Old 05-30-2012, 08:09 PM   #1
newtimer
Cheap Rear Disc Conversion '73
I really want to convert my rear drums to discs and thought about pulling a newer model Chevy rear axle with disc brakes already set up. Any body know if this will work, and if so what to get it from?
newtimer is offline   Reply With Quote
Old 05-30-2012, 08:17 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Cheap Rear Disc Conversion '73
What axle does it have now?
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 05-30-2012, 08:38 PM   #3
newtimer
Not sure. I am new at restoration and don't really know a whole lot. How would I be able to tell?
Old 05-31-2012, 02:23 AM   #4
andrewmp6
This will help you id the rear end http://coloradok5.com/axleguide.shtml But check out the vendors market on here there is a few rear disc kits cheap like http://67-72chevytrucks.com/vboard/s...d.php?t=382633
Old 05-31-2012, 07:52 AM   #5
newtimer
Awesome! Thanks for giving me a great starting place! I have looked for hours trying to find someone just selling the mounting plates by themselves, with no luck. Thanks again.
Old 05-31-2012, 04:56 PM   #6
JRANGER
JRANGER's Avatar
I need this info too.. Subscribed for it
JRANGER is offline   Reply With Quote
Old 05-31-2012, 10:28 PM   #7
Pro Performance
Pro Performance's Avatar
I am not 100% sure on the specifics, but maybe even check out the rear ends from a 94-96 Impala SS. They will have the rear disc setup, and be 5x5 bolt pattern.
Maybe someone else has already looked into this and has more info.
Pro Performance is offline   Reply With Quote
Old 05-31-2012, 10:49 PM   #8
74 stepside
74 stepside's Avatar
I believe the Cadillac Sevilles form 76-80 will work also. They have rear disc with 5 on 5 bolt pattern.
74 stepside is offline   Reply With Quote
Old 06-01-2012, 10:59 AM   #9
wyattglock
wyattglock's Avatar
The nice thing about the Caddy setup is that you retain the e-brake with the disc calipers.
I got my disc brake brackets for my Dana 70HD from www.diy4x.com. Not sure if he has half ton brackets or not, but it might be worth checking out.
wyattglock is offline   Reply With Quote
Old 05-31-2012, 10:55 PM   #10
JRANGER
JRANGER's Avatar
hmmm will that work on a 78 as well?
axle, brakes, conversion, disc, switch
