12-28-2011, 11:01 PM | #1 |
Ash Tray Removal
Okay, Kinda embarrased. How do you remove the ash tray? Its not full of ashes to dump out or anything, just trying to see how it comes out.
Thank you, Kevin C
1988 C1500 Regular Cab, Long Bed, 2WD. |
12-28-2011, 11:12 PM | #2 |
Re: Ash Tray Removal
Push the center tab down that is inside and catches at the top, then pull it out.
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed |
12-29-2011, 05:58 AM | #3 |
Tried that. I have it depressed as far down as it goes, but just won't tilt out. May just need to get more agressive with it.
Thank you, Kevin C
12-29-2011, 07:01 PM | #4 |
If it opens and closes normally then it should just slide right out hen the tab is depressed. That's really all that's holding it in place.
Rockin' a '66 and loving every minute of it |
03-07-2019, 06:49 PM | #5 |
This is an old thread but I can't get the ashtray out of my 64. What am I missing?
03-08-2019, 02:21 PM | #6 |
Moderator
After you push down the tab and pull it out just a little, lift it up and out.
03-08-2019, 07:54 PM | #7 |
But Found Her 25yrs Later!
You first have to remove the windshield. Then drill out all the spot welds to remove the dash, and then....
03-08-2019, 08:32 PM | #8 |
I did it!! Thanks!!
03-11-2019, 04:06 PM | #9 |
It has a bad design flaw.
Try doing it with it full of butts. Have quit smoking now so only gum wrappers now. Not as messy to clean up. Cal. |
03-11-2019, 11:05 PM | #10 |
I 3D printed a plate to hold switches and a usb charger to replace the ashtray...
03-14-2019, 03:19 PM | #11 |
looks good!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
