet, no,no,no, the hubcap only covers the wheel bearings...hence, the wheel hub, the hub cap. Now drag it away
04-08-2009, 06:58 AM | #45 | |
If you want to keep things stock and use your blazer as a daily driver, wanting it to look original, I'd say you have two option's. 1) buy a factory replacement set of torsion boxes as pictured above. 2) fab up and support the tub in some other manner but keep it within the stock area using tubing or similar. Option 1 would be the easiest IMO. OR...if it's a wheeler kind of ride, you could do some basic support above the floor. Another way would be to build a cage and tie the tub into that for structured support. These pics are of my off road blazer, torsion boxes were long gone when I got it and I was going for maximum clearance. I completely cut out everything, including the rocker boxes but still had to support the firewall, here's what I did. |
04-08-2009, 07:44 AM | #46 |
Buy a welder, practice and when I come thru Binghampton I'll show ya. Thought mine were hideous, you got me beat
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-08-2009 at 07:47 AM. |
04-08-2009, 09:05 AM | #47 | |
The fact of the matter is that everyone knows what the term rocker box applies to, you wouldn't use that term describing a part on a 1/2 ton.
04-08-2009, 10:12 AM | #48 | |
Rods
The reason there is a debate is that not everyone knows what it is... We have already stated that the part in question is not on a 1/2 ton or any ton TRUCK. its a blazer spicific part. |
04-08-2009, 10:17 AM | #49 | |
Still considering getting a welder. Need to sell a few more things first (compromised with the GF that I'd only spend the money I made selling other things on this.) Anyone want to buy a tonka truck? |
04-08-2009, 11:00 AM | #50 | |
Careful not to turn this into a For Sale Thread, better go back and delete that last
