Hard starting 87 TBI Suburban
My 87 suburban with a 350 TBI has an odd problem I can't nail down.
If I get in, turn the key, and crank it won't start for a good 5 seconds. BUT if I get in, and only turn the key to the crank position for a second, wait a second, then do it again it starts instantly. It seems like the pump isn't priming unless its cranking? Any ideas? |
78K & 79C Jimmys
Re: Hard starting 87 TBI Suburban
is there no sound from the fuel pump ,just before crankin
i usally turn the key wait for the pump to stop then crank
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Chevys Kick A$$
Yep that's the same thing I was thinking. Did you listen for the pump priming when you turn the key yet?
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
