Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 05-24-2012, 11:22 AM   #1
Hogsophist
8" low profile sub
anyone tried one of these?
http://www.crutchfield.com/p_068SUB8...rv=12625223545
I'm looking for just good sound, not anything more. I have ordered the retrosound stereo and kick panel speaker assembly for my 57 and thought about this as the sub.
Hogsophist is offline   Reply With Quote
Old 05-24-2012, 11:40 AM   #2
JRANGER
JRANGER's Avatar
Re: 8" low profile sub
I went with a Pioneer setup. Fit perfect behind the seat of my 78 and i can still push the seat all the way back. I bought mine off buy.com though as it was a lot cheaper
SUB:
http://www.crutchfield.com/p_130TSS2...S2501&skipvs=T
BOX:
http://www.crutchfield.com/p_130DSW1...UD-SW100T.html
JRANGER is offline   Reply With Quote
Old 06-05-2012, 09:28 PM   #3
Red68
Red68's Avatar
SUB:
BOX:
That is the same sub I have with a custom build box behind the seat of my 68. Powered by a 500 watt alpine amp. Sounds great!
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 05-25-2012, 04:33 PM   #4
tubbedII
needs more $$$
tubbedII's Avatar
I've never seen or heard that product. However, I wouldn't expect much out of it. The size of the entire piece is less than .2 cubic feet which doesn't include the speaker, amp or even the material thickness (So I'd be guessing less than .1 cubic foot of actual volume). I always hear that the enclosure/installation is the biggest factor in a good system, and this issue would make me stay clear.
I once built an enclosure at half the recommended size due to bad math and it sounded horrible...after rebuiling the box, it sounded great with no other changes.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 05-25-2012, 08:56 PM   #5
Matt R
Matt R's Avatar
The pioneer stuff looks pretty good. You could also do some Tang Band woofers from parts-express.com or some Dayton audio shallow woofers. I've used several Tang Band products, they are very good for the price especially.
Matt
My build thread http://www.67-72chevytrucks.com/vboa...d.php?t=494247
Matt R is offline   Reply With Quote
Old 06-03-2012, 03:57 PM   #6
utee05
I was recommended to look at either the Polk MM series (840 8") or the Alpine Type-R (SWR-T10). In my case I was looking to place some subs underneath the seat. You can also look at the TC Sounds Epic 8".
utee05 is offline   Reply With Quote
Old 06-04-2012, 10:52 AM   #7
tubbedII
needs more $$$
tubbedII's Avatar
I don't know how much room is under a typical bench (never measured personally), but I have seen 1 10" woofer under one. If this is a route you can go, I would recommend the RE Audio REX series 8" woofer. I have heard the 10" and for the price (about $50), I don't think it can be beat. The 8" only requires .35 cubic feet of enclosure sealed, so I would imagine you'd be able to get 1 under the seat incredible ease and more than likely 2 with 1 under each side.
1970 2wd Blazer
Old 06-04-2012, 11:37 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
RE audio was sold to a new company a couple years back, and the quality has gone downhill. They used to be a great "boutique" brand, and while there high end stuff is still pretty good for the money, the overall quality and service has suffered.
Focal makes some really impressive options, but the price is sometimes deterrent.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-04-2012, 12:59 PM   #9
tubbedII
needs more $$$
tubbedII's Avatar
Really?! That's bad news...I liked this line a lot.
1970 2wd Blazer
Old 06-08-2012, 05:01 PM   #10
chevy72blu
chevy72blu's Avatar
Thats too bad. I actually met the owner a few times here in Las Vegas. Very passionate guys who took a lot of pride in their work. They were the "in" thing several years back.
I still have a few of their 8" and 12" woofers that sound like 12's and 15's respectively.
chevy72blu is offline   Reply With Quote
Old 07-05-2012, 03:27 PM   #11
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Matt
Tang Band 8s are great! they are pretty deep for an 8 though. I had 4 in a T-Line in my mazda b2200. I could do 146.1 at 43hz on 600RMS.
David who used to own RE now owns PSI car audio as well as fix my speaker.
ProStreet68SB is offline   Reply With Quote
Old 06-04-2012, 12:06 PM   #12
utee05
From my initial measurements in my 72 C1500 you should be able to fit a box that can allow up to 8" of depth. I am looking to fit a 10" underneath my set with a box that is 7" in depth.
Old 06-14-2012, 04:50 PM   #13
claytonisbob
Another slimline sub option is the 10" sub from ED: the SQ10
http://www.edesignaudio.com/product_...roducts_id=106
They're obviously not super high powered, but they sound good and they're cheap. I've been an Elemental Designs fan for years. They'll also build you a custom box if you want.
claytonisbob is offline   Reply With Quote
Old 06-14-2012, 05:01 PM   #14
utee05
Also check out the Polk MM1040:
http://www.crutchfield.com/p_107MM10...io-MM1040.html
I am also a fan of ED as I have been using their equipment for years in my car and home theater. I may look at those EDs as well for my setup.
'72 GMC Super Custom 1500 350 V8 w/AC
Old 06-15-2012, 11:13 AM   #15
Hogsophist
after way too much research, and really liking the sound of the kick panel speakers that were in, i decided that for the money, i'm going to try one of these low profile subs. Easy for a dummy like me and with such a small space, i dont think i will need anything else. I'll let you guys know when i get it hooked in.
ordered a pyle 10" low profile sub off amazon for a pretty decent deal. Good reviews. We shall see.
Old 06-25-2012, 02:48 PM   #16
dukcaln
dukcaln's Avatar
please let me know because I need to get a sub installed under the seat too...I was looking at the pioneer.... keep us updated
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 06-25-2012, 07:18 PM   #17
E.Furgal
I like rockford fosgate.. some of mine are 15 years old and still work like new..
E.Furgal is offline   Reply With Quote
Old 07-03-2012, 11:34 PM   #18
colin_havens
colin_havens's Avatar
From what I understand, the guys that had RE Audio eventually opened up another speaker company called Fi Car Audio
Not sure if they offer a slim sub, but they make some amazing speakers. I would love to run one of their Q series 10s in my 67. Thats the plan anyway for the future when I revamp the audio in it.
colin_havens is offline   Reply With Quote
Old 07-05-2012, 11:59 AM   #19
jimmydean
jimmydean's Avatar
Pioneer's are a solid sub for a low profile. I was looking at running four 8's in my buddy's Dodge.
I was going to use the Alphasonik shallows, but I managed to find enough room to use the Polk Audio MM 10" instead of the shallow. The MM 10" is only 4.5" deep and uses very little air for a sealed setup.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 07-05-2012, 12:14 PM   #20
utee05
In my setup I ended up going with some Alpine 8" subs. I got a SWR-843D sub and looking to get another one so each will go underneath the passenger and driver. These subs are only 4.5" deep and can fit in a 0.4cuft sealed enclosure. Also they only take about 200W RMS power.
Old 07-05-2012, 12:25 PM   #21
tubbedII
needs more $$$
tubbedII's Avatar
How'd that polk sound, jimmydean? I was contemplating them for the Blazer, but have decided on a set of Sundowns instead.
1970 2wd Blazer
Old 07-05-2012, 12:37 PM   #22
jimmydean
jimmydean's Avatar
They aren't as good as the older version I used in my Toyota (two 8's in there), but still one of my favorite subs all around. Good power, solid bass, great for tight spaces and a good price.
At .75ft3 per 10, it's a nice fit behind my Caddy seats. Still waiting on my amp purchase before building anything more at this point.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 07-05-2012, 12:42 PM   #23
tubbedII
needs more $$$
tubbedII's Avatar
I know the feeling! I have the amp for the Blazer, just need to rack up some $$$ for the speaker purchase...
What amp are you going with?
1970 2wd Blazer
Old 07-05-2012, 01:47 PM   #24
Billett
Billett's Avatar
Sundowns are fantastic subs. Even the 8" ones can hang in with some of the better name brand 12"s. Unfortunately Sundown doesn't make any shallow ones to my knowledge. Fi is arguable one of the best brands out there right now for subs but they will definitely cost you. I'd rate polk above alpine/pioneer but Fi quality. Whatever you do do NOT under any circumstances waste your money on a set of sonys... Right now the best shallow mount out there is the JL 13tw5-3. A friend of mine has one in the trunk of his Camaro and I have to say it is a bit better quality than the pair of 12" full size JLs that I have. Unfortunately it also costs a bit more
Not trying to bad mouth the subs you guys bought just giving out my opinion. As far as setup, as long as you keep in mind the ft^3 that the speaker needs in a box almost anything can sound good with a well built box. A lot of people I meet think that they need the biggest subs with the highest max output, when really this sub is just going in a truck cab. 10" max is all you really need when the speaker is bumping 6" under your a$$ in a small cab. max watts mean nothing, RMS is more important. Expensive speakers still sound like crap if you put them in too small of a box, and my biggest pet peeve is quality. What good is a loud subwoofer if it is so distorted you can't even hear the lyrics of your music through the garbage!
again not trying to degrade anything you guys bought. As long as it isn't sony its fine with me, I just get a little riled up over bad sound system advice so I'm trying to preemptively give good advice haha
sorry about that /rant.
Billett is offline   Reply With Quote
Old 07-08-2012, 05:41 AM   #25
dliving69
dliving69's Avatar
I recently put a 10 Kicker CVT in my truck which is a slim line sub in the slim box made for it bye KICKER. and it shakes my truck with 300 watts.
dliving69 is offline   Reply With Quote
