Tot Roddin'
Accuair - Worth the cost?
Accuair has become the premier retailer for managing your air ride over the last couple of years. Looking at the trucks build by n2billet, Delmo, etc. makes you realize these products are top notch, but typically with top notch products come a price worthy of the R&D, manufacturing, etc. to bring the product(s) to market.
I wanted to see what member's opinions were on the products offered and how they compare to other competitors. Let's hear your experiences. ![]() Nate
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Re: Accuair - Worth the cost?
Money to me was not an issue and i decided to go with ride tech. They have been around a long time and their products thus far have been flawless. There are four vehicles in my family that all of them have ride tech as well for years and they have had zero issues. No different than the classic auto air and vintage air debate..both systems are great i think it boils down to a popularity contest at the end of it all.
So nate do i see your truck going on bags finally?
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Project 7dos
I've got Accuair sitting waiting to be installed along with Porterbuilt stage 2 stuff...
We could have saved a ton of money piecing together a system, but it wouldn't have been the same quality. As far as the Porterbuilt stuff, we have a truck that we are extremely proud of, and we couldn't be happier to buy from a company who has R&D'ed parts soley for C-10. When you look at a porterbuilt product, you know it's quality. Same for the Accuair stuff... When you hold the VU4 valve block in your hand, you know you got your money's worth. Can't wait to get all this stuff installed. Thanks to Travis @ Pro Performance.
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
#4 | |
![]() Join Date: Jul 2010
Sounds like a nice build. I question the ability to "save a ton of money piecing together a system". I hear this from a lot of people. Getting quality is never cheap, but as you yourself know, you have to add it all up. 8 parker valves, 8 brass T's, 15 short brass nipples, 12 NPT to hose quick connects... the fittings add up. Wiring, shrink wrap, connectors......bla bla bla. If you add it ALL up, there is no real savings, and less quality. Quality parts like AccuAir and RideTeck valve blocks and controls are worth every penny.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
#5 | |
Project 7dos
Glad we saw the light though, because that would have gotten old REAL quick.
Happy to be here
![]() Join Date: Mar 2000
I have yet to own one of their systems, but my research says YES! Talk to Keith (n2billet) has has owned several Ride Tech systems, and now has an Accuair too. He tells me they are really nice.
AccuAir is worth every penny. My system has worked flawlessly since day one, Ill be running their system on anything I do from now on.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
YES! Accuair is fantastic. Such a simple install and getting rid of all those brass pipe fittings is great! I just have the VU4 block with electric toggle switches, but am tempted to get the e-level kit.
I dont know about the E-level, but the manifold itself is worth it. It save you tons of time and headaches.
needs more $$$
I haven't installed one myself, but watched the installation of the manifold be installed on a caddy. It took 30 minutes which included drilling holes for lines to go through the trunk and even drilling/tapping hold downs. That along with not having to chase down leaks at every brass fitting makes it worth the extra $40 bucks (at least that's all I saved with my 8 valves and a ton of fittings). If a single valve ever goes wrong on my rig, that'll be the day I swap.
1970 2wd Blazer |
Looks really nice and an intresting thread that provides all the info in format that even a new be could understand, as far as it comes to installations and up gradations i am pretty new to the feild and looking forward to it.
You have to take into account the servicability of the manifold as well. If one valve in the manifold goes bad can it be replaced or do you have to replace the entire manifold?
One valve can be replaced
I will use one on my build. I did 8 valves pair mounted by each bag on my '69. I liked how it worked, but it wasn't pretty and was a lot more work than a valve block.
I would say it's worth it for both ease of install and cleanliness.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#15 |
If you dont wanna drop the coin right now all at once, you could just buy the manifold and run a switch box until you buy the level system later on. That's what I did.
#16 |
Tot Roddin'
Thanks guys... just wanting to see what everyone's opinion is on their products as they seem to be the new product everyone has to have.
#17 |
i purchased my accuair unit in may of 2011, i traded trucks and dilly dallied a while. I finally installed it this july and used it about a dozen times. i drove the truck in august, parked until last week. when i took to the cruise on of the valves wasn't closing or 'leaking through'. it's not stopping the air from filling the bag (had a mean gangster lean before i realized). i cycled up and down a few times to try and blow any out, but i have 2 traps in line and the tanks were new. i don't think anything would be in the valve, but i haven't had time to look it over, i can't be certain.
this is not a rant or testament of quality...just sharing my experience. it's custom and stuff happens. fixing it is half the fun, right?
John J Bodied 1994 Suburban on custom frame - http://67-72chevytrucks.com/vboard/s...d.php?t=672297 Dad's 1948 Suburban - http://67-72chevytrucks.com/vboard/s...d.php?t=563150 Bagged 1995 Suburban - SOLD Bodied 1995 Tahoe -SOLD |
#18 | |
Tot Roddin'
Misread on the level unit?
#19 |
just the manifold, i'm using dakota digital controller with no leveler. I use air pressure on each corner to gauge height. i went to the show (a block away) and dumped all the bags to zero. went and helped park cars and what not for about 20 minutes then i saw the front pass was up and the bag was at 145psi (matching the tank pressure).
i left air out, watched it start to climb again. i cycled air in and out until the tank was empty and left the problem for another day. i haven't checked anything, it could be any number of things at this point. i drove the truck 170 miles before parking it, but the valve didn't act up the next day when i washed the truck. it just happened after sitting.
#20 |
I was working on piecing together a system, and ended up getting my compressors and Porterbuilt stuff from Travis @ProPerformance. I will be running DLOE"s manual valves (cause I like the idea of less wiring and no solenoids, and I am more of a cruiser than a hopper). If I had it to do over again, I would have ordered DLOE's valves, and the rest of the stuff from Travis. I know this might be a litttle off subject (not Accuair or Ridetech), but I said all of that to say this: It is always better to get as much of the system as you can from one source, because these kits were designed to function together. I am the king of trying to save a penny, but at the end of the day I have learned that if you don't want to pay for quality, you might better just leave it alone. I am new to air ride, but it looks to me like a sub-standard system would be a HUGE pain in the butt, and might be dangerous, too. I'm sure that there are people on this site who could make their own system and do a great job, but for me it is better to stick with a kit (and read the dad-gum instructions).
=MATTHEW 69 Stepper...Stroked & Bagged ![]() 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
#21 |
![]() Join Date: Sep 2010
When I first decided to bag my truck I was planning on piecing it together. After doing alot of research I decided to go with the e-level system and I absolutly love it. From the awesome touch pad to the self leveling and now the i-level coming out! Not to mention the customer service, Reno is great. Any time I've had an issue (all self induced) I email or call him directly and he has me fixed up in minutes.
#22 |
Hey thanks for such a nice and informative post along with all those links providing quality precise information about how to go about a job.
#23 |
Man of Mini-Talents
If their controller had a display with the pressures and diagnostics, I might consider it. Hard to believe a major player doesn't have that.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#24 | |
Posted via Mobile Device |
#25 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Nate,... I would look at this kit.
You could add dual needle gauges to it. Switching to E-level would be an option for later on. http://accuairsuspension.com/product...speed_amp.html SwitchSpeed Air Management Package NON-LEVELING Includes: (1) SwitchSpeedTM Controller (Electroless Nickel or Black Anodized Finish) (1) Viair Mechanical Pressure Switch (145psi) (1) VU4 4-Corner Valve Unit (1 or 2) Viair 400C Compressor Kit(s) (1) 5-Gallon Anodized Aluminum Air Tank (1) Serviceable Aluminum Air Filter (1) 3/8" D.O.T. Approved Plumbing Kit
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-20-2012 at 10:07 PM. |
