Old 05-31-2011, 10:28 PM   #1
crisco
Hard starting 87 TBI Suburban
My 87 suburban with a 350 TBI has an odd problem I can't nail down.
If I get in, turn the key, and crank it won't start for a good 5 seconds.
BUT if I get in, and only turn the key to the crank position for a second, wait a second, then do it again it starts instantly.
It seems like the pump isn't priming unless its cranking?
Any ideas?
crisco is offline   Reply With Quote
Old 06-01-2011, 07:09 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Hard starting 87 TBI Suburban
is there no sound from the fuel pump ,just before crankin
i usally turn the key wait for the pump to stop then crank
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 06-07-2011, 07:51 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
Sounds like a fuel pump that's getting weak.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-09-2011, 11:10 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yep that's the same thing I was thinking. Did you listen for the pump priming when you turn the key yet?
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
